Warning message
887VAG router only slip encapsulation supported
I have a 887VAG router with 15.1(2r)T2 software. I am trying to setup the Cellular 0 interface with encapsulation ppp but it comes back with only slip encapsulation is supported. I need ppp encapsulation because I am trying to connect to the telstra.corp APN which requires CHAP authentication.
Does anyone know how I can get ppp encapsulation to work.
thanks
gh
paolo bevilacqua Tue, 09/17/2013 - 02:32
  • Hall of Fame,
    Founding Member
You need to configure a dialer interface. If you never done thaqt before, check configuration examples.
Also, this the wrong forum, post in "WAN and routing". You can move your posting with the Actions panel on the right.
