Cisco 881 Router Help
Sep 16th, 2013
I have inherited a network with no handover. There is a Cisco 881 router and I'm trying to gain access but having no previous Cisco experience I have no idea how to.
So some quesstions.
1. Does the Cisco 881 support DHCP server, ie can it allocate IP addresses
2. Is the Router accessible via the web, I know its IP etc but don't know how to configure it
Very basic questions I know, but I appreciate your help.
mvsheik123 Tue, 09/17/2013 - 13:26
  • Gold, 750 points or more
Yes & Yes - It can act as DHCP server and can be accessible via web.  Refer to datasheet below..
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78_459542_ps380_Products_Data_Sheet.html
I would suggest to exercise password recovery procedure, to gain access to the same.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_password_recovery09186a00800942bc.shtml
hth
MS
PS: Pls rate helpful posts.
Leo Laohoo Tue, 09/17/2013 - 19:16
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Yes, but with some limitation.  The router will not be able to support ALL DHCP options.
Yes and no.
Firstly, your router should have Cisco Network Asstance (CNA) files.  If someone (like me), erased it you can go to the Cisco website and download CNA and re-install into the router.
So, the answer is yes.
But I wouldn't recommend it for the following reasons:
1.  Not all browsers are supported.
2.  Configuration via HTML can cause the CPU to balloon up.
3.  Not all features are supported via GUI.
If you are not "familiar" with command line interface (CLI) then I recommend you start getting used to it.  If you want to get the benefit of any Cisco enterprise kit, CLI is the way to go.
Related Content
