Warning message
Cisco ASA 5520 Crash Report Seem to crash every morning around the same time
Sep 17th, 2013
any help would be much appreciated.
: Saved_Crash
Thread Name: Dispatch Unit
Illegal operation: Illegal operand
    vector 0x00000006
       edi 0x6e9340f8
       esi 0x000041d1
       ebp 0x6e71d718
       esp 0x6e71d6fd
       ebx 0x40011e00
       edx 0x00007530
       ecx 0xff5fc800
       eax 0x706f1408
error code n/a
       eip 0x09140960
        cs 0x00000073
    eflags 0x00013246
       CR2 0x00000000
Cisco Adaptive Security Appliance Software Version 9.1(1)
Compiled on Wed 28-Nov-12 10:38 by builders
Hardware:   ASA5520
Crashinfo collected on 05:47:12.302 EDT Tue Sep 17 2013
Traceback:
0: 0x080627e0
1: 0x08062821
2: 0x080649d5
3: 0x08eb53a0
4: 0xffffe410
5: 0x08a5e1af
6: 0x09144857
7: 0x0827eab9
8: 0x0806922c
Stack dump: base:0x6e71d618 size:280, active:280
entries above '==': return PC preceded by input parameters
entries below '==': local variables followed by saved regs
             '==Fn': stack frame n, contains next stack frame
                '*': stack pointer at crash
For example:
    0xeeeeef00: 0x005d0707     : arg3
    0xeeeeeefc: 0x00000159     : arg2
    0xeeeeeef8: 0x005d0722     : arg1
    0xeeeeeef4: 0x005d1754     : return PC
    0xeeeeeef0: 0xeeeeef20 ==F2: stack frame F2
    0xeeeeeeec: 0x00def9e0     : local variable
    0xeeeeeee8: 0x0187df9e     : local variable or saved reg
    0xeeeeeee4: 0x01191548     : local variable or saved reg
    0xeeeeeee0: 0x014dde20     : local variable or saved reg
0x6e71da78-0x6e71da70: 0x00000000
0x6e71da6c-0x6e71da68: 0x00000072
0x6e71da64: 0x0000006f
0x6e71da60: 0x0000006b
0x6e71da5c: 0x00000000
0x6e71da58: 0x0984e55a
0x6e71da54: 0x6e732298
0x6e71da50: 0x6e6ea350
0x6e71da4c-0x6e71da48: 0x00000000
0x6e71da44: 0x00000030
0x6e71da40: 0xa11c0123
0x6e71da3c: 0x00000063
0x6e71da38: 0x4740d4d0
0x6e71da34: 0xa11ccdef
0x6e71da30-0x6e71da2c: 0x0fffffff
0x6e71da28-0x6e71da20: 0x00000000
0x6e71da1c: 0x0ad37b20
0x6e71da18: 0x00000000
0x6e71da14: 0x6e71d9b8
0x6e71da10: 0x6e71d9f8
0x6e71da0c: 0x00000000
0x6e71da08: 0x6e5d2f1c
0x6e71da04-0x6e71d9e4: 0x00000000
0x6e71d9e0: 0x0a4f35d4
0x6e71d9dc: 0x0805d960
0x6e71d9d8: 0x09988342
0x6e71d9d4: 0x00000002
0x6e71d9d0: 0x00010010
0x6e71d9cc: 0x0b031f20
0x6e71d9c8: 0x6e71d9b8
0x6e71d9c4: 0x6e6ea2d0
0x6e71d9c0: 0x0ad5818c
0x6e71d9bc: 0x6e5d2f1c
0x6e71d9b8: 0x6e71da08
0x6e71d9b4: 0xdeadfeed
0x6e71d9b0-0x6e71d9ac: 0x00000000
0x6e71d9a8: 0x0805e56c
0x6e71d9a4: 0x6e737f08
0x6e71d9a0: 0x6e6ea2a0
0x6e71d99c-0x6e71d998: 0x00000000
0x6e71d994: 0x00000084
0x6e71d990: 0xa11c0123
0x6e71d98c: 0x000000b3
0x6e71d988: 0x4740d4d0
0x6e71d984: 0x00000000
0x6e71d980: 0xa11ccdef
0x6e71d97c-0x6e71d96c: 0x00000000 ==F5
0x6e71d968-0x6e71d8dc: 0x12345678
0x6e71d8d8: 0x08069219
0x6e71d8d4: 0x6e71d8b0
0x6e71d8d0: 0x6e71d978
0x6e71d8cc: 0x00000000
0x6e71d8c8: 0xffffefc8
0x6e71d8c4: 0x6e5d2d8c
0x6e71d8c0: 0x00000000
0x6e71d8bc-0x6e71d8b4: 0x12345678
0x6e71d8b0: 0x6e6fd890
0x6e71d8ac: 0x0806922c
0x6e71d8a8: 0x6e71d978 ==F4
0x6e71d8a4: 0x00000000
0x6e71d8a0: 0xffffefc8
0x6e71d89c: 0x6e5d2d8c
0x6e71d898: 0x12345678
0x6e71d894: 0x00000000
0x6e71d890-0x6e71d88c: 0x00000007
0x6e71d888: 0x12345678
0x6e71d884: 0x00008394
0x6e71d880: 0x0e325616
0x6e71d87c: 0x12345678
0x6e71d878: 0xffffffff
0x6e71d874: 0x0000060e
0x6e71d870: 0x6e72f790
0x6e71d86c: 0x00000000
0x6e71d868: 0x6e72b040
0x6e71d864: 0x6995c042
0x6e71d860: 0x00000000
0x6e71d85c: 0x0000004e
0x6e71d858: 0x12345678
0x6e71d854: 0x000000c5
0x6e71d850: 0x19417a18
0x6e71d84c: 0xb5500c31
0x6e71d848: 0x6e5d2df0
0x6e71d844: 0x00000000
0x6e71d840: 0x00000019
0x6e71d83c: 0x00000004
0x6e71d838: 0x00000032
0x6e71d834: 0x6e71d880
0x6e71d830-0x6e71d82c: 0x12345678
0x6e71d828: 0x00000000
0x6e71d824: 0x0000d021
0x6e71d820: 0x6e71d88c
0x6e71d81c: 0x0827eab9
0x6e71d818: 0x6e71d8a8 ==F3
0x6e71d814: 0x744b0040
0x6e71d810: 0x000000e5
0x6e71d80c: 0xbaa774a8
0x6e71d808: 0x00000000
0x6e71d804: 0x00008394
0x6e71d800: 0x108546fa
0x6e71d7fc: 0x000041ca
0x6e71d7f8: 0x0842a200
0x6e71d7f4: 0x000041ca
0x6e71d7f0: 0x07426600
0x6e71d7ec: 0x6fa90368
0x6e71d7e8: 0x00000014
0x6e71d7e4: 0x00000000
0x6e71d7e0: 0x6faa0e7c
0x6e71d7dc-0x6e71d7d8: 0x00000000
0x6e71d7d4: 0x6e9340f8
0x6e71d7d0: 0x6faa0e7c
0x6e71d7cc: 0x6e71d7f8
0x6e71d7c8-0x6e71d7b8: 0x00000000
0x6e71d7b4: 0x00008394
0x6e71d7b0: 0x706f1408
0x6e71d7ac: 0x09144857
0x6e71d7a8: 0x6e71d818 ==F2
0x6e71d7a4: 0x08a5e040
0x6e71d7a0: 0x706f1408
0x6e71d79c: 0x00000000
0x6e71d798: 0x10854c22
0x6e71d794: 0x00000000
0x6e71d790: 0x0542be00
0x6e71d78c: 0x000041ca
0x6e71d788: 0x0842a800
0x6e71d784: 0x00004100
0x6e71d780: 0x6e6df8e0
0x6e71d77c: 0x000041ca
0x6e71d778: 0x0842a800
0x6e71d774: 0x00007530
0x6e71d770: 0x6e6df520
0x6e71d76c: 0x00000040
0x6e71d768: 0x08e2e000
0x6e71d764: 0x00000020
0x6e71d760: 0xe5042154
0x6e71d75c: 0x744b00e8
0x6e71d758: 0x6e71d768
0x6e71d754: 0x690f17d8
0x6e71d750: 0x00000000
0x6e71d74c: 0x08562f8a
0x6e71d748: 0x6e71d768
0x6e71d744: 0x00000000
0x6e71d740: 0x6e730d40
0x6e71d73c: 0x000000e9
0x6e71d738: 0x00000000
0x6e71d734: 0x69894b20
0x6e71d730: 0x04000fbd
0x6e71d72c: 0x000041d1
0x6e71d728: 0x40011e00
0x6e71d724: 0x08a5e040
0x6e71d720: 0x706f1408
0x6e71d71c: 0x08a5e1af
0x6e71d718: 0x6e71d7a8 ==F1
0x6e71d714: 0x706f1408
0x6e71d710: 0x706f1300
0x6e71d70c: 0x00753000
0x6e71d708: 0x740a5e08
0x6e71d704: 0xa5e04070
0x6e71d700: 0x6f140809
0x6e71d6fc: 0x144dbf00
0x6e71d6f8-0x6e71d61c: 0x00000000
Process virtual address map:
08048000-09f42000 r-xp 00000000 00:01 884        /asa/bin/lina
09f42000-09f44000 r-xp 01efa000 00:01 884        /asa/bin/lina
09f44000-0a4fe000 rwxp 01efc000 00:01 884        /asa/bin/lina
0a4fe000-0b035000 rwxp 0a4fe000 00:00 0          [heap]
68a39000-68a3a000 rwxp 68a39000 00:00 0
68a3a000-68a3b000 rwxs fff00000 00:0e 1176       /dev/mem
68a3b000-68b3c000 rwxp 68a3b000 00:00 0
68b3c000-68b40000 rwxs 00000000 00:08 2297       /dev/zero (deleted)
68b40000-68f45000 rwxp 68b40000 00:00 0
68f45000-68f65000 rwxs f8100000 00:0e 1176       /dev/mem
68f65000-68f85000 rwxs f8200000 00:0e 1176       /dev/mem
68f85000-68fa5000 rwxs f8220000 00:0e 1176       /dev/mem
68fa5000-68fc5000 rwxs f8240000 00:0e 1176       /dev/mem
68fc5000-68fe5000 rwxs f8260000 00:0e 1176       /dev/mem
68fe5000-68fe6000 rwxs ffb00000 00:0e 1176       /dev/mem
68fe6000-68ff6000 rwxs fff00000 00:0e 1176       /dev/mem
68ff6000-68ffe000 rwxs 000d8000 00:0e 1176       /dev/mem
68ffe000-68fff000 rwxs f8340000 00:0e 1176       /dev/mem
68fff000-69000000 rwxs f8300000 00:0e 1176       /dev/mem
69000000-6e268000 rwxs 00000000 00:0e 1686       /dev/udma0
6e400000-71400000 rwxs 00000000 00:0b 0          /SYSV00000002 (deleted)
71400000-71800000 r-xs 03000000 00:0b 0          /SYSV00000002 (deleted)
71800000-71c00000 rwxs 03400000 00:0b 0          /SYSV00000002 (deleted)
71c00000-72000000 r-xs 03800000 00:0b 0          /SYSV00000002 (deleted)
72000000-72400000 r-xs 03c00000 00:0b 0          /SYSV00000002 (deleted)
72400000-72800000 r-xs 04000000 00:0b 0          /SYSV00000002 (deleted)
72800000-72c00000 r-xs 04400000 00:0b 0          /SYSV00000002 (deleted)
72c00000-73000000 r-xs 04800000 00:0b 0          /SYSV00000002 (deleted)
73000000-73400000 r-xs 04c00000 00:0b 0          /SYSV00000002 (deleted)
73400000-73800000 r-xs 05000000 00:0b 0          /SYSV00000002 (deleted)
73800000-73c00000 r-xs 05400000 00:0b 0          /SYSV00000002 (deleted)
73c00000-dcc00000 rwxs 05800000 00:0b 0          /SYSV00000002 (deleted)
dcf54000-dcf57000 rwxp dcf54000 00:00 0
dcf57000-dd090000 r-xp 00000000 00:01 241        /lib/libc-2.9.so
dd090000-dd091000 ---p 00139000 00:01 241        /lib/libc-2.9.so
dd091000-dd093000 r-xp 00139000 00:01 241        /lib/libc-2.9.so
dd093000-dd094000 rwxp 0013b000 00:01 241        /lib/libc-2.9.so
dd094000-dd098000 rwxp dd094000 00:00 0
dd098000-dd0a2000 r-xp 00000000 00:01 326        /lib/libgcc_s.so.1
dd0a2000-dd0a3000 r-xp 00009000 00:01 326        /lib/libgcc_s.so.1
dd0a3000-dd0a4000 rwxp 0000a000 00:01 326        /lib/libgcc_s.so.1
dd0a4000-dd0c8000 r-xp 00000000 00:01 307        /lib/libm-2.9.so
dd0c8000-dd0c9000 r-xp 00023000 00:01 307        /lib/libm-2.9.so
dd0c9000-dd0ca000 rwxp 00024000 00:01 307        /lib/libm-2.9.so
dd0ca000-dd0d3000 r-xp 00000000 00:01 178        /lib/libudev.so.0.5.0
dd0d3000-dd0d4000 r-xp 00008000 00:01 178        /lib/libudev.so.0.5.0
dd0d4000-dd0d5000 rwxp 00009000 00:01 178        /lib/libudev.so.0.5.0
dd0d5000-dd0e0000 r-xp 00000000 00:01 801        /usr/lib/libcgroup.so.1.0.34
dd0e0000-dd0e1000 r-xp 0000a000 00:01 801        /usr/lib/libcgroup.so.1.0.34
dd0e1000-dd0e2000 rwxp 0000b000 00:01 801        /usr/lib/libcgroup.so.1.0.34
dd0e2000-dd6db000 rwxp dd0e2000 00:00 0
dd6db000-dd6e2000 r-xp 00000000 00:01 240        /lib/librt-2.9.so
dd6e2000-dd6e3000 r-xp 00006000 00:01 240        /lib/librt-2.9.so
dd6e3000-dd6e4000 rwxp 00007000 00:01 240        /lib/librt-2.9.so
dd6e4000-dd6e6000 r-xp 00000000 00:01 242        /lib/libdl-2.9.so
dd6e6000-dd6e7000 r-xp 00001000 00:01 242        /lib/libdl-2.9.so
dd6e7000-dd6e8000 rwxp 00002000 00:01 242        /lib/libdl-2.9.so
dd6e8000-dd6e9000 rwxp dd6e8000 00:00 0
dd6e9000-dd6fd000 r-xp 00000000 00:01 320        /lib/libpthread-2.9.so
dd6fd000-dd6fe000 r-xp 00013000 00:01 320        /lib/libpthread-2.9.so
dd6fe000-dd6ff000 rwxp 00014000 00:01 320        /lib/libpthread-2.9.so
dd6ff000-dd701000 rwxp dd6ff000 00:00 0
dd701000-dd71c000 r-xp 00000000 00:01 778        /usr/lib/libexpat.so.1.5.2
dd71c000-dd71e000 r-xp 0001a000 00:01 778        /usr/lib/libexpat.so.1.5.2
dd71e000-dd71f000 rwxp 0001c000 00:01 778        /usr/lib/libexpat.so.1.5.2
dd71f000-dd7cd000 r-xp 00000000 00:01 325        /lib/libstdc++.so.6.0.10
dd7cd000-dd7d1000 r-xp 000ad000 00:01 325        /lib/libstdc++.so.6.0.10
dd7d1000-dd7d2000 rwxp 000b1000 00:01 325        /lib/libstdc++.so.6.0.10
dd7d2000-dd7d8000 rwxp dd7d2000 00:00 0
dd7d8000-dd7dd000 r-xp 00000000 00:01 807        /usr/lib/libnuma.so.1
dd7dd000-dd7de000 r-xp 00004000 00:01 807        /usr/lib/libnuma.so.1
dd7de000-dd7df000 rwxp 00005000 00:01 807        /usr/lib/libnuma.so.1
dd7e0000-dd7e2000 rwxp dd7e0000 00:00 0
dd7e2000-dd7fe000 r-xp 00000000 00:01 259        /lib/ld-2.9.so
dd7fe000-dd7ff000 r-xp 0001b000 00:01 259        /lib/ld-2.9.so
dd7ff000-dd800000 rwxp 0001c000 00:01 259        /lib/ld-2.9.so
ddfeb000-de000000 rwxp ddfeb000 00:00 0          [stack]
ffffe000-fffff000 r-xp 00000000 00:00 0          [vdso]
Globl mempool: least_addr=0x6e400000 top=0x75b79068 dv=0x75632050 mflags=0x7
DMA   mempool: least_addr=0x69000000 top=0x6c495cb8 dv=0x6aee2738 mflags=0x7
Current Block:
Block     : 0x6e4f2720
B-base    : 0x6e4f2a04
B-size    : 152
B-rptr    : 0x6e4f2a98
B-hptr    : 0x6e4f2a98
B-allocd  : 0x0827e7ff
B-freed   : 0x08a7f752
B-location: 0x00000088
B-meta    : 0x0
B-flags2  : 0x0
B-input   :
B-output  :
Region #0 [0x6e4f27c0] ext-dump 0 of (Block) from Current Block extra dump
0x6e4f27a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f27b0: c8 00 30 01 50 28 4f 6e 00 00 00 00 00 00 00 00  |  ..0.P(On........
0x6e4f27c0: 00 00 00 00 00 00 00 00 00 00 00 00 ff ff ff ff  |  ................
0x6e4f27d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f27e0: 88 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f27f0: 01 f4 01 f4 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f2800: 00 00 00 00 00 00 00 00 00 00 00 00 98 2a 4f 6e  |  .............*On
0x6e4f2810: 00 00 00 00 08 da 66 75 00 00 00 00 4d 2f 0d 00  |  ......fu....M/..
0x6e4f2820: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f2830: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #1 [0x6e4f2a98] ext-dump 1 of (Block) from Current Block extra dump
0x6e4f2a78: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f2a88: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f2a98: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f2aa8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f2ab8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f2ac8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f2ad8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f2ae8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f2af8: 00 00 00 00 58 3b 50 6e 00 00 00 00 00 00 00 00  |  ....X;Pn........
0x6e4f2b08: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #2 [0x6e4f2b38] ext-dump 2 of (Block) from Current Block extra dump
0x6e4f2b18: 58 3b 50 6e 00 00 00 00 20 ab 4e 6e cc cc bb bb  |  X;Pn.... .Nn....
0x6e4f2b28: 67 ff 01 00 04 2e 4f 6e 9c 2e 4f 6e e0 37 56 08  |  g.....On..On.7V.
0x6e4f2b38: 52 f7 a7 08 d4 74 00 00 00 00 00 00 00 00 00 00  |  R....t..........
0x6e4f2b48: 00 00 00 00 00 00 00 00 90 38 05 08 c0 7c d3 0a  |  .........8...|..
0x6e4f2b58: 00 00 00 00 00 00 00 00 00 00 00 00 ff ff ff ff  |  ................
0x6e4f2b68: ff ff ff ff 00 00 00 00 00 00 00 00 00 c0 00 00  |  ................
0x6e4f2b78: 98 2e 4f 6e 00 00 00 00 98 2e 4f 6e 98 2e 4f 6e  |  ..On......On..On
0x6e4f2b88: 98 2e 4f 6e d0 a5 87 69 c0 a5 87 69 00 00 00 00  |  ..On...i...i....
0x6e4f2b98: 00 ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e4f2ba8: 00 00 00 00 00 00 00 00 c8 00 30 01 50 2c 4f 6e  |  ..........0.P,On
Current Connection:
Conn      : 0x6fd2c940
C-flow    : 0x6fd2ca1c 0x6fd2cb3c
C-flowcnt : 1
C-flags   : 0x0
C-par_conn: 0x00000000
C-chd_conn: 0x00000000
C-sib_conn: 0x00000000
C-inspect : 0x00000000
C-inspect2: 0x00000000
C-ids     : 0x00000000
C-cxsc    : 0x00000000
C-conn_lck_own: 0x0
C-conn_lck_cnt: 0x0
C-work_que: 0xffffffff
C-pur_call: 0x00000000
C-pur_calb: 0x08992e30
C-tim_call: 0x08a77700
C-tim_calq: 0x6fa90368
Flow      : C-FLOW_SRC 0x6fd2ca1c
F-SrcIP  : 0xbae2624b (75.XXX.XXX.186)
F-DstIP  : 0xe88d0a6b (107.10.141.232)
F-SrcPort: 0xe1a5 (42465)
F-DstPort: 0x36c7 (50998)
F-ESrcIP : 0xbae2624b (75.XXX.XXX.186)
F-EDstIP : 0xe88d0a6b (107.10.141.232)
F-ESrcPrt: 0xe1a5 (42465)
F-EDstPrt: 0x36c7 (50998)
F-flags  : 0x8100000
F-flags2 : 0x0
F-flags3 : 0x18000
F-bytes  : 59424364
F-disp-refcnt   : 5
F-host    : 0x6fa6b000
H-addr    : 0xbae2624b
H-refcnt  : 8
H-tcpmss  : 0
Flow      : C-FLOW_DEST 0x6fd2cb3c
F-SrcIP  : 0xe88d0a6b (107.10.141.232)
F-DstIP  : 0xbae2624b (75.XXX.XXX.186)
F-SrcPort: 0x36c7 (50998)
F-DstPort: 0xe1a5 (42465)
F-ESrcIP : 0xe88d0a6b (107.10.141.232)
F-EDstIP : 0xbae2624b (75.XXX.XXX.186)
F-ESrcPrt: 0x36c7 (50998)
F-EDstPrt: 0xe1a5 (42465)
F-flags  : 0x40000000
F-flags2 : 0x0
F-flags3 : 0x0
F-bytes  : 0
F-host    : 0x6fa6af00
H-addr    : 0xe88d0a6b
H-refcnt  : 5
H-tcpmss  : 0
Region #3 [0x6fd2ca1c] ext-dump 0 of (Conn) from Current Conn extra dump
0x6fd2c9fc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2ca0c: 00 d6 11 7e 03 00 00 00 00 00 00 00 ff ff ff ff  |  ...~............
0x6fd2ca1c: 01 00 00 00 55 5e b3 cf 02 00 00 00 40 c9 d2 6f  |  ....U^......@..o
0x6fd2ca2c: 40 4d a6 6f 80 3e 09 74 50 9b 97 74 01 00 00 00  |  @M.o.>.tP..t....
0x6fd2ca3c: 45 01 00 00 70 13 63 75 e2 04 00 00 00 00 00 00  |  E...p.cu........
0x6fd2ca4c: 00 00 00 00 00 00 00 00 ff ff 00 00 00 00 10 08  |  ................
0x6fd2ca5c: 00 00 00 00 00 80 01 00 00 01 00 00 6c be 8a 03  |  ............l...
0x6fd2ca6c: 3c cb d2 6f 00 b0 a6 6f 98 cb d2 6f a5 e1 c7 36  |  <..o...o...o...6
0x6fd2ca7c: 32 00 00 00 00 00 00 00 4b 62 e2 ba 00 00 00 00  |  2.......Kb......
0x6fd2ca8c: 00 00 00 00 00 00 00 00 00 00 00 00 6b 0a 8d e8  |  ............k...
Region #4 [0x6fd2cabc] ext-dump 1 of (Conn) from Current Conn extra dump
0x6fd2ca9c: 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00  |  ................
0x6fd2caac: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cabc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cacc: 6c be 8a 03 00 00 00 00 00 00 00 00 00 00 00 00  |  l...............
0x6fd2cadc: 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2caec: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cafc: 00 00 00 00 ff ff 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cb0c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cb1c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cb2c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #5 [0x6fa64d40] ext-dump 2 of (Conn) from Current Conn extra dump
0x6fa64d20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa64d30: 00 00 00 00 00 00 00 00 00 00 00 00 88 27 86 6e  |  .............'.n
0x6fa64d40: 01 00 00 00 84 c6 46 ef 05 00 00 00 04 00 00 00  |  ......F.........
0x6fa64d50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa64d60: 00 00 00 00 00 00 00 00 00 00 00 00 00 fc 6d 6e  |  ..............mn
0x6fa64d70: 00 00 00 00 20 fc 6d 6e 00 00 00 00 e0 fb 6d 6e  |  .... .mn......mn
0x6fa64d80: 00 00 00 00 20 ef 6d 6e 00 00 00 00 00 00 00 00  |  .... .mn........
0x6fa64d90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa64da0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa64db0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #6 [0x6fd2cb3c] ext-dump 3 of (Conn) from Current Conn extra dump
0x6fd2cb3c: 00 00 00 00 00 00 00 00 00 00 00 00 40 c9 d2 6f  |  ............@..o
0x6fd2cb4c: 00 00 00 00 50 9b 97 74 80 3e 09 74 e4 00 00 00  |  ....P..t.>.t....
0x6fd2cb5c: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cb6c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40  |  ...............@
0x6fd2cb7c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cb8c: 1c ca d2 6f 00 af a6 6f 78 ca d2 6f c7 36 a5 e1  |  ...o...ox..o.6..
0x6fd2cb9c: 32 00 00 00 00 00 00 00 6b 0a 8d e8 00 00 00 00  |  2.......k.......
0x6fd2cbac: 00 00 00 00 00 00 00 00 00 00 00 00 4b 62 e2 ba  |  ............Kb..
Region #7 [0x6fd2cbdc] ext-dump 4 of (Conn) from Current Conn extra dump
0x6fd2cbbc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cbcc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cbdc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cbec: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cbfc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cc0c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cc1c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cc2c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cc3c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2cc4c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #8 [0x6fd2c948] ext-dump 5 of (Conn) from Current Conn extra dump
0x6fd2c928: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2c938: 00 00 00 00 00 52 72 6e c1 10 a1 c0 9e 8a 5f 82  |  .....Rrn......_.
0x6fd2c948: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00  |  ................
0x6fd2c958: 48 c9 d2 6f ff ff ff ff 00 00 00 00 00 00 00 00  |  H..o............
0x6fd2c968: 30 2e 99 08 00 00 00 00 00 00 00 00 ff ff ff ff  |  0...............
0x6fd2c978: 48 c9 d2 6f 00 62 02 03 ca 41 00 00 00 00 00 00  |  H..o.b...A......
0x6fd2c988: 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00  |  ................
0x6fd2c998: 00 00 00 00 00 00 00 00 00 00 00 00 00 77 a7 08  |  .............w..
0x6fd2c9a8: 00 00 00 00 02 00 00 00 68 03 a9 6f d8 08 a9 6f  |  ........h..o...o
0x6fd2c9b8: d8 08 a9 6f d0 08 a9 6f 5a c9 d2 6f c3 ee 14 01  |  ...o...oZ..o....
TSD dump (core0 tp=0x0abdda80):
core0: dp_executing_cp=1 tid=0x6e5d2d8c latest purge=0x0 calq=0x706f1418
       async_cnt=0 purgatory=0x00000000 async_lock=0x00000000 dor_spinlock=0x00000000
Dumping latest_calq_entry 0x706f1418
0x706f13d8: 00 00 00 00 14 67 06 06 08 5e 0a 74 01 00 00 00  |  .....g...^.t....
0x706f13e8: 97 ac d7 ee 01 00 00 00 b9 9b 48 4a 00 e0 e2 08  |  ..........HJ....
0x706f13f8: 40 00 00 00 00 28 e2 08 40 00 00 00 30 75 00 00  |  @....(..@...0u..
0x706f1408: 00 00 00 00 00 00 00 00 02 00 00 00 68 03 a9 6f  |  ............h..o
0x706f1418: 18 14 6f 70 18 14 6f 70 00 00 00 00 04 13 6f 70  |  ..op..op......op
0x706f1428: 35 bc 14 01 d4 9f a6 6f d4 9f a6 6f 00 9f a6 6f  |  5......o...o...o
0x706f1438: 00 00 00 00 c0 33 6f 70 80 fc 6e 70 00 00 00 00  |  .....3op..np....
0x706f1448: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Selective memory dump: DT(Data, default) TX(Text) UD(Uninit-Data)
                       BA(Bad) ID(Init-Data) UK(Unknown)
Region #0 [0x6e71d6fd] from tback F0
0x6e71d6dc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e71d6ec: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e71d6fc: 00 bf 4d 14 09 08 14 6f 70 40 e0 a5 08 5e 0a 74  |  ..M....op@...^.t
0x6e71d70c: 00 30 75 00 00 13 6f 70 08 14 6f 70 a8 d7 71 6e  |  .0u...op..op..qn
0x6e71d71c: af e1 a5 08 08 14 6f 70 40 e0 a5 08 00 1e 01 40  |  ......op@......@
0x6e71d72c: d1 41 00 00 bd 0f 00 04 20 4b 89 69 00 00 00 00  |  .A...... K.i....
0x6e71d73c: e9 00 00 00 40 0d 73 6e 00 00 00 00 68 d7 71 6e  |  ....@.sn....h.qn
0x6e71d74c: 8a 2f 56 08 00 00 00 00 d8 17 0f 69 68 d7 71 6e  |  ./V........ih.qn
0x6e71d75c: e8 00 4b 74 54 21 04 e5 20 00 00 00 00 e0 e2 08  |  ..KtT!.. .......
0x6e71d76c: 40 00 00 00 20 f5 6d 6e 30 75 00 00 00 a8 42 08  |  @... .mn0u....B.
Region #1 [0x6e6fd960] from #0 (malloc_header) magic off 0
0x6e6fd940: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e6fd950: 00 00 00 00 ef cd 1c a1 d0 d4 40 47 33 00 02 00  |  ..........@G3...
0x6e6fd960: 23 01 1c a1 00 00 02 00 00 00 00 00 00 00 00 00  |  #...............
0x6e6fd970: 98 7f 6b 6e 08 e4 f5 6e 81 97 06 08 00 00 00 00  |  .&#127;kn...n........
0x6e6fd980: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e6fd990: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e6fd9a0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e6fd9b0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e6fd9c0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e6fd9d0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
malloc_header:0x6e6fd960
M-size    : 0x20000
M-allocd  : 0x08069781
Region #2 [TX:0x09144dbc] from #0 tback F0 dump off 0x00000000
0x09144d9c: f8 14 89 44 24 10 8b 45 10 89 54 24 0c 89 44 24  |  ...D$..E..T$..D$
0x09144dac: 00 8b 45 0c 89 44 24 04 8b 45 08 89 04 24 e8 a1  |  ..E..D$..E...$..
0x09144dbc: bb ff ff c9 c3 eb 0d 90 90 90 90 90 90 90 90 90  |  ................
0x09144dcc: 90 90 90 90 55 89 e5 57 56 31 f6 53 83 ec 0c 8b  |  ....U..WV1.S....
0x09144ddc: 7d 08 66 90 8b 54 37 10 85 d2 74 2f 8b 5a 1c 8b  |  }.f..T7...t/.Z..
0x09144dec: 4a 18 89 d8 09 c8 74 13 31 c0 85 db 75 2e 8d b6  |  J.....t.1...u...
0x09144dfc: 00 00 00 00 83 c0 01 39 c1 77 f9 89 14 24 e8 01  |  .......9.w...$..
0x09144e0c: 59 71 00 c7 44 37 10 00 00 00 00 83 c6 14 83 fe  |  Yq..D7..........
0x09144e1c: 50 75 c1 83 c4 0c 5b 5e 5f 5d c3 90 eb fe 8d b6  |  Pu....[^_]......
0x09144e2c: 00 00 00 00 55 89 e5 57 56 31 f6 53 83 ec 0c a1  |  ....U..WV1.S....
Region #3 [0x706f1408] from #0 tback F0 dump off 0x00000004
0x706f1458: 00 00 00 00 00 00 00 00 00 00 00 00 ff ff ff ff  |  ................
0x706f1468: c0 79 bb 0a 40 14 6f 70 01 41 80 00 ff ff ff ff  |  .y..@.op.A......
0x706f1478: c0 d5 c0 d5 00 00 00 00 ff ff ff ff 34 c7 71 6e  |  ............4.qn
Region #4 [0x706eb5e0] from #3 (malloc_header) magic off 0
0x706eb5c0: c0 30 6e 70 c0 31 6e 70 c0 32 6e 70 c0 33 6e 70  |  .0np.1np.2np.3np
0x706eb5d0: 00 00 00 ef cd 1c a1 00 d0 d4 40 47 bb 7d 00 00  |  ..........@G.}..
0x706eb5e0: 23 01 1c a1 87 7d 00 00 00 00 00 00 00 00 00 00  |  #....}..........
0x706eb5f0: 90 52 a6 6f 20 3e 8f 70 c2 88 80 09 00 00 00 00  |  .R.o >.p........
0x706eb600: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706eb610: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706eb620: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706eb630: 00 00 00 00 00 00 00 00 45 36 27 18 00 b6 6e 70  |  ........E6'...np
0x706eb640: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706eb650: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
malloc_header:0x706eb5e0
M-size    : 0x7d87
M-allocd  : 0x098088c2
Region #5 [0x706f1300] from #3 (Corrupt Xlate) magic off 0
0x706f12e0: 00 00 00 00 c4 11 6f 70 81 af 14 01 00 00 00 00  |  ......op........
0x706f12f0: 00 00 00 00 80 2a b0 75 00 00 00 00 c0 33 6f 70  |  .....*.u.....3op
0x706f1300: ef be ad de 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706f1310: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706f1320: 00 00 00 00 ff ff ff ff c0 79 bb 0a 00 13 6f 70  |  .........y....op
0x706f1330: 00 41 00 00 01 00 00 00 cb dc cb dc 00 00 00 00  |  .A..............
0x706f1340: ff ff ff ff 34 c7 71 6e 97 ac d7 ee c0 ae 4d 70  |  ....4.qn......Mp
0x706f1350: 48 1b 6a 74 00 00 00 00 0a 07 04 0a 00 00 00 00  |  H.jt............
0x706f1360: 00 00 00 00 00 00 00 00 50 9b 97 74 00 00 00 00  |  ........P..t....
0x706f1370: 4b 62 e2 ba 00 00 00 00 d4 34 4f 74 a6 65 85 09  |  Kb.......4Ot.e..
Dumping contents of valid xlate pointer:
0x706f1380: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706f1390: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706f13a0: 00 00 00 00 11 95 24 cc 00 00 00 00 00 00 00 00  |  ......$.........
0x706f13b0: 00 00 00 00 0c 08 a1 74 48 55 a4 74 3c ee 6e 70  |  .......tHU.t<.np
0x706f13c0: bc 18 6f 70 80 45 a4 74 00 00 00 00 11 95 24 cc  |  ..op.E.t......$.
0x706f13d0: 00 00 00 00 00 00 00 00 00 00 00 00 14 67 06 06  |  .............g..
0x706f13e0: 08 5e 0a 74 01 00 00 00 97 ac d7 ee 01 00 00 00  |  .^.t............
0x706f13f0: b9 9b 48 4a 00 e0 e2 08 40 00 00 00 00 28 e2 08  |  ..HJ....@....(..
0x706f1400: 40 00 00 00 30 75 00 00 00 00 00 00 00 00 00 00  |  @...0u..........
0x706f1410: 02 00 00 00 68 03 a9 6f 18 14 6f 70 18 14 6f 70  |  ....h..o..op..op
0x706f1420: 00 00 00 00 04 13 6f 70 35 bc 14 01 d4 9f a6 6f  |  ......op5......o
0x706f1430: d4 9f a6 6f 00 9f a6 6f 00 00 00 00 c0           |  ...o...o.....
Xlate-Refcnt        : 1
Xlate-Flags         : 4100
Xlate-DiagFlags     : 0
Xlate-NatPolicy              : 0x74a44580
0x74a44580: 01 00 00 00 02 00 00 00 01 00 00 00 48 1b 6a 74  |  ............H.jt
0x74a44590: 50 9b 97 74 00 00 00 00 60 59 9e 74 00 00 00 00  |  P..t....`Y.t....
0x74a445a0: 80 45 a4 74 08 5a 9e 74 18 62 a4 74 01 00 00 00  |  .E.t.Z.t.b.t....
0x74a445b0: 01 00 00 00 01 00 00 00 00 00 00 00 00 00 04 01  |  ................
0x74a445c0: 06 00 00 00 58 50 00 00 2a 34 00 00 38 46 a4 74  |  ....XP..*4..8F.t
0x74a445d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a445e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a445f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a44600: 00 00 00 00 ff ff ff ff ef                       |  .........
Xlate-NatPool              : 0x74a1080c
0x74a1080c: 00 00 00 00 00 00 00 00 b8 0a a1 74 05 00 00 00  |  ...........t....
0x74a1081c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a1082c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a1083c: 00 00 00 00 70 07 a1 74 00 00 00 00 00 70 c9 b2  |  ....p..t.....p..
0x74a1084c: 8b 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a1085c: 00 00 00 00 00 00 00 00 00 00 00 00 22 02 00 00  |  ............"...
0x74a1086c: 00 00 00 00 00 00 00 00 00 00 00 00 18 01 00 00  |  ................
0x74a1087c: 7c 08 a1 74 7c 08 a1 74 00 00 00 00 00 00 00 00  |  |..t|..t........
0x74a1088c: 00 00 00 00 00 00 00 00 00 00 00 00 ef cd 1c a1  |  ................
0x74a1089c: c0 80 01 03 d0 d4 40 47 fb 00 00 00 23 01 1c a1  |  ......@G....#...
0x74a108ac: c8 00 00 00 00 00 00 00 00 00 00 00 40 d5 8a 6e  |  ............@..n
0x74a108bc: a0 09 a1 74 62 9f 23 08 06 0c 18 30 00 00 00 00  |  ...tb.#....0....
0x74a108cc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a108dc: 00 00 00 00 00 00 00 00 00 00 00 00 70 07 a1 74  |  ............p..t
0x74a108ec: 01 00 00 00 00 00 00 00 00 02 00 00 11 00 00 00  |  ................
0x74a108fc: 01 00 00 00 11 01 00 00 11 00 00 00 6e 09 a1 74  |  ............n..t
0x74a1090c: fc ff 00 00 00                                   |  .....
Xlate-HostSrc    : 0x6fa69f00
H-addr    : 0xa04070a
H-refcnt  : 4
H-tcpmss  : 1380
Region #6 [TX:0x08a5e040] from #0 tback F0 dump off 0x00000008
0x08a5e020: 00 00 00 c7 04 24 4f 01 00 00 05 ac 02 00 00 89  |  .....$O.........
0x08a5e030: 44 24 0c e8 58 ec 81 ff 31 d2 e9 7b ff ff ff 90  |  D$..X...1..{....
0x08a5e040: 55 89 e5 57 56 53 83 ec 7c 8b 7d 08 8d 4d e0 0f  |  U..WVS..|.}..M..
0x08a5e050: 31 89 01 89 51 04 8b 55 e4 8b 45 e0 8b 0d 20 27  |  1...Q..U..E... '
0x08a5e060: 03 0b c7 45 ec 01 00 00 00 0f ac d0 0a c1 ea 0a  |  ...E............
0x08a5e070: 89 55 bc 8b 75 bc 89 45 b8 f7 e1 0f af f1 89 45  |  .U..u..E.......E
0x08a5e080: d0 8b 45 d0 01 f2 89 55 d4 8b 55 d4 8d b7 f8 fe  |  ..E....U..U.....
0x08a5e090: ff ff 89 45 e0 89 f0 89 55 e4 8d 55 ec e8 4e 4e  |  ...E....U..U..NN
0x08a5e0a0: ff ff 83 e8 01 0f 84 95 00 00 00 8b 56 2c 8d 87  |  ............V,..
0x08a5e0b0: fc fe ff ff 29 f0 8b 7c 02 28 85 ff 0f 84 8e 00  |  ....)..|.(......
Region #9 [TX:0x08706f10] from #0 tback F0 dump off 0x00000014
0x08706ef0: a0 01 00 00 00 00 00 00 e9 7b ff ff ff 8d 76 00  |  .........{....v.
0x08706f00: 55 89 e5 53 83 ec 14 8b 5d 08 85 db 0f 84 9e 00  |  U..S....].......
0x08706f10: 00 00 8b 93 d8 00 00 00 85 d2 0f 84 90 00 00 00  |  ................
0x08706f20: a1 c4 51 d8 0a 89 14 24 89 44 24 04 e8 0f e2 05  |  ..Q....$.D$.....
0x08706f30: 00 8b 93 a0 01 00 00 b8 01 00 00 00 85 d2 74 69  |  ..............ti
0x08706f40: 8b 52 04 b8 2b 00 00 00 81 fa ac 00 00 00 74 59  |  .R..+.........tY
0x08706f50: 81 fa ad 00 00 00 b0 2c 74 4f c7 44 24 08 ae 00  |  .......,tO.D$...
0x08706f60: 00 00 c7 44 24 04 00 00 00 00 8b 83 d8 00 00 00  |  ...D$...........
0x08706f70: 89 04 24 e8 78 df 05 00 c7 44 24 10 a6 f8 ac 09  |  ..$.x....D$.....
0x08706f80: c7 44 24 0c be 0c 00 00 c7 44 24 08 58 47 ab 09  |  .D$......D$.XG..
Region #10 [0x6e71d718] from tback F1
0x6e71d6f8: 00 00 00 00 00 bf 4d 14 09 08 14 6f 70 40 e0 a5  |  ......M....op@..
0x6e71d708: 08 5e 0a 74 00 30 75 00 00 13 6f 70 08 14 6f 70  |  .^.t.0u...op..op
0x6e71d718: a8 d7 71 6e af e1 a5 08 08 14 6f 70 40 e0 a5 08  |  ..qn......op@...
0x6e71d728: 00 1e 01 40 d1 41 00 00 bd 0f 00 04 20 4b 89 69  |  ...@.A...... K.i
0x6e71d738: 00 00 00 00 e9 00 00 00 40 0d 73 6e 00 00 00 00  |  ........@.sn....
0x6e71d748: 68 d7 71 6e 8a 2f 56 08 00 00 00 00 d8 17 0f 69  |  h.qn./V........i
0x6e71d758: 68 d7 71 6e e8 00 4b 74 54 21 04 e5 20 00 00 00  |  h.qn..KtT!.. ...
0x6e71d768: 00 e0 e2 08 40 00 00 00 20 f5 6d 6e 30 75 00 00  |  ....@... .mn0u..
0x6e71d778: 00 a8 42 08 ca 41 00 00 e0 f8 6d 6e 00 41 00 00  |  ..B..A....mn.A..
0x6e71d788: 00 a8 42 08 ca 41 00 00 00 be 42 05 00 00 00 00  |  ..B..A....B.....
Region #11 [0x6e6fd960] from #10 (malloc_header) magic off 0
M-size    : 0x20000
Region #12 [0x6e71d7a8] from #10 tback F1 dump off 0x00000000
0x6e71d798: 22 4c 85 10 00 00 00 00 08 14 6f 70 40 e0 a5 08  |  "L........op@...
0x6e71d7a8: 18 d8 71 6e 57 48 14 09 08 14 6f 70 94 83 00 00  |  ..qnWH....op....
0x6e71d7b8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e71d7c8: 00 00 00 00 f8 d7 71 6e 7c 0e aa 6f f8 40 93 6e  |  ......qn|..o.@.n
0x6e71d7d8: 00 00 00 00 00 00 00 00 7c 0e aa 6f 00 00 00 00  |  ........|..o....
0x6e71d7e8: 14 00 00 00 68 03 a9 6f 00 66 42 07 ca 41 00 00  |  ....h..o.fB..A..
0x6e71d7f8: 00 a2 42 08 ca 41 00 00 fa 46 85 10 94 83 00 00  |  ..B..A...F......
0x6e71d808: 00 00 00 00 a8 74 a7 ba e5 00 00 00 40 00 4b 74  |  .....t......@.Kt
0x6e71d818: a8 d8 71 6e b9 ea 27 08 8c d8 71 6e 21 d0 00 00  |  ..qn..'...qn!...
Region #13 [0x6e6fd960] from #12 (malloc_header) magic off 0
M-size    : 0x20000
Region #14 [TX:0x08a5e1ac] from #10 tback F1 dump off 0x00000004
0x08a5e18c: 9a 3b 83 d6 00 8d 87 08 01 00 00 89 04 24 89 5c  |  .;...........$.\
0x08a5e19c: 24 08 89 74 24 0c c7 44 24 04 40 e0 a5 08 e8 21  |  $..t$..D$.@....!
0x08a5e1ac: 16 f6 ff 8b 45 ec 85 c0 75 9a 8b 87 b8 00 00 00  |  ....E...u.......
0x08a5e1bc: 89 04 24 e8 fc 67 fe ff 3c ff 89 c2 74 86 8b 45  |  ..$..g..<...t..E
0x08a5e1cc: cc 89 44 24 30 0f b6 87 df 00 00 00 89 44 24 2c  |  ..D$0........D$,
0x08a5e1dc: 0f b6 87 de 00 00 00 89 44 24 28 0f b7 87 dc 00  |  ........D$(.....
0x08a5e1ec: 00 00 89 44 24 24 8d 87 c8 00 00 00 89 44 24 20  |  ...D$$.......D$
0x08a5e1fc: 8d 87 a0 00 00 00 89 44 24 1c 0f b7 47 3a 89 44  |  .......D$...G:.D
0x08a5e20c: 24 18 8d 47 6c 89 44 24 14 8b 47 68 89 44 24 10  |  $..Gl.D$..Gh.D$.
0x08a5e21c: 0f b7 47 38 89 44 24 0c 8d 47 54 89 44 24 08 8b  |  ..G8.D$..GT.D$..
Region #15 [TX:0x08a5e0c4] from #14 (Corrupt Xlate) magic off 0
0x08a5e0a4: 01 0f 84 95 00 00 00 8b 56 2c 8d 87 fc fe ff ff  |  ........V,......
0x08a5e0b4: 29 f0 8b 7c 02 28 85 ff 0f 84 8e 00 00 00 81 3f  |  )..|.(.........?
0x08a5e0c4: ef be ad de 0f 84 8a 00 00 00 8b 47 2c 8b 40 2c  |  ...........G,.@,
0x08a5e0d4: 85 c0 74 07 83 88 80 00 00 00 01 60 e8 6b 3a 60  |  ..t........`.k:`
0x08a5e0e4: ff 61 c7 44 24 04 b0 4f b5 09 c7 04 24 b1 17 b4  |  .a.D$..O....$...
0x08a5e0f4: 09 e8 56 ed 60 ff 8d 87 3c 01 00 00 89 44 24 04  |  ..V.`...<....D$.
0x08a5e104: 89 3c 24 e8 a4 fd 60 ff c7 04 24 f4 4c b5 09 e8  |  .<$...`...$.L...
0x08a5e114: 38 ed 60 ff 89 3d 40 74 d3 0a c7 44 24 08 cd 00  |  8.`..=@t...D$...
0x08a5e124: 00 00 c7 44 24 04 c2 17 b4 09 c7 04 24 61 b3 b0  |  ...D$.......$a..
0x08a5e134: 09 e8 16 b3 e0 00 8d b6 00 00 00 00 c7 44 24 04  |  .............D$.
Xlate pointer out of bounds
Region #16 [0x706f1408] from #10 tback F1 dump off 0x00000008
Region #17 [0x706eb5e0] from #16 (malloc_header) magic off 0
M-size    : 0x7d87
Region #18 [0x706f1300] from #16 (Corrupt Xlate) magic off 0
Xlate-Refcnt        : 1
Xlate-Flags         : 4100
Xlate-DiagFlags     : 0
H-addr    : 0xa04070a
H-refcnt  : 4
H-tcpmss  : 1380
Region #19 [TX:0x08a5e040] from #10 tback F1 dump off 0x0000000c
Region #23 [UK:0x69894b20] from #10 tback F1 dump off 0x0000001c
0x69894b00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894b10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894b20: 00 00 00 00 cc cc bb bb a9 e4 04 00 04 4e 89 69  |  .............N.i
0x69894b30: 52 55 89 69 78 f5 27 08 78 f5 27 08 02 00 00 00  |  RU.ix.'.x.'.....
0x69894b40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894b50: b0 ab 84 09 40 b0 72 6e 00 00 00 00 00 00 00 00  |  ....@.rn........
0x69894b60: 00 00 00 00 ff ff ff ff ff ff ff ff 00 00 00 00  |  ................
0x69894b70: 00 00 00 00 00 00 00 00 20 4f 89 69 00 00 00 00  |  ........ O.i....
0x69894b80: 20 4f 89 69 20 4f 89 69 20 4f 89 69 00 00 00 00  |   O.i O.i O.i....
0x69894b90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Block     : 0x69894b20
B-base    : 0x69894e04
B-size    : 1870
B-rptr    : 0x69894f20
B-hptr    : 0x69894f20
B-allocd  : 0x0827f578
B-freed   : 0x0827f578
B-location: 0x00000087
B-meta    : 0x0
B-flags2  : 0x0
B-input   :
B-output  :
Region #24 [UK:0x69894bc0] ext-dump 0 of (Block) from #23
0x69894ba0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894bb0: c8 00 30 01 50 4c 89 69 00 00 00 00 00 00 00 00  |  ..0.PL.i........
0x69894bc0: 00 00 00 00 00 00 00 00 00 00 00 00 ff ff ff ff  |  ................
0x69894bd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894be0: 87 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894bf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894c00: 00 00 00 00 00 00 00 00 00 00 00 00 20 4f 89 69  |  ............ O.i
0x69894c10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894c20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894c30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #25 [UK:0x69894f20] ext-dump 1 of (Block) from #23
0x69894f00: f3 50 08 0a 00 1b 2a 34 d1 35 08 00 45 00 00 a0  |  .P....*4.5..E...
0x69894f10: 8b 15 40 00 40 32 88 07 4b 62 e2 ba 6b 0a 8d e8  |  ..@.@2..Kb..k...
0x69894f20: e1 a5 36 c7 00 0b b2 2f 89 aa 0c b9 0f 7c 11 14  |  ..6..../.....|..
0x69894f30: a2 bf ef dc 91 a3 c2 1b e7 0b 38 ff 0d 72 ef e8  |  ..........8..r..
0x69894f40: 41 b3 7f d0 69 24 63 60 db 18 c1 5f 6a 0b f3 9f  |  A.&#127;.i$c`..._j...
0x69894f50: 12 5b 24 97 81 37 81 f6 5d 9d 66 a4 b4 45 be 30  |  .[$..7..].f..E.0
0x69894f60: ee 0f 5d 72 ba 91 cc 7e ae 83 b2 de 89 a0 8f 8e  |  ..]r...~........
0x69894f70: 8d 9b 66 62 32 9a e3 cb e0 31 8d fe d6 27 d3 be  |  ..fb2....1...'..
0x69894f80: 34 48 dc 1e e5 4c 02 4e 91 e3 d4 b8 11 6d c2 d7  |  4H...L.N.....m..
0x69894f90: d3 5c ec f2 78 99 7d 02 c7 b5 57 e3 6f 3d 64 2c  |  .\..x.}...W.o=d,
Region #27 [0x6e730d40] from #10 tback F1 dump off 0x00000028
0x6e730d20: f2 d5 55 08 00 00 00 00 00 00 00 00 00 00 00 00  |  ..U.............
0x6e730d30: 00 00 00 00 00 00 00 00 45 36 27 18 28 0d 73 6e  |  ........E6'.(.sn
0x6e730d40: 00 50 f6 68 01 00 00 00 00 01 00 00 09 00 00 00  |  .P.h............
0x6e730d50: 02 04 00 00 00 d0 a0 69 58 16 73 6e 00 00 00 00  |  .......iX.sn....
0x6e730d60: 00 f0 a0 69 88 1a 73 6e 40 00 00 00 00 00 00 00  |  ...i..sn@.......
0x6e730d70: 40 0d 73 6e a0 a1 55 08 00 00 00 9a ff ff ff ff  |  @.sn..U.........
0x6e730d80: 98 00 00 00 60 0e 24 69 00 84 a0 69 97 00 00 00  |  ....`.$i...i....
0x6e730d90: e9 00 00 00 e9 00 00 00 ec 13 73 6e 40 b0 72 6e  |  ..........sn@.rn
0x6e730da0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e730db0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #28 [0x6e730d08] from #27 (malloc_header) magic off 0
0x6e730ce8: 4c 00 40 6e 88 57 72 6e 23 01 ee f3 60 f7 72 6e  |  L.@n.Wrn#...`.rn
0x6e730cf8: 00 00 00 00 ef cd ee f3 20 00 00 00 82 07 00 00  |  ........ .......
0x6e730d08: 23 01 1c a1 53 07 00 00 00 00 00 00 00 00 00 00  |  #...S...........
0x6e730d18: 28 f7 72 6e f8 22 73 6e f2 d5 55 08 00 00 00 00  |  (.rn."sn..U.....
0x6e730d28: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e730d38: 45 36 27 18 28 0d 73 6e 00 50 f6 68 01 00 00 00  |  E6'.(.sn.P.h....
0x6e730d48: 00 01 00 00 09 00 00 00 02 04 00 00 00 d0 a0 69  |  ...............i
0x6e730d58: 58 16 73 6e 00 00 00 00 00 f0 a0 69 88 1a 73 6e  |  X.sn.......i..sn
0x6e730d68: 40 00 00 00 00 00 00 00 40 0d 73 6e a0 a1 55 08  |  @.......@.sn..U.
0x6e730d78: 00 00 00 9a ff ff ff ff 98 00 00 00 60 0e 24 69  |  ............`.$i
malloc_header:0x6e730d08
M-size    : 0x753
M-allocd  : 0x0855d5f2
Region #29 [0x6e71d768] from #10 tback F1 dump off 0x00000030
Region #30 [0x6e6fd960] from #29 (malloc_header) magic off 0
M-size    : 0x20000
Region #31 [TX:0x08562f88] from #10 tback F1 dump off 0x00000034
0x08562f68: 0a 85 c9 0f 84 a7 00 00 00 ba 01 00 00 00 89 f0  |  ................
0x08562f78: e8 e3 c5 ff ff 83 7e 0c 02 76 1d 89 f0 e8 46 82  |  ......~..v....F.
0x08562f88: ff ff 85 c0 74 a2 8b 46 4c 8b 16 89 82 18 28 00  |  ....t..FL.....(.
0x08562f98: 00 31 c0 eb 95 8d 76 00 89 f0 e8 29 82 ff ff 85  |  .1....v....)....
0x08562fa8: c0 74 85 8b 46 4c 8b 96 f4 05 00 00 89 82 28 01  |  .t..FL........(.
0x08562fb8: 00 00 31 c0 e9 71 ff ff ff 8d b4 26 00 00 00 00  |  ..1..q.....&....
0x08562fc8: 89 fa e8 41 91 ff ff 89 47 10 31 c0 e9 59 ff ff  |  ...A....G.1..Y..
0x08562fd8: ff 8d b4 26 00 00 00 00 8b 5e 50 8b 56 54 89 d8  |  ...&.....^P.VT..
0x08562fe8: 29 d0 89 c1 03 4e 08 39 d3 0f 4c c1 89 07 31 c0  |  )....N.9..L...1.
0x08562ff8: e9 35 ff ff ff 8d 76 00 8b 46 58 8b 10 89 17 0f  |  .5....v..FX.....
Region #32 [UK:0x690f17d8] from #10 tback F1 dump off 0x0000003c
0x690f17b8: 23 01 1c a1 2c 01 00 00 00 00 00 00 00 00 00 00  |  #...,...........
0x690f17c8: 00 00 00 00 e0 92 19 69 24 f2 56 08 00 00 00 00  |  .......i$.V.....
0x690f17d8: 00 93 19 69 00 1b 2a 34 d1 31 00 1b 2a 34 d1 31  |  ...i..*4.1..*4.1
0x690f17e8: 98 8d 19 69 88 90 19 69 40 8e 19 69 ad fb ca de  |  ...i...i@..i....
0x690f17f8: 00 00 00 00 04 00 00 00 00 00 00 00 04 00 00 00  |  ................
0x690f1808: ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x690f1818: 00 00 00 00 ad fb ca de 00 00 00 00 04 00 00 00  |  ................
0x690f1828: 00 00 00 00 05 00 00 00 ff ff 00 00 00 00 00 00  |  ................
0x690f1838: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x690f1848: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #33 [0x6e71d768] from #10 tback F1 dump off 0x00000040
Region #34 [0x6e71d7a8] from tback F2
Region #35 [0x6e6fd960] from #34 (malloc_header) magic off 0
M-size    : 0x20000
Region #36 [0x6e71d818] from #34 tback F2 dump off 0x00000000
0x6e71d828: 00 00 00 00 78 56 34 12 78 56 34 12 80 d8 71 6e  |  ....xV4.xV4...qn
0x6e71d838: 32 00 00 00 04 00 00 00 19 00 00 00 00 00 00 00  |  2...............
0x6e71d848: f0 2d 5d 6e 31 0c 50 b5 18 7a 41 19 c5 00 00 00  |  .-]n1.P..zA.....
0x6e71d858: 78 56 34 12 4e 00 00 00 00 00 00 00 42 c0 95 69  |  xV4.N.......B..i
0x6e71d868: 40 b0 72 6e 00 00 00 00 90 f7 72 6e 0e 06 00 00  |  @.rn......rn....
0x6e71d878: ff ff ff ff 78 56 34 12 16 56 32 0e 94 83 00 00  |  ....xV4..V2.....
0x6e71d888: 78 56 34 12 07 00 00 00 07 00 00 00 00 00 00 00  |  xV4.............
Region #37 [0x6e6fd960] from #36 (malloc_header) magic off 0
M-size    : 0x20000
Region #38 [TX:0x09144854] from #34 tback F2 dump off 0x00000004
0x09144834: 0f 84 2d 01 00 00 e8 f1 97 70 00 8b 46 04 89 04  |  ..-......p..F...
0x09144844: 24 e8 06 3a b9 ff c7 06 00 00 00 00 89 34 24 89  |  $..:.........4$.
0x09144854: c3 ff d7 89 1c 24 e8 f1 39 b9 ff 8b 55 d4 83 45  |  .....$..9...U..E
0x09144864: c0 01 8b 4d c0 3b 4a 30 0f 83 d6 fe ff ff 8b 75  |  ...M.;J0.......u
0x09144874: b8 8b 16 39 55 c8 0f 84 a0 00 00 00 8b 4d b8 8b  |  ...9U........M..
0x09144884: 02 89 01 8b 75 c8 8b 02 89 12 89 70 04 b8 c8 ef  |  ....u......p....
0x09144894: ff ff 89 d6 89 52 04 8b 7d d4 83 6f 2c 01 c7 42  |  .....R..}..o,..B
0x091448a4: 08 00 00 00 00 65 89 50 24 2b 77 34 8b 46 1c 85  |  .....e.P$+w4.F..
0x091448b4: c0 0f 84 75 ff ff ff 90 8d 74 26 00 8b 46 1c a8  |  ...u.....t&..F..
0x091448c4: 02 74 39 83 e0 fc 74 44 8b 10 85 d2 74 3e 8b 46  |  .t9...tD....t>.F
Region #39 [0x706f1408] from #34 tback F2 dump off 0x00000008
Region #40 [0x706eb5e0] from #39 (malloc_header) magic off 0
M-size    : 0x7d87
Region #41 [0x706f1300] from #39 (Corrupt Xlate) magic off 0
Xlate-Refcnt        : 1
Xlate-Flags         : 4100
Xlate-DiagFlags     : 0
H-addr    : 0xa04070a
H-refcnt  : 4
H-tcpmss  : 1380
Region #43 [0x6faa0e7c] from #34 tback F2 dump off 0x00000028
0x6faa0e5c: 4c 0e aa 6f 00 00 00 00 00 00 00 00 68 0e aa 6f  |  L..o........h..o
0x6faa0e6c: 68 0e aa 6f 60 0e aa 6f 00 00 00 00 00 00 00 00  |  h..o`..o........
0x6faa0e7c: 7c 0e aa 6f 7c 0e aa 6f 74 0e aa 6f 00 00 00 00  |  |..o|..ot..o....
0x6faa0e8c: 00 00 00 00 90 0e aa 6f 90 0e aa 6f 88 0e aa 6f  |  .......o...o...o
0x6faa0e9c: 00 00 00 00 00 00 00 00 10 20 a4 75 10 20 a4 75  |  ......... .u. .u
0x6faa0eac: 9c 0e aa 6f 00 00 00 00 00 00 00 00 b8 0e aa 6f  |  ...o...........o
0x6faa0ebc: b8 0e aa 6f b0 0e aa 6f 00 00 00 00 00 00 00 00  |  ...o...o........
0x6faa0ecc: cc 0e aa 6f cc 0e aa 6f c4 0e aa 6f 00 00 00 00  |  ...o...o...o....
0x6faa0edc: 00 00 00 00 e0 0e aa 6f e0 0e aa 6f d8 0e aa 6f  |  .......o...o...o
0x6faa0eec: 00 00 00 00 00 00 00 00 f4 0e aa 6f f4 0e aa 6f  |  ...........o...o
Region #44 [0x6fa90348] from #43 (malloc_header) magic off 0
0x6fa90328: 00 00 00 00 2c 03 a9 6f 2c 03 a9 6f 24 03 a9 6f  |  ....,..o,..o$..o
0x6fa90338: ef cd 1c a1 00 00 00 00 d0 d4 40 47 73 40 01 00  |  ..........@Gs@..
0x6fa90348: 23 01 1c a1 40 40 01 00 00 00 00 00 00 00 00 00  |  #...@@..........
0x6fa90358: d8 c2 a7 6f 08 f3 d1 6f b0 4f 14 09 00 00 00 00  |  ...o...o.O......
0x6fa90368: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00  |  ................
0x6fa90378: 18 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00  |  ................
0x6fa90388: 57 0d 00 00 00 00 00 00 00 00 00 00 d7 00 00 00  |  W...............
0x6fa90398: 64 00 00 00 10 00 00 00 00 66 42 07 ca 41 00 00  |  d........fB..A..
0x6fa903a8: 00 00 00 00 00 00 00 00 b0 03 a9 6f b0 03 a9 6f  |  ...........o...o
0x6fa903b8: a8 03 a9 6f 00 00 00 00 00 00 00 00 c4 03 a9 6f  |  ...o...........o
malloc_header:0x6fa90348
M-size    : 0x14040
M-allocd  : 0x09144fb0
Region #45 [0x6e9340f8] from #34 tback F2 dump off 0x0000002c
0x6e9340d8: 23 01 1c a1 50 00 00 00 00 00 00 00 00 00 00 00  |  #...P...........
0x6e9340e8: a0 3f 93 6e 38 f8 2f 71 35 52 14 09 78 56 34 12  |  .?.n8./q5R..xV4.
0x6e9340f8: 00 40 00 00 00 00 00 00 00 00 00 02 00 00 00 00  |  .@..............
0x6e934108: f8 c2 a7 6f 00 00 00 01 00 00 00 00 00 00 00 00  |  ...o............
0x6e934118: 08 00 00 00 68 03 a9 6f 00 00 00 40 00 00 00 00  |  ....h..o...@....
0x6e934128: 00 00 00 00 00 04 00 00 d8 43 aa 6f 00 00 00 00  |  .........C.o....
0x6e934138: 10 00 00 00 00 00 00 00 00 00 01 00 48 c4 ac 6f  |  ............H..o
0x6e934148: ef cd 1c a1 78 56 34 12 d0 d4 40 47 9b 00 00 00  |  ....xV4...@G....
0x6e934158: 23 01 1c a1 6c 00 00 00 00 00 00 00 00 00 00 00  |  #...l...........
0x6e934168: f0 72 75 6e e0 ae 3d 70 0b 08 24 08 78 56 34 12  |  .run..=p..$.xV4.
Region #46 [0x6faa0e7c] from #34 tback F2 dump off 0x00000038
Region #47 [0x6fa90348] from #46 (malloc_header) magic off 0
M-size    : 0x14040
Region #49 [0x6fa90368] from #34 tback F2 dump off 0x00000044
0x6fa903c8: c4 03 a9 6f bc 03 a9 6f 00 00 00 00 00 00 00 00  |  ...o...o........
0x6fa903d8: d8 03 a9 6f d8 03 a9 6f d0 03 a9 6f 00 00 00 00  |  ...o...o...o....
Region #52 [TX:0x0842a200] from #34 tback F2 dump off 0x00000050
0x0842a1e0: 55 89 e5 83 ec 28 8b 45 0c 89 5d f8 8b 5d 10 89  |  U....(.E..]..]..
0x0842a1f0: 75 fc 8d 75 f0 89 74 24 08 89 44 24 04 8b 45 08  |  u..u..t$..D$..E.
0x0842a200: 89 04 24 a1 fc 2f d9 0a ff 90 b8 01 00 00 85 db  |  ..$../..........
0x0842a210: 74 20 c7 43 28 00 00 00 00 c7 43 2c 00 00 00 00  |  t .C(.....C,....
0x0842a220: a1 fc 2f d9 0a 89 74 24 04 89 1c 24 ff 90 bc 01  |  ../...t$...$....
0x0842a230: 00 00 8b 5d f8 b8 01 00 00 00 8b 75 fc 89 ec 5d  |  ...].......u...]
0x0842a240: c3 eb 0d 90 90 90 90 90 90 90 90 90 90 90 90 90  |  ................
0x0842a250: 55 89 e5 57 56 53 83 ec 7c 0f b7 45 20 8b 55 10  |  U..WVS..|..E .U.
0x0842a260: 8b 4d 2c 66 89 45 a6 8b 45 0c 89 55 a0 89 55 e4  |  .M,f.E..E..U..U.
0x0842a270: 89 4d 9c 89 45 e0 8b 45 14 89 4d d0 89 45 e8 8b  |  .M..E..E..M..E..
Region #56 [0xbaa774a8] from #34 tback F2 dump off 0x00000064
0xbaa77488: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xbaa77498: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xbaa774a8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xbaa774b8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xbaa774c8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xbaa774d8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xbaa774e8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xbaa774f8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xbaa77508: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xbaa77518: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #58 [0x6e71d818] from tback F3
Region #59 [0x6e6fd960] from #58 (malloc_header) magic off 0
M-size    : 0x20000
Region #60 [0x6e71d8a8] from #58 tback F3 dump off 0x00000000
0x6e71d898: 78 56 34 12 8c 2d 5d 6e c8 ef ff ff 00 00 00 00  |  xV4..-]n........
0x6e71d8a8: 78 d9 71 6e 2c 92 06 08 90 d8 6f 6e 78 56 34 12  |  x.qn,.....onxV4.
0x6e71d8b8: 78 56 34 12 78 56 34 12 00 00 00 00 8c 2d 5d 6e  |  xV4.xV4......-]n
0x6e71d8c8: c8 ef ff ff 00 00 00 00 78 d9 71 6e b0 d8 71 6e  |  ........x.qn..qn
0x6e71d8d8: 19 92 06 08 78 56 34 12 78 56 34 12 78 56 34 12  |  ....xV4.xV4.xV4.
0x6e71d8e8: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e71d8f8: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e71d908: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e71d918: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
Region #61 [0x6e6fd960] from #60 (malloc_header) magic off 0
M-size    : 0x20000
Region #62 [TX:0x0827eab8] from #58 tback F3 dump off 0x00000004
0x0827ea98: 45 a4 23 45 e4 83 e8 01 0f 85 d4 fe ff ff 8b 55  |  E.#E...........U
0x0827eaa8: a0 8d 45 e4 8b 1a 8b 72 04 89 04 24 e8 77 5f ec  |  ..E....r...$.w_.
0x0827eab8: 00 8b 4d a0 01 c3 11 d6 89 19 89 71 04 e9 b0 fe  |  ..M........q....
0x0827eac8: ff ff 8d b6 00 00 00 00 8b 45 a0 8b 55 dc 8b 18  |  .........E..U...
0x0827ead8: 8b 70 04 8b 45 d8 89 54 24 04 89 04 24 e8 46 64  |  .p..E..T$...$.Fd
0x0827eae8: de ff 01 c3 11 d6 8b 55 a0 89 1a 89 72 04 e9 5e  |  .......U....r..^
0x0827eaf8: fe ff ff 90 8d 74 26 00 83 05 b8 3d d9 0a 01 8d  |  .....t&....=....
0x0827eb08: 45 ec 83 15 bc 3d d9 0a 00 89 04 24 e8 e7 57 ca  |  E....=.....$..W.
0x0827eb18: 00 e9 d2 fd ff ff 66 90 55 89 e5 83 ec 18 89 75  |  ......f.U......u
0x0827eb28: fc 8b 75 08 89 5d f8 8d 5e d0 8b 43 14 89 04 24  |  ..u..]..^..C...$
Region #69 [0x6e5d2df0] from #58 tback F3 dump off 0x00000030
0x6e5d2dd0: 76 b9 bd 12 94 83 00 00 dc 2e 91 fb d5 4e 00 00  |  v............N..
0x6e5d2de0: ec 24 9f 13 00 00 00 00 00 00 00 00 00 00 00 00  |  .$..............
0x6e5d2df0: a8 74 a7 ba e5 00 00 00 03 00 00 00 00 00 00 00  |  .t..............
0x6e5d2e00: 24 89 94 b4 23 89 94 b4 00 00 00 00 00 00 00 00  |  $...#...........
0x6e5d2e10: 00 00 00 00 00 00 00 00 00 00 00 00 a0 e8 6d 6e  |  ..............mn
0x6e5d2e20: 00 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e5d2e30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e5d2e40: 00 00 00 00 c0 d8 71 6e 00 00 00 00 ff ff ff 0f  |  ......qn........
0x6e5d2e50: ff ff ff 0f 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e5d2e60: 00 00 00 00 60 75 d3 0a 00 00 00 00 00 00 00 00  |  ....`u..........
Region #70 [0x6e5a6728] from #69 (malloc_header) magic off 0
0x6e5a6708: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e5a6718: ef cd 1c a1 00 00 00 00 d0 d4 40 47 9b cc 02 00  |  ..........@G....
0x6e5a6728: 23 01 1c a1 68 cc 02 00 00 00 00 00 00 00 00 00  |  #...h...........
0x6e5a6738: 00 00 00 00 70 86 5d 6e 84 93 06 08 00 00 00 00  |  ....p.]n........
0x6e5a6748: 80 2b 5d 6e 54 69 5a 6e 56 34 12 ff 00 00 00 00  |  .+]nTiZnV4......
0x6e5a6758: bc 49 5c 0a 53 69 a6 09 48 67 5a 6e e2 44 4c 08  |  .I\.Si..HgZn.DL.
0x6e5a6768: 1c 92 ab 75 e8 92 ab 75 48 67 5a 6e c8 ef ff ff  |  ...u...uHgZn....
0x6e5a6778: 00 00 00 00 90 19 55 08 50 b6 a1 74 f0 92 a9 75  |  ......U.P..t...u
0x6e5a6788: 00 00 02 00 ca 9d 23 07 6b 28 00 00 d4 11 14 00  |  ......#.k(......
0x6e5a6798: 00 00 00 00 20 19 13 00 00 00 00 00 00 00 00 00  |  .... ...........
malloc_header:0x6e5a6728
M-size    : 0x2cc68
M-allocd  : 0x08069384
Region #71 [0xb5500c30] from #58 tback F3 dump off 0x00000034
0xb5500c10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xb5500c20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xb5500c30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xb5500c40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xb5500c50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xb5500c60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xb5500c70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xb5500c80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xb5500c90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xb5500ca0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #76 [UK:0x6995c040] from #58 tback F3 dump off 0x0000004c
0x6995c020: f3 50 08 0a 00 1b 2a 34 d1 35 08 00 45 c0 00 a0  |  .P....*4.5..E...
0x6995c030: 6b 6b 40 00 40 32 0b ba 4b 62 e2 ba ad 58 e6 d1  |  kk@.@2..Kb...X..
0x6995c040: 3e 2a 00 1b 2a 34 d1 34 00 0a f3 50 08 0a 08 00  |  >*..*4.4...P....
0x6995c050: 45 00 00 40 2b 02 00 00 78 11 83 af 6d eb f8 6f  |  E..@+...x...m..o
0x6995c060: 4b 62 e2 3e cc 3e 00 35 00 2c 00 00 0b 85 01 00  |  Kb.>.>.5.,......
0x6995c070: 00 01 00 00 00 00 00 01 03 69 73 63 03 6f 72 67  |  .........isc.org
0x6995c080: 00 00 ff 00 01 00 00 29 10 00 00 00 80 00 00 00  |  .......)........
0x6995c090: d6 1d 47 cb 72 2f dd 3b 89 f3 7e 28 a9 a2 e4 da  |  ..G.r/.;..~(....
0x6995c0a0: 23 c0 60 1d c7 05 7f 65 b4 e2 78 2f 7d 1d 38 cc  |  #.`...&#127;e..x/}.8.
0x6995c0b0: 57 df 2a 25 3c 68 1f 82 b4 10 b8 91 86 dc d4 a4  |  W.*%<h..........
Region #77 [0x6e72b040] from #58 tback F3 dump off 0x00000050
0x6e72b020: 23 01 1c a1 68 00 00 00 00 00 00 00 00 00 00 00  |  #...h...........
0x6e72b030: 78 72 72 6e b0 ab 73 6e ad a0 84 09 00 00 00 00  |  xrrn..sn........
0x6e72b040: 00 00 00 00 00 00 00 00 05 00 00 00 05 07 00 00  |  ................
0x6e72b050: 00 0c 00 00 9a 06 00 00 00 0c 00 00 00 00 00 00  |  ................
0x6e72b060: 00 00 00 00 00 00 00 00 0e 06 00 00 d8 b0 72 6e  |  ..............rn
0x6e72b070: 60 0e 24 69 00 84 a0 69 00 00 00 00 01 00 00 00  |  `.$i...i........
0x6e72b080: ef be ad de a0 67 a0 69 80 b0 72 6e c0 86 4d 69  |  .....g.i..rn..Mi
0x6e72b090: 00 00 00 00 8c b0 72 6e 00 00 00 00 00 00 00 00  |  ......rn........
0x6e72b0a0: 00 00 00 00 00 00 00 00 ef cd 1c a1 00 00 00 00  |  ................
0x6e72b0b0: d0 d4 40 47 33 30 00 00 23 01 1c a1 04 30 00 00  |  ..@G30..#....0..
Region #78 [0x6e72f790] from #58 tback F3 dump off 0x00000058
0x6e72f770: 02 04 00 00 00 10 a1 69 78 00 73 6e 00 00 00 00  |  .......ix.sn....
0x6e72f780: 00 30 a1 69 a8 04 73 6e 40 00 00 00 00 00 00 00  |  .0.i..sn@.......
0x6e72f790: 60 f7 72 6e a0 a1 55 08 00 00 00 9a ff ff ff ff  |  `.rn..U.........
0x6e72f7a0: ef 00 00 00 60 0e 24 69 00 84 a0 69 ee 00 00 00  |  ....`.$i...i....
0x6e72f7b0: ee 00 00 00 ee 00 00 00 0c fe 72 6e 40 b0 72 6e  |  ..........rn@.rn
0x6e72f7c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e72f7d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e72f7e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e72f7f0: 00 00 00 00 60 e1 72 6e 86 80 79 10 07 00 30 02  |  ....`.rn..y...0.
0x6e72f800: 03 00 00 02 10 50 80 00 04 00 22 f8 00 00 00 00  |  .....P....".....
Region #79 [0x6e72f728] from #78 (malloc_header) magic off 0
0x6e72f708: d0 d4 40 47 19 00 00 00 f8 ef 71 6e 38 37 22 6f  |  ..@G......qn87"o
0x6e72f718: 23 01 ee f3 ef cd ee f3 18 00 00 00 82 07 00 00  |  #...............
0x6e72f728: 23 01 1c a1 53 07 00 00 00 00 00 00 00 00 00 00  |  #...S...........
0x6e72f738: 20 e1 72 6e 08 0d 73 6e f2 d5 55 08 00 00 00 00  |   .rn..sn..U.....
0x6e72f748: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e72f758: 45 36 27 18 48 f7 72 6e 00 50 f8 68 01 00 00 00  |  E6'.H.rn.P.h....
0x6e72f768: 00 01 00 00 09 00 00 00 02 04 00 00 00 10 a1 69  |  ...............i
0x6e72f778: 78 00 73 6e 00 00 00 00 00 30 a1 69 a8 04 73 6e  |  x.sn.....0.i..sn
0x6e72f788: 40 00 00 00 00 00 00 00 60 f7 72 6e a0 a1 55 08  |  @.......`.rn..U.
0x6e72f798: 00 00 00 9a ff ff ff ff ef 00 00 00 60 0e 24 69  |  ............`.$i
malloc_header:0x6e72f728
M-size    : 0x753
Region #82 [0x6e71d8a8] from tback F4
Region #83 [0x6e6fd960] from #82 (malloc_header) magic off 0
M-size    : 0x20000
Region #84 [0x6e71d978] from #82 tback F4 dump off 0x00000000
0x6e71d958: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e71d968: 78 56 34 12 00 00 00 00 00 00 00 00 00 00 00 00  |  xV4.............
0x6e71d978: 00 00 00 00 00 00 00 00 ef cd 1c a1 00 00 00 00  |  ................
0x6e71d988: d0 d4 40 47 b3 00 00 00 23 01 1c a1 84 00 00 00  |  ..@G....#.......
0x6e71d998: 00 00 00 00 00 00 00 00 a0 a2 6e 6e 08 7f 73 6e  |  ..........nn.&#127;sn
0x6e71d9a8: 6c e5 05 08 00 00 00 00 00 00 00 00 ed fe ad de  |  l...............
0x6e71d9b8: 08 da 71 6e 1c 2f 5d 6e 8c 81 d5 0a d0 a2 6e 6e  |  ..qn./]n......nn
0x6e71d9c8: b8 d9 71 6e 20 1f 03 0b 10 00 01 00 02 00 00 00  |  ..qn ...........
0x6e71d9d8: 42 83 98 09 60 d9 05 08 d4 35 4f 0a 00 00 00 00  |  B...`....5O.....
0x6e71d9e8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #85 [0x6e6fd960] from #84 (malloc_header) magic off 0
M-size    : 0x20000
Region #86 [TX:0x0806922c] from #82 tback F4 dump off 0x00000004
0x0806920c: 85 4c ff ff ff 89 04 24 e8 f3 32 10 01 89 45 f4  |  .L.....$..2...E.
0x0806921c: 8b 45 f4 85 c0 75 4c 8b 43 38 89 04 24 ff 53 34  |  .E...uL.C8..$.S4
0x0806922c: 8b 45 f4 85 c0 75 15 65 8b 16 85 d2 74 0e 8b 82  |  .E...u.e....t...
0x0806923c: b8 00 00 00 8b 00 89 82 b8 00 00 00 8b 45 f4 83  |  .............E..
0x0806924c: e8 01 74 56 65 8b 06 c7 40 70 08 00 00 00 c6 80  |  ..tVe...@p......
0x0806925c: bd 00 00 00 01 89 40 18 8d 74 26 00 e8 6b 53 fe  |  ......@..t&..kS.
0x0806926c: ff eb f9 65 8b 06 c7 45 f4 02 00 00 00 c7 40 70  |  ...e...E......@p
0x0806927c: 08 00 00 00 c6 80 bd 00 00 00 01 89 40 18 8d b6  |  ............@...
0x0806928c: 00 00 00 00 e8 43 53 fe ff eb f9 c7 85 48 ff ff  |  .....CS......H..
0x0806929c: ff 00 00 00 00 e9 65 ff ff ff 8b 45 ec 89 44 24  |  ......e....E..D$
Region #87 [0x6e6fd890] from #82 tback F4 dump off 0x00000008
0x6e6fd870: 23 01 1c a1 c4 00 00 00 00 00 00 00 00 00 00 00  |  #...............
0x6e6fd880: 00 00 00 00 48 8e bb 6e 2e e1 27 08 00 00 00 00  |  ....H..n..'.....
0x6e6fd890: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e6fd8a0: 00 00 00 00 00 00 00 00 03 04 00 04 32 19 05 00  |  ............2...
0x6e6fd8b0: 8c 2d 5d 6e 00 1d 4a 74 80 b4 4a 74 40 00 4b 74  |  .-]n..Jt..Jt@.Kt
0x6e6fd8c0: 00 4c 4b 74 40 c2 fb 73 80 c3 fb 73 00 00 00 00  |  .LKt@..s...s....
0x6e6fd8d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e6fd8e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e6fd8f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e6fd900: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #91 [0x6e5d2d8c] from #82 tback F4 dump off 0x0000001c
0x6e5d2d6c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e5d2d7c: 00 00 00 00 00 00 00 00 80 3a 12 74 80 2b 5d 6e  |  .........:.t.+]n
0x6e5d2d8c: b0 2d 5c 6e 68 84 d3 0a 56 34 12 ff 80 2b 5d 6e  |  .-\nh...V4...+]n
0x6e5d2d9c: 68 84 d3 0a 42 83 98 09 00 00 00 00 46 11 2d 09  |  h...B.......F.-.
0x6e5d2dac: 2c ff b3 68 28 d1 71 6e 00 00 00 00 c8 ef ff ff  |  ,..h(.qn........
0x6e5d2dbc: 20 cf bd 0a 50 e6 27 08 90 d8 6f 6e 80 d9 6f 6e  |   ...P.'...on..on
0x6e5d2dcc: 00 00 02 00 76 b9 bd 12 94 83 00 00 dc 2e 91 fb  |  ....v...........
0x6e5d2ddc: d5 4e 00 00 ec 24 9f 13 00 00 00 00 00 00 00 00  |  .N...$..........
0x6e5d2dec: 00 00 00 00 a8 74 a7 ba e5 00 00 00 03 00 00 00  |  .....t..........
0x6e5d2dfc: 00 00 00 00 24 89 94 b4 23 89 94 b4 00 00 00 00  |  ....$...#.......
Region #92 [0x6e5a6728] from #91 (malloc_header) magic off 0
M-size    : 0x2cc68
Region #93 [UK:0xffffefc8] from #82 tback F4 dump off 0x00000020
0xffffefa8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xffffefb8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xffffefc8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xffffefd8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xffffefe8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xffffeff8: 00 00 00 00 00 00 00 00                          |  ........
Region #94 [0x6e71d978] from #82 tback F4 dump off 0x00000028
Region #95 [0x6e6fd960] from #94 (malloc_header) magic off 0
M-size    : 0x20000
Region #96 [0x6e71d8b0] from #82 tback F4 dump off 0x0000002c
0x6e71d890: 07 00 00 00 00 00 00 00 78 56 34 12 8c 2d 5d 6e  |  ........xV4..-]n
0x6e71d8a0: c8 ef ff ff 00 00 00 00 78 d9 71 6e 2c 92 06 08  |  ........x.qn,...
0x6e71d8b0: 90 d8 6f 6e 78 56 34 12 78 56 34 12 78 56 34 12  |  ..onxV4.xV4.xV4.
0x6e71d8c0: 00 00 00 00 8c 2d 5d 6e c8 ef ff ff 00 00 00 00  |  .....-]n........
0x6e71d8d0: 78 d9 71 6e b0 d8 71 6e 19 92 06 08 78 56 34 12  |  x.qn..qn....xV4.
0x6e71d8e0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e71d8f0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e71d900: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e71d910: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e71d920: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
Region #97 [0x6e6fd960] from #96 (malloc_header) magic off 0
M-size    : 0x20000
Region #98 [TX:0x08069218] from #82 tback F4 dump off 0x00000030
0x080691f8: 31 d2 39 c8 0f 45 d0 89 95 48 ff ff ff 89 8b b8  |  1.9..E...H......
0x08069208: 00 00 00 8d 85 4c ff ff ff 89 04 24 e8 f3 32 10  |  .....L.....$..2.
0x08069218: 01 89 45 f4 8b 45 f4 85 c0 75 4c 8b 43 38 89 04  |  ..E..E...uL.C8..
0x08069228: 24 ff 53 34 8b 45 f4 85 c0 75 15 65 8b 16 85 d2  |  $.S4.E...u.e....
0x08069238: 74 0e 8b 82 b8 00 00 00 8b 00 89 82 b8 00 00 00  |  t...............
0x08069248: 8b 45 f4 83 e8 01 74 56 65 8b 06 c7 40 70 08 00  |  .E....tVe...@p..
0x08069258: 00 00 c6 80 bd 00 00 00 01 89 40 18 8d 74 26 00  |  ..........@..t&.
0x08069268: e8 6b 53 fe ff eb f9 65 8b 06 c7 45 f4 02 00 00  |  .kS....e...E....
0x08069278: 00 c7 40 70 08 00 00 00 c6 80 bd 00 00 00 01 89  |  ..@p............
0x08069288: 40 18 8d b6 00 00 00 00 e8 43 53 fe ff eb f9 c7  |  @........CS.....
Region #106 [0x6e71d978] from tback F5
Region #107 [0x6e6fd960] from #106 (malloc_header) magic off 0
M-size    : 0x20000
Region #108 [0xa11ccdec] from #106 tback F5 dump off 0x00000008
0xa11ccdcc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11ccddc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11ccdec: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11ccdfc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11cce0c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11cce1c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11cce2c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11cce3c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11cce4c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11cce5c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #111 [0xa11c0120] from #106 tback F5 dump off 0x00000018
0xa11c0100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11c0110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11c0120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11c0130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11c0140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11c0150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11c0160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11c0170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11c0180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa11c0190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #113 [0x6e6ea2a0] from #106 tback F5 dump off 0x00000028
0x6e6ea280: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e6ea290: ef cd 1c a1 00 00 00 00 d0 d4 40 47 b3 00 00 00  |  ..........@G....
0x6e6ea2a0: 23 01 1c a1 84 00 00 00 00 00 00 00 00 00 00 00  |  #...............
0x6e6ea2b0: 00 00 00 00 90 d9 71 6e 6c e5 05 08 00 00 00 00  |  ......qnl.......
0x6e6ea2c0: 00 00 00 00 ed fe ad de 18 a3 6e 6e 34 33 5d 6e  |  ..........nn43]n
0x6e6ea2d0: c0 d9 71 6e c0 ad 6a 6e c8 a2 6e 6e 20 1f 03 0b  |  ..qn..jn..nn ...
0x6e6ea2e0: 0e 00 01 00 02 00 00 00 a0 0a 90 09 60 d9 05 08  |  ............`...
0x6e6ea2f0: d4 35 4f 0a 00 00 00 00 00 00 00 00 00 00 00 00  |  .5O.............
0x6e6ea300: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e6ea310: 00 00 00 00 00 00 00 00 34 33 5d 6e 00 00 00 00  |  ........43]n....
malloc_header:0x6e6ea2a0
M-size    : 0x84
M-allocd  : 0x0805e56c
**WARNING: ptr 0x6e6ea2a0 not within (mh + 1) 0x6e6ea2c0 and (unsigned char *)(mh + 1) + mh->mh_len 0x6e6ea344
Region #114 [0x6e737f08] from #106 tback F5 dump off 0x0000002c
0x6e737ee8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e737ef8: ef cd 1c a1 00 00 00 00 d0 d4 40 47 b3 00 00 00  |  ..........@G....
0x6e737f08: 23 01 1c a1 84 00 00 00 00 00 00 00 00 00 00 00  |  #...............
0x6e737f18: 90 d9 71 6e 60 ef 73 6e 6c e5 05 08 00 00 00 00  |  ..qn`.snl.......
0x6e737f28: 00 00 00 00 ed fe ad de 80 7f 73 6e 04 2b 5d 6e  |  .........&#127;sn.+]n
0x6e737f38: 90 ef 73 6e 64 ab 60 6e 30 7f 73 6e 20 1f 03 0b  |  ..snd.`n0&#127;sn ...
0x6e737f48: 14 00 01 00 02 00 00 00 96 35 b0 09 60 d9 05 08  |  .........5..`...
0x6e737f58: d4 35 4f 0a 00 00 00 00 00 00 00 00 00 00 00 00  |  .5O.............
0x6e737f68: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e737f78: 00 00 00 00 00 00 00 00 04 2b 5d 6e 00 00 00 00  |  .........+]n....
malloc_header:0x6e737f08
M-size    : 0x84
**WARNING: ptr 0x6e737f08 not within (mh + 1) 0x6e737f28 and (unsigned char *)(mh + 1) + mh->mh_len 0x6e737fac
Region #115 [TX:0x0805e56c] from #106 tback F5 dump off 0x00000030
0x0805e54c: 00 00 00 00 55 89 e5 56 53 83 ec 10 c7 44 24 04  |  ....U..VS....D$.
0x0805e55c: 84 00 00 00 c7 04 24 01 00 00 00 e8 c4 c0 7f 01  |  ......$.......&#127;.
0x0805e56c: 85 c0 89 c3 74 6b c7 40 04 ed fe ad de 8d 70 08  |  ....tk.@......p.
0x0805e57c: c7 80 80 00 00 00 ff ff ff 0f c7 40 7c ff ff ff  |  ...........@|...
0x0805e58c: 0f 8b 45 08 c7 44 24 0c 08 00 00 00 c7 44 24 08  |  ..E..D$......D$.
0x0805e59c: 00 00 00 00 89 34 24 89 44 24 04 e8 84 e9 7a 01  |  .....4$.D$....z.
0x0805e5ac: 85 c0 74 36 c7 44 24 04 60 d9 05 08 89 04 24 e8  |  ..t6.D$.`.....$.
0x0805e5bc: 10 e6 7a 01 8b 43 30 8d 53 48 89 54 24 08 8d 53  |  ..z..C0.SH.T$..S
0x0805e5cc: 58 89 54 24 04 89 34 24 ff 10 c7 43 6c 20 7b d3  |  X.T$..4$...Cl {.
0x0805e5dc: 0a 83 c4 10 89 d8 5b 5e 5d c3 89 1c 24 31 db e8  |  ......[^]...$1..
Region #117 [0x6e71da08] from #106 tback F5 dump off 0x00000040
0x6e71d9f8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e71da08: 1c 2f 5d 6e 00 00 00 00 f8 d9 71 6e b8 d9 71 6e  |  ./]n......qn..qn
0x6e71da18: 00 00 00 00 20 7b d3 0a 00 00 00 00 00 00 00 00  |  .... {..........
0x6e71da28: 00 00 00 00 ff ff ff 0f ff ff ff 0f ef cd 1c a1  |  ................
0x6e71da38: d0 d4 40 47 63 00 00 00 23 01 1c a1 30 00 00 00  |  ..@Gc...#...0...
0x6e71da48: 00 00 00 00 00 00 00 00 50 a3 6e 6e 98 22 73 6e  |  ........P.nn."sn
0x6e71da58: 5a e5 84 09 00 00 00 00 6b 00 00 00 6f 00 00 00  |  Z.......k...o...
0x6e71da68: 72 00 00 00 72 00 00 00 00 00 00 00 00 00 00 00  |  r...r...........
0x6e71da78: 00 00 00 00 00 00 00 00 08 bc a0 04 00 00 00 00  |  ................
Region #118 [0x6e71d990] from #117 (malloc_header) magic off 0
0x6e71d970: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e71d980: ef cd 1c a1 00 00 00 00 d0 d4 40 47 b3 00 00 00  |  ..........@G....
0x6e71d990: 23 01 1c a1 84 00 00 00 00 00 00 00 00 00 00 00  |  #...............
0x6e71d9a0: a0 a2 6e 6e 08 7f 73 6e 6c e5 05 08 00 00 00 00  |  ..nn.&#127;snl.......
0x6e71d9b0: 00 00 00 00 ed fe ad de 08 da 71 6e 1c 2f 5d 6e  |  ..........qn./]n
0x6e71d9c0: 8c 81 d5 0a d0 a2 6e 6e b8 d9 71 6e 20 1f 03 0b  |  ......nn..qn ...
0x6e71d9d0: 10 00 01 00 02 00 00 00 42 83 98 09 60 d9 05 08  |  ........B...`...
0x6e71d9e0: d4 35 4f 0a 00 00 00 00 00 00 00 00 00 00 00 00  |  .5O.............
0x6e71d9f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e71da00: 00 00 00 00 00 00 00 00 1c 2f 5d 6e 00 00 00 00  |  ........./]n....
malloc_header:0x6e71d990
M-size    : 0x84
Region #119 [0x6e5d2f1c] from #106 tback F5 dump off 0x00000044
0x6e5d2efc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e5d2f0c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e5d2f1c: 00 00 00 00 08 da 71 6e 0c 2f 5d 6e b8 d9 71 6e  |  ......qn./]n..qn
0x6e5d2f2c: 00 00 00 00 80 74 d3 0a 00 00 00 00 00 00 00 00  |  .....t..........
0x6e5d2f3c: 00 00 00 00 04 00 00 00 00 00 00 00 01 01 00 00  |  ................
0x6e5d2f4c: 00 00 00 00 92 01 a1 40 39 00 00 00 00 84 1e 00  |  .......@9.......
0x6e5d2f5c: 00 00 00 00 64 00 00 00 00 00 00 00 00 00 00 00  |  ....d...........
0x6e5d2f6c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e5d2f7c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e5d2f8c: 00 00 00 00 60 da 71 6e 8c 2d 5d 6e 08 17 5d 6e  |  ....`.qn.-]n..]n
Region #120 [0x6e5a6728] from #119 (malloc_header) magic off 0
M-size    : 0x2cc68
Region #121 [ID:0x0ad5818c] from #106 tback F5 dump off 0x00000048
0x0ad5816c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0ad5817c: 00 00 00 00 0e 00 00 00 2c 74 72 6e 0c d7 0f 6f  |  ........,trn...o
0x0ad5818c: 64 ab 60 6e c0 d9 71 6e 84 81 d5 0a 20 1f 03 0b  |  d.`n..qn.... ...
0x0ad5819c: 12 00 01 00 0e 00 00 00 cb 1e a6 09 c0 cb 80 09  |  ................
0x0ad581ac: d4 35 4f 0a 00 00 00 00 e8 73 72 6e 88 7e 72 6e  |  .5O......srn.~rn
0x0ad581bc: d8 7c 0f 6f 68 17 18 6f 00 00 00 00 30 21 18 6f  |  .|.oh..o....0!.o
0x0ad581cc: 00 00 00 00 f8 c4 0f 6f c0 d7 0f 6f c0 3f 93 6e  |  .......o...o.?.n
0x0ad581dc: f8 fc 2c 71 f0 c5 0f 6f 00 00 00 00 b8 87 22 6f  |  ..,q...o......"o
0x0ad581ec: b8 d8 0f 6f b0 d9 0f 6f 00 00 00 00 c8 d6 0f 6f  |  ...o...o.......o
0x0ad581fc: 00 00 00 00 00 00 00 00 00 00 00 00 a4 03 5c 6e  |  ..............\n
Region #122 [0x6e6ea2d0] from #106 tback F5 dump off 0x0000004c
0x6e6ea320: 08 a3 6e 6e c8 a2 6e 6e 00 00 00 00 20 7b d3 0a  |  ..nn..nn.... {..
0x6e6ea330: 00 00 00 00 00 00 00 00 00 00 00 00 ff ff ff 0f  |  ................
0x6e6ea340: ff ff ff 0f ef cd 1c a1 d0 d4 40 47 63 00 00 00  |  ..........@Gc...
Region #123 [0x6e71d9b8] from #106 tback F5 dump off 0x00000050
Region #124 [ID:0x0b031f20] from #106 tback F5 dump off 0x00000054
0x0b031f00: 60 4d 58 6e 00 00 00 00 00 00 00 00 00 00 00 00  |  `MXn............
0x0b031f10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0b031f20: 28 7c d3 0a 04 49 66 75 00 00 00 00 00 00 00 00  |  (|...Ifu........
0x0b031f30: 00 00 00 00 00 00 00 00 00 00 01 00 79 02 00 00  |  ............y...
0x0b031f40: 85 83 b6 09 c0 cb 80 09 d4 35 4f 0a 00 00 00 00  |  .........5O.....
0x0b031f50: d8 06 60 6e 00 00 00 00 00 00 00 00 00 00 00 00  |  ..`n............
0x0b031f60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0b031f70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0b031f80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0b031f90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #126 [UK:0x09988340] from #106 tback F5 dump off 0x00000060
0x09988320: 73 28 29 20 6e 6f 74 20 73 75 70 70 6f 72 74 65  |  s() not supporte
0x09988330: 64 20 6f 6e 20 74 68 69 73 20 74 61 72 67 65 74  |  d on this target
0x09988340: 0a 00 44 69 73 70 61 74 63 68 20 55 6e 69 74 00  |  ..Dispatch Unit.
0x09988350: 70 72 69 6f 72 69 74 79 5f 71 2e 63 00 20 20 71  |  priority_q.c.  q
0x09988360: 75 65 75 65 3a 20 6d 61 78 3d 30 78 25 78 20 71  |  ueue: max=0x%x q
0x09988370: 75 5f 73 69 7a 65 3d 25 64 0a 00 20 20 20 20 67  |  u_size=%d..    g
0x09988380: 71 69 78 20 25 64 3a 20 61 76 5f 71 75 5f 71 75  |  qix %d: av_qu_qu
0x09988390: 6f 74 61 3d 25 64 0a 00 69 6e 64 65 78 20 3c 20  |  ota=%d..index <
0x099883a0: 4e 45 4c 54 53 28 69 66 63 2d 3e 71 75 65 75 65  |  NELTS(ifc->queue
0x099883b0: 73 29 00 43 50 2d 44 50 20 45 56 45 4e 54 20 51  |  s).CP-DP EVENT Q
Region #127 [TX:0x0805d960] from #106 tback F5 dump off 0x00000064
0x0805d940: 09 89 44 24 14 8b 45 14 89 44 24 0c 8b 45 10 89  |  ..D$..E..D$..E..
0x0805d950: 44 24 08 e8 48 e3 81 01 b8 01 00 00 00 c9 c3 90  |  D$..H...........
0x0805d960: 55 31 c0 89 e5 83 ec 18 8b 55 0c 85 d2 74 40 8b  |  U1.......U...t@.
0x0805d970: 42 08 39 d0 74 42 8b 40 24 8b 40 44 c7 44 24 10  |  B.9.tB.@$.@D.D$.
0x0805d980: f3 19 90 09 89 44 24 14 8b 45 14 89 44 24 0c 8b  |  .....D$..E..D$..
0x0805d990: 45 10 c7 44 24 04 ff 00 00 00 c7 04 24 ac 19 90  |  E..D$.......$...
0x0805d9a0: 09 89 44 24 08 e8 f6 e2 81 01 b8 01 00 00 00 c9  |  ..D$............
0x0805d9b0: c3 8d b4 26 00 00 00 00 8b 40 20 ba 17 bc af 09  |  ...&.....@ .....
0x0805d9c0: 85 c0 74 03 8b 50 14 89 54 24 14 c7 44 24 10 e7  |  ..t..P..T$..D$..
0x0805d9d0: 19 90 09 8b 45 14 89 44 24 0c 8b 45 10 c7 44 24  |  ....E..D$..E..D$
Region #128 [UD:0x0a4f35d4] from #106 tback F5 dump off 0x00000068
0x0a4f35b4: 10 27 00 00 10 27 00 00 10 27 00 00 f4 01 00 00  |  .'...'...'......
0x0a4f35c4: 50 c3 00 00 f4 01 00 00 88 13 00 00 05 00 00 00  |  P...............
0x0a4f35d4: 80 d5 80 09 a0 d3 80 09 80 d2 80 09 a0 d7 80 09  |  ................
0x0a4f35e4: 60 d1 80 09 70 d6 80 09 1a 6a f2 09 24 6a f2 09  |  `...p....j..$j..
0x0a4f35f4: 01 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0a4f3604: 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0a4f3614: 00 00 00 00 0a 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0a4f3624: 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0a4f3634: 00 00 00 00 3c 00 00 00 00 00 00 00 00 00 00 00  |  ....<...........
0x0a4f3644: 00 00 00 00 b5 a9 f2 09 24 00 00 00 00 d6 9e 74  |  ........$......t
Region #129 [0x6e9340f8] from %edi
Region #132 [0x6fa7c2f8] from #129 (%edi) dump off 0x00000010
0x6fa7c2d8: 23 01 1c a1 40 40 01 00 00 00 00 00 00 00 00 00  |  #...@@..........
0x6fa7c2e8: 08 b3 9c 6f 48 03 a9 6f b0 4f 14 09 00 00 00 00  |  ...oH..o.O......
0x6fa7c2f8: 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00  |  .........@......
0x6fa7c308: 0e 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00  |  ................
0x6fa7c318: d8 0b 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa7c328: 64 00 00 00 10 00 00 00 00 ba 37 43 3f 13 00 00  |  d.........7C?...
0x6fa7c338: 00 00 00 00 00 00 00 00 40 c3 a7 6f 40 c3 a7 6f  |  ........@..o@..o
0x6fa7c348: 38 c3 a7 6f 00 00 00 00 00 00 00 00 54 c3 a7 6f  |  8..o........T..o
0x6fa7c358: 54 c3 a7 6f 4c c3 a7 6f 00 00 00 00 00 00 00 00  |  T..oL..o........
0x6fa7c368: 68 c3 a7 6f 68 c3 a7 6f 60 c3 a7 6f 00 00 00 00  |  h..oh..o`..o....
Region #135 [0x6fa90368] from #129 (%edi) dump off 0x00000024
Region #138 [0x6faa43d8] from #129 (%edi) dump off 0x00000038
0x6faa43b8: 23 01 1c a1 40 80 02 00 00 00 00 00 00 00 00 00  |  #...@...........
0x6faa43c8: 38 c0 fa 6e 28 c4 ac 6f b0 4f 14 09 00 00 00 00  |  8..n(..o.O......
0x6faa43d8: 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00  |  ...........@....
0x6faa43e8: 1e 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00  |  ......... ......
0x6faa43f8: b5 06 00 00 00 00 00 00 00 00 00 00 a6 00 00 00  |  ................
0x6faa4408: 64 00 00 00 10 00 00 00 00 62 43 f0 c9 41 00 00  |  d........bC..A..
0x6faa4418: 00 00 00 00 00 00 00 00 20 44 aa 6f 20 44 aa 6f  |  ........ D.o D.o
0x6faa4428: 18 44 aa 6f 00 00 00 00 00 00 00 00 34 44 aa 6f  |  .D.o........4D.o
0x6faa4438: 34 44 aa 6f 2c 44 aa 6f 00 00 00 00 00 00 00 00  |  4D.o,D.o........
0x6faa4448: 48 44 aa 6f 48 44 aa 6f 40 44 aa 6f 00 00 00 00  |  HD.oHD.o@D.o....
Region #141 [0x6facc448] from #129 (%edi) dump off 0x0000004c
0x6facc428: 23 01 1c a1 40 80 02 00 00 00 00 00 00 00 00 00  |  #...@...........
0x6facc438: b8 43 aa 6f c0 6a d3 6f b0 4f 14 09 00 00 00 00  |  .C.o.j.o.O......
0x6facc448: 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00  |  ................
0x6facc458: 24 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00  |  $........ ......
0x6facc468: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6facc478: 64 00 00 00 10 00 00 00 00 c0 46 b0 1c 00 00 00  |  d.........F.....
0x6facc488: 00 00 00 00 00 00 00 00 90 c4 ac 6f 90 c4 ac 6f  |  ...........o...o
0x6facc498: 88 c4 ac 6f 00 00 00 00 00 00 00 00 a4 c4 ac 6f  |  ...o...........o
0x6facc4a8: a4 c4 ac 6f 9c c4 ac 6f 00 00 00 00 00 00 00 00  |  ...o...o........
0x6facc4b8: b8 c4 ac 6f b8 c4 ac 6f b0 c4 ac 6f 00 00 00 00  |  ...o...o...o....
Region #142 [0xa11ccdec] from #129 (%edi) dump off 0x00000050
Region #146 [0xa11c0120] from #129 (%edi) dump off 0x00000060
Region #148 [0x6e7572f0] from #129 (%edi) dump off 0x00000070
0x6e7572d0: 20 81 8a 6e 5c 81 8a 6e 98 81 8a 6e d4 81 8a 6e  |   ..n\..n...n...n
0x6e7572e0: 78 56 34 ef cd 1c a1 12 d0 d4 40 47 9b 00 00 00  |  xV4.......@G....
0x6e7572f0: 23 01 1c a1 68 00 00 00 00 00 00 00 00 00 00 00  |  #...h...........
0x6e757300: d0 ad 2f 6f 58 41 93 6e a4 d4 21 08 be bf 5f 08  |  ../oXA.n..!..._.
0x6e757310: 0f 00 00 00 55 61 75 74 68 20 43 6c 75 73 74 65  |  ....Uauth Cluste
0x6e757320: 72 20 43 6c 69 65 6e 74 00 00 00 00 00 00 00 00  |  r Client........
0x6e757330: 00 00 00 00 40 7a 0a 09 00 00 00 00 f0 74 0a 09  |  ....@z.......t..
0x6e757340: c0 74 0a 09 70 6f 0a 09 b0 7c 0a 09 e0 6f 0a 09  |  .t..po...|...o..
0x6e757350: b0 74 0a 09 08 9e 10 6f 00 00 00 00 00 00 00 00  |  .t.....o........
0x6e757360: 60 2a 00 00 06 a0 a5 02 01 00 00 00 20 99 0a 09  |  `*.......... ...
malloc_header:0x6e7572f0
M-size    : 0x68
M-allocd  : 0x0821d4a4
**WARNING: ptr 0x6e7572f0 not within (mh + 1) 0x6e757310 and (unsigned char *)(mh + 1) + mh->mh_len 0x6e757378
Region #149 [0x6e756f28] from #148 (chunk-hdr) magic off 20
0x6e756f08: 00 00 00 00 00 00 00 00 18 6a f9 6e 70 f8 89 6e  |  .........j.np..n
0x6e756f18: 3e 89 80 09 78 56 34 12 45 36 27 18 20 6f 75 6e  |  >...xV4.E6'. oun
0x6e756f28: 30 ee a6 6f 00 00 00 00 00 00 00 00 00 00 00 00  |  0..o............
0x6e756f38: 00 00 00 00 9d c9 a3 15 c8 00 00 00 c8 00 00 00  |  ................
0x6e756f48: 3c 00 00 00 3c 00 00 00 c8 00 00 00 00 00 00 00  |  <...<...........
0x6e756f58: 00 00 00 00 c8 00 00 00 04 00 00 00 00 00 00 00  |  ................
0x6e756f68: 00 00 10 00 05 00 00 00 57 00 00 00 00 00 00 00  |  ........W.......
0x6e756f78: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e756f88: 49 50 20 41 6e 73 77 65 72 20 4d 65 6d 6f 72 79  |  IP Answer Memory
0x6e756f98: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
chunk_type: 0x6e756f28
C-base    : 0x6e8a5330
C-size    : 0x2ee0
C-type    : 87
C-headtail: 0x00000000
**WARNING: ptr 0x6e7572f0 not within chunk->data 0x6e8a5330 and chunk->end 0x6e8a8210
Region #150 [0x703daee0] from #129 (%edi) dump off 0x00000074
0x703daec0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x703daed0: ef cd 1c a1 00 00 00 00 d0 d4 40 47 9b 00 00 00  |  ..........@G....
0x703daee0: 23 01 1c a1 6c 00 00 00 00 00 00 00 00 00 00 00  |  #...l...........
0x703daef0: 58 41 93 6e 30 b0 3d 70 0b 08 24 08 00 00 00 00  |  XA.n0.=p..$.....
0x703daf00: 18 3c a5 74 00 00 00 00 10 00 00 00 40 00 00 00  |  .<.t........@...
0x703daf10: 00 00 00 00 00 00 00 00 fe ff ff ff 01 00 00 00  |  ................
0x703daf20: 00 00 00 00 00 00 00 00 43 00 00 00 00 00 00 00  |  ........C.......
0x703daf30: 04 00 00 00 00 00 00 00 21 8d 16 00 00 00 00 00  |  ........!.......
0x703daf40: 21 8d 16 00 00 00 00 00 00 00 00 00 00 00 00 00  |  !...............
0x703daf50: 3f 00 00 00 b8 01 00 00 01 00 00 00 00 00 00 00  |  ?...............
malloc_header:0x703daee0
M-size    : 0x6c
M-allocd  : 0x0824080b
**WARNING: ptr 0x703daee0 not within (mh + 1) 0x703daf00 and (unsigned char *)(mh + 1) + mh->mh_len 0x703daf6c
Region #151 [0x703d80d8] from #150 (chunk-hdr) magic off 20
0x703d80b8: 00 00 00 00 00 00 00 00 18 2c 2e 70 00 d0 89 6e  |  .........,.p...n
0x703d80c8: 3e 89 80 09 00 00 00 00 45 36 27 18 d0 80 3d 70  |  >.......E6'...=p
0x703d80d8: b0 b3 4d 70 00 00 00 00 00 00 00 00 00 00 00 00  |  ..Mp............
0x703d80e8: 00 00 00 00 9d c9 a3 15 00 04 00 00 00 04 00 00  |  ................
0x703d80f8: 8c 00 00 00 c0 00 00 00 00 04 00 00 00 00 00 00  |  ................
0x703d8108: 00 00 00 00 00 04 00 00 40 00 00 00 00 00 00 00  |  ........@.......
0x703d8118: 40 00 50 00 45 00 00 00 8e 03 00 00 00 00 00 00  |  @.P.E...........
0x703d8128: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x703d8138: 44 50 20 67 65 6e 65 72 61 74 65 64 20 43 58 20  |  DP generated CX
0x703d8148: 65 76 65 6e 74 00 00 00 00 00 00 00 00 00 00 00  |  event...........
chunk_type: 0x703d80d8
C-base    : 0x703a8040
C-size    : 0x30040
C-type    : 910
**WARNING: ptr 0x703daee0 not within chunk->data 0x703a8040 and chunk->end 0x703d8080
Region #152 [TX:0x08240808] from #129 (%edi) dump off 0x00000078
0x082407e8: 01 8d b4 26 00 00 00 00 55 89 e5 53 83 ec 14 c7  |  ...&....U..S....
0x082407f8: 44 24 04 6c 00 00 00 c7 04 24 01 00 00 00 e8 25  |  D$.l.....$.....%
0x08240808: 9e 61 01 85 c0 89 c3 74 5a 8b 45 10 c7 04 24 10  |  .a.....tZ.E...$.
0x08240818: 00 00 00 89 44 24 0c 8b 45 0c 89 44 24 08 8b 45  |  ....D$..E..D$..E
0x08240828: 08 89 44 24 04 e8 ce 0f 00 00 85 c0 89 03 74 3b  |  ..D$..........t;
0x08240838: c7 43 60 00 00 00 00 c7 43 64 00 00 00 00 c7 43  |  .C`.....Cd.....C
0x08240848: 68 00 00 00 00 c7 43 0c 10 00 00 00 c7 43 08 00  |  h.....C......C..
0x08240858: 00 00 00 8b 40 48 c7 43 58 01 00 00 00 83 c0 6c  |  ....@H.CX......l
0x08240868: 89 43 54 89 d8 83 c4 14 5b 5d c3 89 1c 24 31 db  |  .CT.....[]...$1.
0x08240878: e8 93 9e 61 01 eb ec 90 55 89 e5 57 56 53 83 ec  |  ...a....U..WVS..
Region #158 [0x706f1408] from %eax
0x706f13e8: 97 ac d7 ee 01 00 00 00 b9 9b 48 4a 00 e0 e2 08  |  ..........HJ....
0x706f13f8: 40 00 00 00 00 28 e2 08 40 00 00 00 30 75 00 00  |  @....(..@...0u..
0x706f1408: 00 00 00 00 00 00 00 00 02 00 00 00 68 03 a9 6f  |  ............h..o
0x706f1418: 18 14 6f 70 18 14 6f 70 00 00 00 00 04 13 6f 70  |  ..op..op......op
0x706f1428: 35 bc 14 01 d4 9f a6 6f d4 9f a6 6f 00 9f a6 6f  |  5......o...o...o
0x706f1438: 00 00 00 00 c0 33 6f 70 80 fc 6e 70 00 00 00 00  |  .....3op..np....
0x706f1448: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #159 [0x706eb5e0] from #158 (malloc_header) magic off 0
M-size    : 0x7d87
Region #160 [0x706f1300] from #158 (Corrupt Xlate) magic off 0
Xlate-Refcnt        : 1
Xlate-Flags         : 4100
Xlate-DiagFlags     : 0
H-addr    : 0xa04070a
H-refcnt  : 4
H-tcpmss  : 1380
Region #161 [0x6fa90368] from #158 (%eax) dump off 0x0000000c
Region #162 [0x706f1418] from #158 (%eax) dump off 0x00000010
0x706f1488: 6b e6 64 1e c0 ae 4d 70 48 1b 6a 74 00 00 00 00  |  k.d...MpH.jt....
Region #163 [0x706eb5e0] from #162 (malloc_header) magic off 0
M-size    : 0x7d87
Region #164 [0x706f1300] from #162 (Corrupt Xlate) magic off 0
Xlate-Refcnt        : 1
Xlate-Flags         : 4100
Xlate-DiagFlags     : 0
H-addr    : 0xa04070a
H-refcnt  : 4
H-tcpmss  : 1380
Region #165 [0x706f1418] from #158 (%eax) dump off 0x00000014
Region #166 [0x706eb5e0] from #165 (malloc_header) magic off 0
M-size    : 0x7d87
Region #167 [0x706f1300] from #165 (Corrupt Xlate) magic off 0
Xlate-Refcnt        : 1
Xlate-Flags         : 4100
Xlate-DiagFlags     : 0
H-addr    : 0xa04070a
H-refcnt  : 4
H-tcpmss  : 1380
Region #168 [0x706f1304] from #158 (%eax) dump off 0x0000001c
0x706f12e4: c4 11 6f 70 81 af 14 01 00 00 00 00 00 00 00 00  |  ..op............
0x706f12f4: 80 2a b0 75 00 00 00 00 c0 33 6f 70 ef be ad de  |  .*.u.....3op....
0x706f1304: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706f1314: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706f1324: ff ff ff ff c0 79 bb 0a 00 13 6f 70 00 41 00 00  |  .....y....op.A..
0x706f1334: 01 00 00 00 cb dc cb dc 00 00 00 00 ff ff ff ff  |  ................
0x706f1344: 34 c7 71 6e 97 ac d7 ee c0 ae 4d 70 48 1b 6a 74  |  4.qn......MpH.jt
0x706f1354: 00 00 00 00 0a 07 04 0a 00 00 00 00 00 00 00 00  |  ................
0x706f1364: 00 00 00 00 50 9b 97 74 00 00 00 00 4b 62 e2 ba  |  ....P..t....Kb..
0x706f1374: 00 00 00 00 d4 34 4f 74 a6 65 85 09 00 00 00 00  |  .....4Ot.e......
Region #169 [0x706eb5e0] from #168 (malloc_header) magic off 0
M-size    : 0x7d87
Xlate-Refcnt        : 1
Xlate-Flags         : 4100
Xlate-DiagFlags     : 0
H-addr    : 0xa04070a
H-refcnt  : 4
H-tcpmss  : 1380
Region #171 [0x6fa69fd4] from #158 (%eax) dump off 0x00000024
0x6fa69fb4: 00 00 00 00 00 00 00 00 64 05 00 00 00 00 00 00  |  ........d.......
0x6fa69fc4: 00 c6 89 ca 27 00 00 00 2c 01 00 00 01 00 00 00  |  ....'...,.......
0x6fa69fd4: 2c 14 6f 70 2c 14 6f 70 00 00 00 00 00 00 00 00  |  ,.op,.op........
0x6fa69fe4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa69ff4: 00 00 00 00 00 00 00 00 28 53 82 6e 00 00 00 00  |  ........(S.n....
0x6fa6a004: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa6a014: 00 00 00 00 00 00 00 00 00 00 00 00 ff ff ff ff  |  ................
0x6fa6a024: 40 37 d9 0a 00 a0 a6 6f 04 00 00 00 03 00 00 00  |  @7.....o........
0x6fa6a034: 40 24 95 75 00 00 00 00 40 79 bb 0a 40 6e 73 75  |  @$.u....@y..@nsu
0x6fa6a044: e4 55 38 1a 00 00 00 00 00 00 00 00 02 00 00 00  |  .U8.............
Region #172 [0x6fa65290] from #171 (malloc_header) magic off 0
0x6fa65270: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ef  |  ................
0x6fa65280: cd 1c a1 ff ff ff ff ff d0 d4 40 47 bb 64 00 00  |  ..........@G.d..
0x6fa65290: 23 01 1c a1 87 64 00 00 00 00 00 00 00 00 00 00  |  #....d..........
0x6fa652a0: d8 ed a5 6f e0 b5 6e 70 c2 88 80 09 ff ff ff ff  |  ...o..np........
0x6fa652b0: ff ff ff ff ff ff ff ff 45 36 27 18 b0 52 a6 6f  |  ........E6'..R.o
0x6fa652c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa652d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa652e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa652f0: 00 00 00 00 00 00 00 00 00 00 00 00 28 53 82 6e  |  ............(S.n
0x6fa65300: 80 2d b0 75 00 00 00 00 00 00 00 00 00 00 00 00  |  .-.u............
malloc_header:0x6fa65290
M-size    : 0x6487
M-allocd  : 0x098088c2
Region #173 [0x6fa69fd4] from #158 (%eax) dump off 0x00000028
Region #174 [0x6fa65290] from #173 (malloc_header) magic off 0
M-size    : 0x6487
Region #175 [0x6fa69f00] from #158 (%eax) dump off 0x0000002c
0x6fa69ee0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa69ef0: 00 00 00 00 00 00 00 00 00 00 00 00 28 53 82 6e  |  ............(S.n
0x6fa69f00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa69f10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6fa69f20: ff ff ff ff 40 37 d9 0a 00 9f a6 6f 04 00 00 00  |  ....@7.....o....
0x6fa69f30: 04 00 00 00 40 3f 95 75 00 00 00 00 40 79 bb 0a  |  ....@?.u....@y..
0x6fa69f40: 01 00 00 00 05 dd d0 af 00 00 00 00 02 00 00 00  |  ................
0x6fa69f50: 00 00 00 00 02 00 00 00 00 00 00 00 30 03 00 00  |  ............0...
0x6fa69f60: 02 00 00 00 30 1c d2 6f 30 32 a5 75 00 00 00 00  |  ....0..o02.u....
0x6fa69f70: 38 03 00 00 00 00 00 00 78 9f a6 6f 78 9f a6 6f  |  8.......x..ox..o
Region #176 [0x6fa65290] from #175 (malloc_header) magic off 0
M-size    : 0x6487
Region #177 [0x706f33c0] from #158 (%eax) dump off 0x00000034
0x706f33a0: 00 00 00 00 00 00 00 00 30 88 92 6e d8 bb 8f 70  |  ........0..n...p
0x706f33b0: 3e 89 80 09 00 00 00 00 45 36 27 18 b8 33 6f 70  |  >.......E6'..3op
0x706f33c0: 00 bc 8f 70 a0 cf 70 75 00 00 00 00 00 00 00 00  |  ...p..pu........
0x706f33d0: a0 cf 70 75 9d c9 a3 15 64 00 00 00 64 00 00 00  |  ..pu....d...d...
0x706f33e0: 3c 01 00 00 40 01 00 00 00 00 00 00 c4 00 00 00  |  <...@...........
0x706f33f0: c4 00 00 00 04 00 00 00 40 00 00 00 00 00 00 00  |  ........@.......
0x706f3400: 40 00 50 00 45 02 00 00 8f 03 00 00 00 00 00 00  |  @.P.E...........
0x706f3410: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706f3420: 4e 41 54 20 78 6c 61 74 65 00 00 00 00 00 00 00  |  NAT xlate.......
0x706f3430: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #178 [0x706efc80] from #158 (%eax) dump off 0x00000038
0x706efc60: 00 00 00 00 44 fb 6e 70 81 af 14 01 00 00 00 00  |  ....D.np........
0x706efc70: 00 00 00 00 80 2a b0 75 00 00 00 00 c0 33 6f 70  |  .....*.u.....3op
0x706efc80: 80 7b ac 75 00 00 00 00 00 00 00 00 00 00 00 00  |  .{.u............
0x706efc90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706efca0: 00 00 00 00 ff ff ff ff c0 79 bb 0a 80 fc 6e 70  |  .........y....np
0x706efcb0: 01 41 80 00 ff ff ff ff c0 bd c0 bd 00 00 00 00  |  .A..............
0x706efcc0: ff ff ff ff 34 c7 71 6e 78 da 9c 9b c0 ae 4d 70  |  ....4.qnx.....Mp
0x706efcd0: 48 1b 6a 74 00 00 00 00 0a 07 0a cb 00 00 00 00  |  H.jt............
0x706efce0: 00 00 00 00 00 00 00 00 50 9b 97 74 00 00 00 00  |  ........P..t....
0x706efcf0: 4b 62 e2 ba 00 00 00 00 d4 34 4f 74 a6 65 85 09  |  Kb.......4Ot.e..
Region #179 [0x706eb5e0] from #178 (malloc_header) magic off 0
0x706eb5c0: c0 30 6e 70 c0 31 6e 70 c0 32 6e 70 c0 33 6e 70  |  .0np.1np.2np.3np
0x706eb5d0: 00 00 00 ef cd 1c a1 00 d0 d4 40 47 bb 7d 00 00  |  ..........@G.}..
0x706eb5e0: 23 01 1c a1 87 7d 00 00 00 00 00 00 00 00 00 00  |  #....}..........
0x706eb5f0: 90 52 a6 6f 20 3e 8f 70 c2 88 80 09 00 00 00 00  |  .R.o >.p........
0x706eb600: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706eb610: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706eb620: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706eb630: 00 00 00 00 00 00 00 00 45 36 27 18 00 b6 6e 70  |  ........E6'...np
0x706eb640: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706eb650: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
malloc_header:0x706eb5e0
M-size    : 0x7d87
Region #181 [ID:0x0abb79c0] from #158 (%eax) dump off 0x00000060
0x0abb79a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0abb79b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0abb79c0: aa 00 00 00 bc 02 00 00 40 c9 6e 70 00 60 ac 75  |  ........@.np.`.u
0x0abb79d0: 3c 01 00 00 8f 03 00 00 06 09 00 00 5e 01 00 00  |  <...........^...
0x0abb79e0: c0 33 6f 70 c4 00 00 00 00 00 00 00 00 00 00 00  |  .3op............
0x0abb79f0: 40 5e f3 08 80 5d f3 08 00 bd 23 08 f0 c6 23 08  |  @^...]....#...#.
0x0abb7a00: 30 a1 80 09 90 83 80 09 80 8d 80 09 00 00 00 00  |  0...............
0x0abb7a10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0abb7a20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x0abb7a30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #182 [0x706f1440] from #158 (%eax) dump off 0x00000064
0x706f1420: 00 00 00 00 04 13 6f 70 35 bc 14 01 d4 9f a6 6f  |  ......op5......o
0x706f1430: d4 9f a6 6f 00 9f a6 6f 00 00 00 00 c0 33 6f 70  |  ...o...o.....3op
0x706f1440: 80 fc 6e 70 00 00 00 00 00 00 00 00 00 00 00 00  |  ..np............
0x706f1450: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706f1460: 00 00 00 00 ff ff ff ff c0 79 bb 0a 40 14 6f 70  |  .........y..@.op
0x706f1470: 01 41 80 00 ff ff ff ff c0 d5 c0 d5 00 00 00 00  |  .A..............
0x706f1480: ff ff ff ff 34 c7 71 6e 6b e6 64 1e c0 ae 4d 70  |  ....4.qnk.d...Mp
0x706f1490: 48 1b 6a 74 00 00 00 00 0a 07 0a cb 00 00 00 00  |  H.jt............
0x706f14a0: 00 00 00 00 00 00 00 00 50 9b 97 74 00 00 00 00  |  ........P..t....
0x706f14b0: 4b 62 e2 ba 00 00 00 00 d4 34 4f 74 a6 65 85 09  |  Kb.......4Ot.e..
Region #183 [0x706eb5e0] from #182 (malloc_header) magic off 0
M-size    : 0x7d87
Region #186 [0xd5c0d5c0] from #158 (%eax) dump off 0x00000070
0xd5c0d5a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xd5c0d5b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xd5c0d5c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xd5c0d5d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xd5c0d5e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xd5c0d5f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xd5c0d600: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xd5c0d610: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xd5c0d620: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xd5c0d630: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #188 [0x6e71c734] from #158 (%eax) dump off 0x0000007c
0x6e71c714: 30 c7 71 6e 9e 9a b2 09 54 c8 71 6e 84 c8 71 6e  |  0.qn....T.qn..qn
0x6e71c724: ac c8 71 6e d0 c7 71 6e 00 00 00 00 01 80 ad 01  |  ..qn..qn........
0x6e71c734: 84 c8 71 6e 84 c8 71 6e 51 00 00 00 00 00 00 00  |  ..qn..qnQ.......
0x6e71c744: 00 00 00 00 82 ca 71 6e 00 00 00 00 00 00 00 00  |  ......qn........
0x6e71c754: ff ff ff ff 00 00 00 20 00 00 00 00 00 00 00 00  |  ....... ........
0x6e71c764: 00 00 00 00 20 00 00 00 00 00 00 00 a0 1a a5 74  |  .... ..........t
0x6e71c774: 00 00 00 00 00 00 00 00 62 ef a7 08 af 00 00 00  |  ........b.......
0x6e71c784: e8 c9 71 6e 58 d4 71 6e 51 00 00 00 01 00 00 00  |  ..qnX.qnQ.......
0x6e71c794: e4 c9 71 6e ff ff ff ff ae c9 00 6e 0c a9 66 75  |  ..qn.......n..fu
0x6e71c7a4: 00 00 00 00 00 00 00 00 00 00 00 01 f1 cd da 09  |  ................
Region #189 [0x6e6fd960] from #188 (malloc_header) magic off 0
0x6e6fd940: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e6fd950: 00 00 00 00 ef cd 1c a1 d0 d4 40 47 33 00 02 00  |  ..........@G3...
0x6e6fd960: 23 01 1c a1 00 00 02 00 00 00 00 00 00 00 00 00  |  #...............
0x6e6fd970: 98 7f 6b 6e 08 e4 f5 6e 81 97 06 08 00 00 00 00  |  .&#127;kn...n........
0x6e6fd980: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e6fd990: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e6fd9a0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e6fd9b0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e6fd9c0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6e6fd9d0: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
malloc_header:0x6e6fd960
M-size    : 0x20000
M-allocd  : 0x08069781
Region #191 [0x6f140808] from #0 deep dump off 0x00000024
0x6f1407e8: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f1407f8: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f140808: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f140818: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f140828: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f140838: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f140848: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f140858: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f140868: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f140878: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
Region #192 [0x6f13eec8] from #191 (malloc_header) magic off 0
0x6f13eea8: 8c 81 00 00 00 00 00 00 01 00 00 00 07 00 00 00  |  ................
0x6f13eeb8: ef cd 1c a1 00 00 00 00 d0 d4 40 47 33 40 00 00  |  ..........@G3@..
0x6f13eec8: 23 01 1c a1 00 40 00 00 00 00 00 00 00 00 00 00  |  #....@..........
0x6f13eed8: 30 ad 13 6f 60 30 14 6f 81 97 06 08 00 00 00 00  |  0..o`0.o........
0x6f13eee8: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f13eef8: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f13ef08: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f13ef18: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f13ef28: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
0x6f13ef38: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
malloc_header:0x6f13eec8
M-size    : 0x4000
Region #193 [0xa5e04070] from #0 deep dump off 0x00000028
0xa5e04050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa5e04060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa5e04070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa5e04080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa5e04090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa5e040a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa5e040b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa5e040c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa5e040d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0xa5e040e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #194 [0x740a5e08] from #0 deep dump off 0x0000002c
0x740a5de8: 23 01 1c a1 18 3d 00 00 00 00 00 00 00 00 00 00  |  #....=..........
0x740a5df8: 48 41 2c 71 c0 48 12 74 30 15 9c 08 00 00 00 00  |  HA,q.H.t0.......
0x740a5e08: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x740a5e18: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x740a5e28: ff ff ff ff 18 3d 00 00 08 5e 0a 74 7c 40 d9 0a  |  .....=...^.t|@..
0x740a5e38: 7c 40 d9 0a 00 00 00 00 00 00 00 00 00 00 00 00  |  |@..............
0x740a5e48: 2c 00 00 00 94 26 9b 74 54 47 12 74 00 00 00 00  |  ,....&.tTG.t....
0x740a5e58: 08 5e 0a 74 73 69 6e 67 6c 65 5f 76 66 00 00 00  |  .^.tsingle_vf...
0x740a5e68: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x740a5e78: 00 00 00 00 00 00 00 00 e0 d3 88 74 01 00 00 00  |  ...........t....
Region #196 [0x706f1300] from #0 deep dump off 0x00000034
0x706f12e0: 00 00 00 00 c4 11 6f 70 81 af 14 01 00 00 00 00  |  ......op........
0x706f12f0: 00 00 00 00 80 2a b0 75 00 00 00 00 c0 33 6f 70  |  .....*.u.....3op
0x706f1300: ef be ad de 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706f1310: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706f1320: 00 00 00 00 ff ff ff ff c0 79 bb 0a 00 13 6f 70  |  .........y....op
0x706f1330: 00 41 00 00 01 00 00 00 cb dc cb dc 00 00 00 00  |  .A..............
0x706f1340: ff ff ff ff 34 c7 71 6e 97 ac d7 ee c0 ae 4d 70  |  ....4.qn......Mp
0x706f1350: 48 1b 6a 74 00 00 00 00 0a 07 04 0a 00 00 00 00  |  H.jt............
0x706f1360: 00 00 00 00 00 00 00 00 50 9b 97 74 00 00 00 00  |  ........P..t....
0x706f1370: 4b 62 e2 ba 00 00 00 00 d4 34 4f 74 a6 65 85 09  |  Kb.......4Ot.e..
Region #197 [0x706eb5e0] from #196 (malloc_header) magic off 0
M-size    : 0x7d87
Dumping contents of valid xlate pointer:
0x706f1380: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706f1390: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x706f13a0: 00 00 00 00 11 95 24 cc 00 00 00 00 00 00 00 00  |  ......$.........
0x706f13b0: 00 00 00 00 0c 08 a1 74 48 55 a4 74 3c ee 6e 70  |  .......tHU.t<.np
0x706f13c0: bc 18 6f 70 80 45 a4 74 00 00 00 00 11 95 24 cc  |  ..op.E.t......$.
0x706f13d0: 00 00 00 00 00 00 00 00 00 00 00 00 14 67 06 06  |  .............g..
0x706f13e0: 08 5e 0a 74 01 00 00 00 97 ac d7 ee 01 00 00 00  |  .^.t............
0x706f13f0: b9 9b 48 4a 00 e0 e2 08 40 00 00 00 00 28 e2 08  |  ..HJ....@....(..
0x706f1400: 40 00 00 00 30 75 00 00 00 00 00 00 00 00 00 00  |  @...0u..........
0x706f1410: 02 00 00 00 68 03 a9 6f 18 14 6f 70 18 14 6f 70  |  ....h..o..op..op
0x706f1430: d4 9f a6 6f 00 9f a6 6f 00 00 00 00 c0           |  ...o...o.....
Xlate-Refcnt        : 1
Xlate-Flags         : 4100
Xlate-DiagFlags     : 0
Xlate-NatPolicy              : 0x74a44580
0x74a44580: 01 00 00 00 02 00 00 00 01 00 00 00 48 1b 6a 74  |  ............H.jt
0x74a44590: 50 9b 97 74 00 00 00 00 60 59 9e 74 00 00 00 00  |  P..t....`Y.t....
0x74a445a0: 80 45 a4 74 08 5a 9e 74 18 62 a4 74 01 00 00 00  |  .E.t.Z.t.b.t....
0x74a445b0: 01 00 00 00 01 00 00 00 00 00 00 00 00 00 04 01  |  ................
0x74a445c0: 06 00 00 00 58 50 00 00 2a 34 00 00 38 46 a4 74  |  ....XP..*4..8F.t
0x74a445d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a445e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a445f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a44600: 00 00 00 00 ff ff ff ff ef                       |  .........
Xlate-NatPool              : 0x74a1080c
0x74a1080c: 00 00 00 00 00 00 00 00 b8 0a a1 74 05 00 00 00  |  ...........t....
0x74a1081c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a1082c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a1083c: 00 00 00 00 70 07 a1 74 00 00 00 00 00 70 c9 b2  |  ....p..t.....p..
0x74a1084c: 8b 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a1085c: 00 00 00 00 00 00 00 00 00 00 00 00 22 02 00 00  |  ............"...
0x74a1086c: 00 00 00 00 00 00 00 00 00 00 00 00 18 01 00 00  |  ................
0x74a1087c: 7c 08 a1 74 7c 08 a1 74 00 00 00 00 00 00 00 00  |  |..t|..t........
0x74a1088c: 00 00 00 00 00 00 00 00 00 00 00 00 ef cd 1c a1  |  ................
0x74a1089c: c0 80 01 03 d0 d4 40 47 fb 00 00 00 23 01 1c a1  |  ......@G....#...
0x74a108ac: c8 00 00 00 00 00 00 00 00 00 00 00 40 d5 8a 6e  |  ............@..n
0x74a108bc: a0 09 a1 74 62 9f 23 08 06 0c 18 30 00 00 00 00  |  ...tb.#....0....
0x74a108cc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x74a108dc: 00 00 00 00 00 00 00 00 00 00 00 00 70 07 a1 74  |  ............p..t
0x74a108ec: 01 00 00 00 00 00 00 00 00 02 00 00 11 00 00 00  |  ................
0x74a108fc: 01 00 00 00 11 01 00 00 11 00 00 00 6e 09 a1 74  |  ............n..t
0x74a1090c: fc ff 00 00 00                                   |  .....
Xlate-HostSrc    : 0x6fa69f00
H-addr    : 0xa04070a
H-refcnt  : 4
H-tcpmss  : 1380
Region #198 [0x6e71d7a8] from #0 deep dump off 0x0000003c
0x6e71d788: 00 a8 42 08 ca 41 00 00 00 be 42 05 00 00 00 00  |  ..B..A....B.....
0x6e71d798: 22 4c 85 10 00 00 00 00 08 14 6f 70 40 e0 a5 08  |  "L........op@...
0x6e71d7a8: 18 d8 71 6e 57 48 14 09 08 14 6f 70 94 83 00 00  |  ..qnWH....op....
0x6e71d7b8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e71d7c8: 00 00 00 00 f8 d7 71 6e 7c 0e aa 6f f8 40 93 6e  |  ......qn|..o.@.n
0x6e71d7d8: 00 00 00 00 00 00 00 00 7c 0e aa 6f 00 00 00 00  |  ........|..o....
0x6e71d7e8: 14 00 00 00 68 03 a9 6f 00 66 42 07 ca 41 00 00  |  ....h..o.fB..A..
0x6e71d7f8: 00 a2 42 08 ca 41 00 00 fa 46 85 10 94 83 00 00  |  ..B..A...F......
0x6e71d808: 00 00 00 00 a8 74 a7 ba e5 00 00 00 40 00 4b 74  |  .....t......@.Kt
0x6e71d818: a8 d8 71 6e b9 ea 27 08 8c d8 71 6e 21 d0 00 00  |  ..qn..'...qn!...
Region #199 [0x6e6fd960] from #198 (malloc_header) magic off 0
M-size    : 0x20000
Region #200 [TX:0x08a5e1ac] from #0 deep dump off 0x00000040
0x08a5e18c: 9a 3b 83 d6 00 8d 87 08 01 00 00 89 04 24 89 5c  |  .;...........$.\
0x08a5e19c: 24 08 89 74 24 0c c7 44 24 04 40 e0 a5 08 e8 21  |  $..t$..D$.@....!
0x08a5e1ac: 16 f6 ff 8b 45 ec 85 c0 75 9a 8b 87 b8 00 00 00  |  ....E...u.......
0x08a5e1bc: 89 04 24 e8 fc 67 fe ff 3c ff 89 c2 74 86 8b 45  |  ..$..g..<...t..E
0x08a5e1cc: cc 89 44 24 30 0f b6 87 df 00 00 00 89 44 24 2c  |  ..D$0........D$,
0x08a5e1dc: 0f b6 87 de 00 00 00 89 44 24 28 0f b7 87 dc 00  |  ........D$(.....
0x08a5e1ec: 00 00 89 44 24 24 8d 87 c8 00 00 00 89 44 24 20  |  ...D$$.......D$
0x08a5e1fc: 8d 87 a0 00 00 00 89 44 24 1c 0f b7 47 3a 89 44  |  .......D$...G:.D
0x08a5e20c: 24 18 8d 47 6c 89 44 24 14 8b 47 68 89 44 24 10  |  $..Gl.D$..Gh.D$.
0x08a5e21c: 0f b7 47 38 89 44 24 0c 8d 47 54 89 44 24 08 8b  |  ..G8.D$..GT.D$..
Region #201 [TX:0x08a5e0c4] from #200 (Corrupt Xlate) magic off 0
0x08a5e0a4: 01 0f 84 95 00 00 00 8b 56 2c 8d 87 fc fe ff ff  |  ........V,......
0x08a5e0b4: 29 f0 8b 7c 02 28 85 ff 0f 84 8e 00 00 00 81 3f  |  )..|.(.........?
0x08a5e0c4: ef be ad de 0f 84 8a 00 00 00 8b 47 2c 8b 40 2c  |  ...........G,.@,
0x08a5e0d4: 85 c0 74 07 83 88 80 00 00 00 01 60 e8 6b 3a 60  |  ..t........`.k:`
0x08a5e0e4: ff 61 c7 44 24 04 b0 4f b5 09 c7 04 24 b1 17 b4  |  .a.D$..O....$...
0x08a5e0f4: 09 e8 56 ed 60 ff 8d 87 3c 01 00 00 89 44 24 04  |  ..V.`...<....D$.
0x08a5e104: 89 3c 24 e8 a4 fd 60 ff c7 04 24 f4 4c b5 09 e8  |  .<$...`...$.L...
0x08a5e114: 38 ed 60 ff 89 3d 40 74 d3 0a c7 44 24 08 cd 00  |  8.`..=@t...D$...
0x08a5e124: 00 00 c7 44 24 04 c2 17 b4 09 c7 04 24 61 b3 b0  |  ...D$.......$a..
0x08a5e134: 09 e8 16 b3 e0 00 8d b6 00 00 00 00 c7 44 24 04  |  .............D$.
Xlate pointer out of bounds
Region #202 [TX:0x08a5e040] from #0 deep dump off 0x00000048
0x08a5e020: 00 00 00 c7 04 24 4f 01 00 00 05 ac 02 00 00 89  |  .....$O.........
0x08a5e030: 44 24 0c e8 58 ec 81 ff 31 d2 e9 7b ff ff ff 90  |  D$..X...1..{....
0x08a5e040: 55 89 e5 57 56 53 83 ec 7c 8b 7d 08 8d 4d e0 0f  |  U..WVS..|.}..M..
0x08a5e050: 31 89 01 89 51 04 8b 55 e4 8b 45 e0 8b 0d 20 27  |  1...Q..U..E... '
0x08a5e060: 03 0b c7 45 ec 01 00 00 00 0f ac d0 0a c1 ea 0a  |  ...E............
0x08a5e070: 89 55 bc 8b 75 bc 89 45 b8 f7 e1 0f af f1 89 45  |  .U..u..E.......E
0x08a5e080: d0 8b 45 d0 01 f2 89 55 d4 8b 55 d4 8d b7 f8 fe  |  ..E....U..U.....
0x08a5e090: ff ff 89 45 e0 89 f0 89 55 e4 8d 55 ec e8 4e 4e  |  ...E....U..U..NN
0x08a5e0a0: ff ff 83 e8 01 0f 84 95 00 00 00 8b 56 2c 8d 87  |  ............V,..
0x08a5e0b0: fc fe ff ff 29 f0 8b 7c 02 28 85 ff 0f 84 8e 00  |  ....)..|.(......
Region #206 [UK:0x69894b20] from #0 deep dump off 0x00000058
0x69894b00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894b10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894b20: 00 00 00 00 cc cc bb bb a9 e4 04 00 04 4e 89 69  |  .............N.i
0x69894b30: 52 55 89 69 78 f5 27 08 78 f5 27 08 02 00 00 00  |  RU.ix.'.x.'.....
0x69894b40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894b50: b0 ab 84 09 40 b0 72 6e 00 00 00 00 00 00 00 00  |  ....@.rn........
0x69894b60: 00 00 00 00 ff ff ff ff ff ff ff ff 00 00 00 00  |  ................
0x69894b70: 00 00 00 00 00 00 00 00 20 4f 89 69 00 00 00 00  |  ........ O.i....
0x69894b80: 20 4f 89 69 20 4f 89 69 20 4f 89 69 00 00 00 00  |   O.i O.i O.i....
0x69894b90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Block     : 0x69894b20
B-base    : 0x69894e04
B-size    : 1870
B-rptr    : 0x69894f20
B-hptr    : 0x69894f20
B-allocd  : 0x0827f578
B-freed   : 0x0827f578
B-location: 0x00000087
B-meta    : 0x0
B-flags2  : 0x0
B-input   :
B-output  :
Region #207 [UK:0x69894bc0] ext-dump 0 of (Block) from #206
0x69894ba0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894bb0: c8 00 30 01 50 4c 89 69 00 00 00 00 00 00 00 00  |  ..0.PL.i........
0x69894bc0: 00 00 00 00 00 00 00 00 00 00 00 00 ff ff ff ff  |  ................
0x69894bd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894be0: 87 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894bf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894c00: 00 00 00 00 00 00 00 00 00 00 00 00 20 4f 89 69  |  ............ O.i
0x69894c10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894c20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x69894c30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #208 [UK:0x69894f20] ext-dump 1 of (Block) from #206
0x69894f00: f3 50 08 0a 00 1b 2a 34 d1 35 08 00 45 00 00 a0  |  .P....*4.5..E...
0x69894f10: 8b 15 40 00 40 32 88 07 4b 62 e2 ba 6b 0a 8d e8  |  ..@.@2..Kb..k...
0x69894f20: e1 a5 36 c7 00 0b b2 2f 89 aa 0c b9 0f 7c 11 14  |  ..6..../.....|..
0x69894f30: a2 bf ef dc 91 a3 c2 1b e7 0b 38 ff 0d 72 ef e8  |  ..........8..r..
0x69894f40: 41 b3 7f d0 69 24 63 60 db 18 c1 5f 6a 0b f3 9f  |  A.&#127;.i$c`..._j...
0x69894f50: 12 5b 24 97 81 37 81 f6 5d 9d 66 a4 b4 45 be 30  |  .[$..7..].f..E.0
0x69894f60: ee 0f 5d 72 ba 91 cc 7e ae 83 b2 de 89 a0 8f 8e  |  ..]r...~........
0x69894f70: 8d 9b 66 62 32 9a e3 cb e0 31 8d fe d6 27 d3 be  |  ..fb2....1...'..
0x69894f80: 34 48 dc 1e e5 4c 02 4e 91 e3 d4 b8 11 6d c2 d7  |  4H...L.N.....m..
0x69894f90: d3 5c ec f2 78 99 7d 02 c7 b5 57 e3 6f 3d 64 2c  |  .\..x.}...W.o=d,
Region #210 [0x6e730d40] from #0 deep dump off 0x00000064
0x6e730d20: f2 d5 55 08 00 00 00 00 00 00 00 00 00 00 00 00  |  ..U.............
0x6e730d30: 00 00 00 00 00 00 00 00 45 36 27 18 28 0d 73 6e  |  ........E6'.(.sn
0x6e730d40: 00 50 f6 68 01 00 00 00 00 01 00 00 09 00 00 00  |  .P.h............
0x6e730d50: 02 04 00 00 00 d0 a0 69 58 16 73 6e 00 00 00 00  |  .......iX.sn....
0x6e730d60: 00 f0 a0 69 88 1a 73 6e 40 00 00 00 00 00 00 00  |  ...i..sn@.......
0x6e730d70: 40 0d 73 6e a0 a1 55 08 00 00 00 9a ff ff ff ff  |  @.sn..U.........
0x6e730d80: 98 00 00 00 60 0e 24 69 00 84 a0 69 97 00 00 00  |  ....`.$i...i....
0x6e730d90: e9 00 00 00 e9 00 00 00 ec 13 73 6e 40 b0 72 6e  |  ..........sn@.rn
0x6e730da0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e730db0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #211 [0x6e730d08] from #210 (malloc_header) magic off 0
0x6e730ce8: 4c 00 40 6e 88 57 72 6e 23 01 ee f3 60 f7 72 6e  |  L.@n.Wrn#...`.rn
0x6e730cf8: 00 00 00 00 ef cd ee f3 20 00 00 00 82 07 00 00  |  ........ .......
0x6e730d08: 23 01 1c a1 53 07 00 00 00 00 00 00 00 00 00 00  |  #...S...........
0x6e730d18: 28 f7 72 6e f8 22 73 6e f2 d5 55 08 00 00 00 00  |  (.rn."sn..U.....
0x6e730d28: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e730d38: 45 36 27 18 28 0d 73 6e 00 50 f6 68 01 00 00 00  |  E6'.(.sn.P.h....
0x6e730d48: 00 01 00 00 09 00 00 00 02 04 00 00 00 d0 a0 69  |  ...............i
0x6e730d58: 58 16 73 6e 00 00 00 00 00 f0 a0 69 88 1a 73 6e  |  X.sn.......i..sn
0x6e730d68: 40 00 00 00 00 00 00 00 40 0d 73 6e a0 a1 55 08  |  @.......@.sn..U.
0x6e730d78: 00 00 00 9a ff ff ff ff 98 00 00 00 60 0e 24 69  |  ............`.$i
malloc_header:0x6e730d08
M-size    : 0x753
M-allocd  : 0x0855d5f2
Region #212 [0x6e71d768] from #0 deep dump off 0x0000006c
0x6e71d748: 68 d7 71 6e 8a 2f 56 08 00 00 00 00 d8 17 0f 69  |  h.qn./V........i
0x6e71d758: 68 d7 71 6e e8 00 4b 74 54 21 04 e5 20 00 00 00  |  h.qn..KtT!.. ...
0x6e71d768: 00 e0 e2 08 40 00 00 00 20 f5 6d 6e 30 75 00 00  |  ....@... .mn0u..
0x6e71d778: 00 a8 42 08 ca 41 00 00 e0 f8 6d 6e 00 41 00 00  |  ..B..A....mn.A..
Region #213 [0x6e6fd960] from #212 (malloc_header) magic off 0
M-size    : 0x20000
Region #214 [TX:0x08562f88] from #0 deep dump off 0x00000070
0x08562f68: 0a 85 c9 0f 84 a7 00 00 00 ba 01 00 00 00 89 f0  |  ................
0x08562f78: e8 e3 c5 ff ff 83 7e 0c 02 76 1d 89 f0 e8 46 82  |  ......~..v....F.
0x08562f88: ff ff 85 c0 74 a2 8b 46 4c 8b 16 89 82 18 28 00  |  ....t..FL.....(.
0x08562f98: 00 31 c0 eb 95 8d 76 00 89 f0 e8 29 82 ff ff 85  |  .1....v....)....
0x08562fa8: c0 74 85 8b 46 4c 8b 96 f4 05 00 00 89 82 28 01  |  .t..FL........(.
0x08562fb8: 00 00 31 c0 e9 71 ff ff ff 8d b4 26 00 00 00 00  |  ..1..q.....&....
0x08562fc8: 89 fa e8 41 91 ff ff 89 47 10 31 c0 e9 59 ff ff  |  ...A....G.1..Y..
0x08562fd8: ff 8d b4 26 00 00 00 00 8b 5e 50 8b 56 54 89 d8  |  ...&.....^P.VT..
0x08562fe8: 29 d0 89 c1 03 4e 08 39 d3 0f 4c c1 89 07 31 c0  |  )....N.9..L...1.
0x08562ff8: e9 35 ff ff ff 8d 76 00 8b 46 58 8b 10 89 17 0f  |  .5....v..FX.....
Region #215 [UK:0x690f17d8] from #0 deep dump off 0x00000078
0x690f17b8: 23 01 1c a1 2c 01 00 00 00 00 00 00 00 00 00 00  |  #...,...........
0x690f17c8: 00 00 00 00 e0 92 19 69 24 f2 56 08 00 00 00 00  |  .......i$.V.....
0x690f17d8: 00 93 19 69 00 1b 2a 34 d1 31 00 1b 2a 34 d1 31  |  ...i..*4.1..*4.1
0x690f17e8: 98 8d 19 69 88 90 19 69 40 8e 19 69 ad fb ca de  |  ...i...i@..i....
0x690f17f8: 00 00 00 00 04 00 00 00 00 00 00 00 04 00 00 00  |  ................
0x690f1808: ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x690f1818: 00 00 00 00 ad fb ca de 00 00 00 00 04 00 00 00  |  ................
0x690f1828: 00 00 00 00 05 00 00 00 ff ff 00 00 00 00 00 00  |  ................
0x690f1838: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x690f1848: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #216 [0x6e71d768] from #0 deep dump off 0x0000007c
Region #217 [0x6e6fd960] from #216 (malloc_header) magic off 0
M-size    : 0x20000
Region #218 [0x744b00e8] from #0 deep dump off 0x00000080
0x744b00c8: 23 01 1c a1 64 01 00 00 00 00 00 00 00 00 00 00  |  #...d...........
0x744b00d8: 40 fe 4a 74 08 4a 4b 74 64 03 28 08 00 00 00 00  |  @.Jt.JKtd.(.....
0x744b00e8: 20 f5 6d 6e 00 00 00 00 00 00 00 00 ff ff ff ff  |   .mn............
0x744b00f8: ff ff ff ff 00 00 00 00 00 00 00 00 ff ff ff ff  |  ................
0x744b0108: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x744b0118: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x744b0128: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x744b0138: 00 00 00 00 00 00 00 00 ad fb ca de 00 00 00 00  |  ................
0x744b0148: 00 00 00 00 00 00 00 00 0f 00 00 00 00 00 00 00  |  ................
0x744b0158: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #221 [TX:0x08e2e000] from #0 deep dump off 0x0000008c
0x08e2dfe0: 89 c7 e8 b9 50 4e ff 85 c0 89 c3 0f 84 0a 16 00  |  ....PN..........
0x08e2dff0: 00 89 04 24 e8 07 32 a3 00 8d 55 dc 89 54 24 08  |  ...$..2...U..T$.
0x08e2e000: 89 1c 24 89 44 24 04 e8 e4 b2 fd ff 85 c0 0f 85  |  ..$.D$..........
0x08e2e010: 6a 12 00 00 e8 87 5d a0 00 89 7c 24 08 89 c6 8b  |  j.....]...|$....
0x08e2e020: 45 dc 89 1c 24 89 44 24 04 e8 42 e9 02 00 ba 98  |  E...$.D$..B.....
0x08e2e030: 39 98 09 c7 04 24 28 93 c4 09 83 e8 01 b8 ed 6c  |  9....$(........l
0x08e2e040: 99 09 0f 45 d0 89 54 24 04 e8 72 dd a4 00 89 1c  |  ...E..T$..r.....
0x08e2e050: 24 e8 ba c6 a2 00 e8 45 5d a0 00 c7 04 24 ed 92  |  $......E]....$..
0x08e2e060: c4 09 29 f0 89 44 24 04 e8 53 dd a4 00 e9 f8 e4  |  ..)..D$..S......
0x08e2e070: ff ff e8 29 62 05 00 90 e9 ed e4 ff ff 8d 76 00  |  ...)b.........v.
Region #223 [0x6e6df520] from #0 deep dump off 0x00000094
0x6e6df500: 00 00 00 00 80 81 73 6e 40 09 4b 74 50 81 88 08  |  ......sn@.KtP...
0x6e6df510: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00  |  ................
0x6e6df520: 00 00 00 00 10 39 73 6e 40 0d 73 6e f0 30 56 08  |  .....9sn@.sn.0V.
0x6e6df530: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00  |  ................
0x6e6df540: 00 00 00 00 c0 db 71 6e e8 00 4b 74 10 18 28 08  |  ......qn..Kt..(.
0x6e6df550: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00  |  ................
0x6e6df560: 00 00 00 00 18 db 71 6e 40 00 4b 74 c0 df 27 08  |  ......qn@.Kt..'.
0x6e6df570: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00  |  ................
0x6e6df580: 00 00 00 00 10 a1 73 6e 80 fe 4a 74 e0 87 e9 08  |  ......sn..Jt....
0x6e6df590: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00  |  ................
Region #224 [0x6e6b7f98] from #223 (malloc_header) magic off 0
0x6e6b7f78: 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00  |  ................
0x6e6b7f88: 01 00 00 00 ef cd 1c a1 d0 d4 40 47 5b 80 02 00  |  ..........@G[...
0x6e6b7f98: 23 01 1c a1 27 80 02 00 00 00 00 00 00 00 00 00  |  #...'...........
0x6e6b7fa8: 70 86 5d 6e 60 d9 6f 6e c2 88 80 09 00 00 00 00  |  p.]n`.on........
0x6e6b7fb8: 45 36 27 18 b8 7f 6b 6e 00 00 00 00 00 00 00 00  |  E6'..&#127;kn........
0x6e6b7fc8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e6b7fd8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e6b7fe8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e6b7ff8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6e6b8008: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
malloc_header:0x6e6b7f98
M-size    : 0x28027
Region #226 [TX:0x0842a800] from #0 deep dump off 0x0000009c
0x0842a7e0: fd ff ff c7 44 24 04 1c 12 a3 09 c7 04 24 2e 01  |  ....D$.......$..
0x0842a7f0: 00 00 e8 79 30 e5 ff 8b 46 0c e9 e9 fc ff ff 90  |  ...y0...F.......
0x0842a800: 89 04 24 be a0 10 a3 09 e8 c3 6e f3 ff 85 c0 0f  |  ..$.......n.....
0x0842a810: 84 01 fe ff ff 8b 40 28 be d4 10 a3 09 85 c0 89  |  ......@(........
0x0842a820: 45 c0 0f 84 ee fd ff ff c7 44 24 04 20 00 00 00  |  E........D$. ...
0x0842a830: c7 04 24 01 00 00 00 e8 f4 fd 42 01 85 c0 89 c3  |  ..$.......B.....
0x0842a840: 89 c6 74 44 8b 55 c0 8b 42 18 85 c0 74 0f 89 04  |  ..tD.U..B...t...
0x0842a850: 24 e8 fa 67 43 01 85 c0 89 43 18 74 51 8b 4d c0  |  $..gC....C.tQ.M.
0x0842a860: 8b 41 04 89 43 04 8b 01 89 03 8b 41 0c 89 43 0c  |  .A..C......A..C.
0x0842a870: 8b 41 10 89 43 10 8b 45 44 c7 40 34 60 b2 42 08  |  .A..C..ED.@4`.B.
Region #227 [0xa11ccdec] from #1 deep dump off 0x00000014
Region #230 [0xa11c0120] from #1 deep dump off 0x00000020
Region #232 [0x6e6b7f98] from #1 deep dump off 0x00000030
M-size    : 0x28027
**WARNING: ptr 0x6e6b7f98 not within (mh + 1) 0x6e6b7fb8 and (unsigned char *)(mh + 1) + mh->mh_len 0x6e6dffdf
Region #233 [0x6e693dd8] from #232 (free_header) magic off 0
0x6e693db8: 00 00 00 00 00 00 00 00 00 00 00 00 ef cd 1c a1  |  ................
0x6e693dc8: d0 d4 40 47 29 00 00 00 38 14 6c 74 38 d7 94 74  |  ..@G)...8.lt8..t
0x6e693dd8: 23 01 ee f3 ad 03 00 00 bf ee b3 09 58 7f 0d 0a  |  #...........X&#127;..
0x6e693de8: 00 00 00 00 ef cd ee f3 28 00 00 00 42 00 00 00  |  ........(...B...
0x6e693df8: 23 01 1c a1 14 00 00 00 00 00 00 00 00 00 00 00  |  #...............
0x6e693e08: f8 3c 69 6e 38 3e 69 6e f1 e4 c4 08 00 00 00 00  |  .<in8>in........
0x6e693e18: 38 0a 69 6e 51 03 00 00 77 84 c7 09 7c 43 0d 0a  |  8.inQ...w...|C..
0x6e693e28: 01 00 00 00 ef cd 1c a1 d0 d4 40 47 43 00 00 00  |  ..........@GC...
0x6e693e38: 23 01 1c a1 14 00 00 00 00 00 00 00 00 00 00 00  |  #...............
0x6e693e48: f8 3d 69 6e 78 3e 69 6e f1 e4 c4 08 00 00 00 00  |  .=inx>in........
free_header:0x6e693dd8
MC-size   : 0x29
MC-pre_siz: 0x4740d4d0
Region #234 [0x6ef5e408] from #1 deep dump off 0x00000034
0x6ef5e3e8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
0x6ef5e3f8: ef cd 1c a1 00 00 00 00 d0 d4 40 47 e3 30 02 00  |  ..........@G.0..
0x6ef5e408: 23 01 1c a1 b3 30 02 00 00 00 00 00 00 00 00 00  |  #....0..........
0x6ef5e418: 60 d9 6f 6e 38 c0 fa 6e 83 8b 80 09 00 00 00 00  |  `.on8..n........
0x6ef5e428: 45 36 27 18 28 e4 f5 6e 10 15 f8 6e 00 00 00 00  |  E6'.(..n...n....
0x6ef5e438: 00 00 00 00 00 00 00 00 00 00 00 00 9d c9 a3 15  |  ................
0x6ef5e448: 00 04 00 00 00 04 00 00 78 00 00 00 88 00 00 00  |  ........x.......
0x6ef5e458: 00 04 00 00 00 00 00 00 00 00 00 00 00 04 00 00  |  ................
0x6ef5e468: 04 00 00 00 00 00 00 00 10 00 08 00 21 00 00 00  |  ............!...
0x6ef5e478: 3e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  >...............
malloc_header:0x6ef5e408
M-size    : 0x230b3
M-allocd  : 0x09808b83
**WARNING: ptr 0x6ef5e408 not within (mh + 1) 0x6ef5e428 and (unsigned char *)(mh + 1) + mh->mh_len 0x6ef814db
Region #235 [TX:0x08069780] from #1 deep dump off 0x00000038
0x08069760: b8 00 40 00 00 0f 45 d8 8b 3d bc 49 5c 0a 85 ff  |  ..@...E..=.I\...
0x08069770: 89 7d ec 0f 84 8a 03 00 00 89 1c 24 e8 ff 8e 00  |  .}.........$....
0x08069780: 00 85 c0 89 c6 0f 84 58 03 00 00 8b 45 08 89 04  |  .......X....E...
0x08069790: 24 e8 ba 4d ff ff 85 c0 89 45 f0 0f 84 1a 03 00  |  $..M.....E......
0x080697a0: 00 e8 9a 4d 7e 01 85 c0 0f 84 6e 03 00 00 8b 4d  |  ...M~.....n....M
0x080697b0: ec 89 f2 89 81 04 02 00 00 89 89 08 02 00 00 89  |  ................
0x080697c0: 71 3c 89 59 40 c7 81 c0 01 00 00 00 00 00 00 8b  |  q<.Y@...........
0x080697d0: 7d f0 89 b9 54 01 00 00 89 d9 c1 e9 02 85 c9 74  |  }...T..........t
0x080697e0: 1a 31 c0 90 8d 74 26 00 83 c0 01 c7 02 78 56 34  |  .1...t&......xV4
0x080697f0: 12 83 c2 04 39 c8 75 f0 8d 14 86 8b 4d 0c 8b 45  |  ....9.u.....M..E
End of Selective memory dump
Traceback of previous thread 'CP Threat-Detection Processing':
0: 0x08370f9a
1: 0x0806922c
Cisco Adaptive Security Appliance Software Version 9.1(1)
Device Manager Version 7.1(3)
Compiled on Wed 28-Nov-12 10:38 by builders
System image file is "disk0:/asa911-k8.bin"
Config file at boot was "startup-config"
TWD-ASA-01 up 20 hours 3 mins
Hardware:   ASA5520, 2048 MB RAM, CPU Pentium 4 Celeron 2000 MHz,
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xfff00000, 1024KB
Encryption hardware device : Cisco ASA-55xx on-board accelerator (revision 0x0)
                             Boot microcode        : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode     : CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode       : CNlite-MC-IPSECm-MAIN-2.08
                             Number of accelerators: 1
0: Ext: GigabitEthernet0/0  : address is 001b.2a34.d132, irq 9
1: Ext: GigabitEthernet0/1  : address is 001b.2a34.d133, irq 9
2: Ext: GigabitEthernet0/2  : address is 001b.2a34.d134, irq 9
3: Ext: GigabitEthernet0/3  : address is 001b.2a34.d135, irq 9
4: Ext: Management0/0       : address is 001b.2a34.d131, irq 11
5: Int: Not used            : irq 11
6: Int: Not used            : irq 5
Licensed features for this platform:
Maximum Physical Interfaces       : Unlimited      perpetual
Maximum VLANs                     : 150            perpetual
Inside Hosts                      : Unlimited      perpetual
Failover                          : Active/Active  perpetual
Encryption-DES                    : Enabled        perpetual
Encryption-3DES-AES               : Enabled        perpetual
Security Contexts                 : 2              perpetual
GTP/GPRS                          : Disabled       perpetual
AnyConnect Premium Peers          : 2              perpetual
AnyConnect Essentials             : Disabled       perpetual
Other VPN Peers                   : 750            perpetual
Total VPN Peers                   : 750            perpetual
Shared License                    : Disabled       perpetual
AnyConnect for Mobile             : Disabled       perpetual
AnyConnect for Cisco VPN Phone    : Disabled       perpetual
Advanced Endpoint Assessment      : Disabled       perpetual
UC Phone Proxy Sessions           : 2              perpetual
Total UC Proxy Sessions           : 2              perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Disabled       perpetual
Cluster                           : Disabled       perpetual
This platform has an ASA 5520 VPN Plus license.
Serial Number: JMX1120L10H
Running Permanent Activation Key: 0xa534487a 0x4860630d 0xfcb07990 0x9d28e488 0x0e0e25ac
Configuration register is 0x1
Configuration last modified by admin at 15:57:44.078 EDT Mon Sep 16 2013
------------------ show clock ------------------
05:47:18.282 EDT Tue Sep 17 2013
------------------ show crashinfo ------------------
Saved crash: 08:20:26.000 EDT Mon Sep 16 2013
------------------ show module ------------------
Mod  Card Type                                    Model              Serial No.
   0 ASA 5520 Adaptive Security Appliance         ASA5520            JMX1120L10H
Mod  MAC Address Range                 Hw Version   Fw Version   Sw Version
   0 001b.2a34.d131 to 001b.2a34.d135  2.0          1.0(11)2     9.1(1)
Mod  SSM Application Name           Status           SSM Application Version
Mod  Status             Data Plane Status     Compatibility
   0 Up Sys             Not Applicable
------------------ show memory ------------------
Free memory:        1728938048 bytes (81%)
Used memory:         418545600 bytes (19%)
Total memory:       2147483648 bytes (100%)
------------------ show conn count ------------------
149 in use, 441 most used
------------------ show xlate count ------------------
26 in use, 196 most used
------------------ show vpn-sessiondb summary ------------------
VPN Session Summary
                               Active : Cumulative : Peak Concur : Inactive
IKEv1 IPsec/L2TP IPsec       :      0 :          3 :           2
Site-to-Site VPN             :      2 :          2 :           2
  IKEv1 IPsec                :      2 :          2 :           2
Total Active and Inactive    :      2             Total Cumulative :      5
Device Total VPN Capacity    :    750
Device Load                  :     0%
Tunnels Summary
                               Active : Cumulative : Peak Concurrent
IKEv1                        :      2 :          5 :               4
IPsec                        :     12 :        306 :              12
IPsecOverNatT                :      0 :          3 :               2
Totals                       :     14 :        314
------------------ show blocks ------------------
  SIZE    MAX    LOW    CNT
     0    700    697    700
     4    300    299    299
    80    950    945    950
   256   2100   2084   2095
  1550   9801   9402   9543
  2048   1100   1100   1100
  2560   2052   2052   2052
  4096    100    100    100
  8192    100    100    100
16384    154    154    154
65536     16     16     16
CORE  LIMIT  ALLOC   HIGH    CNT       FAILED
   0  24576    105    105    105            0
------------------ show blocks queue history detail ------------------
History buffer memory usage: 2832 bytes (default)
History analysis time limit: 100 msec
Please see 'show blocks exhaustion snapshot' for more information
------------------ show interface ------------------
Interface GigabitEthernet0/0 "inside", is up, line protocol is up
  Hardware is i82546GB rev03, BW 1000 Mbps, DLY 10 usec
Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
Input flow control is unsupported, output flow control is off
MAC address 001b.2a34.d132, MTU 1500
IP address 10.7.1.2, subnet mask 255.255.0.0
3665753 packets input, 1820362916 bytes, 0 no buffer
Received 12673 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 pause input, 0 resume input
0 L2 decode drops
3458046 packets output, 1750989333 bytes, 0 underruns
0 pause output, 0 resume output
0 output errors, 0 collisions, 1 interface resets
0 late collisions, 0 deferred
9 input reset drops, 0 output reset drops, 0 tx hangs
input queue (blocks free curr/low): hardware (255/230)
output queue (blocks free curr/low): hardware (255/202)
  Traffic Statistics for "inside":
3665721 packets input, 1743981705 bytes
3458045 packets output, 1682315845 bytes
5928 packets dropped
      1 minute input rate 37 pkts/sec,  2378 bytes/sec
      1 minute output rate 41 pkts/sec,  21566 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 37 pkts/sec,  2584 bytes/sec
      5 minute output rate 41 pkts/sec,  21488 bytes/sec
      5 minute drop rate, 0 pkts/sec
  Control Point Interface States:
Interface number is 2
Interface config status is active
Interface state is active
Interface GigabitEthernet0/0.10 "VoIP", is up, line protocol is up
VLAN identifier 10
IP address 10.8.0.2, subnet mask 255.255.255.0
  Traffic Statistics for "VoIP":
0 packets input, 0 bytes
1 packets output, 28 bytes
0 packets dropped
Interface number is 8
  Control Point Vlan10 States:
Interface vlan config status is active
Interface vlan state is UP
Interface GigabitEthernet0/1 "", is administratively down, line protocol is down
Auto-Duplex, Auto-Speed
Available but not configured via nameif
MAC address 001b.2a34.d133, MTU not set
IP address unassigned
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 L2 decode drops
0 packets output, 0 bytes, 0 underruns
0 input reset drops, 0 output reset drops, 0 tx hangs
input queue (blocks free curr/low): hardware (255/255)
output queue (blocks free curr/low): hardware (255/255)
Interface number is 3
Interface config status is not active
Interface state is not active
Interface GigabitEthernet0/2 "outside2", is up, line protocol is up
MAC address 001b.2a34.d134, MTU 1500
IP address 75.XXX.XXX.58, subnet mask 255.255.255.248
1253568 packets input, 104827063 bytes, 0 no buffer
Received 7341 broadcasts, 0 runts, 0 giants
0 L2 decode drops
229102 packets output, 287393860 bytes, 0 underruns
13 input reset drops, 0 output reset drops, 0 tx hangs
output queue (blocks free curr/low): hardware (255/148)
  Traffic Statistics for "outside2":
1253359 packets input, 82078439 bytes
229102 packets output, 283216507 bytes
1195675 packets dropped
      1 minute input rate 32 pkts/sec,  2143 bytes/sec
      1 minute output rate 0 pkts/sec,  9 bytes/sec
      1 minute drop rate, 32 pkts/sec
      5 minute input rate 33 pkts/sec,  2142 bytes/sec
      5 minute output rate 0 pkts/sec,  86 bytes/sec
      5 minute drop rate, 32 pkts/sec
Interface number is 4
Interface GigabitEthernet0/3 "outside", is up, line protocol is up
MAC address 001b.2a34.d135, MTU 1500
IP address 75.XXX.XXX.186, subnet mask 255.255.255.248
3688872 packets input, 1940467468 bytes, 0 no buffer
0 L2 decode drops
3902697 packets output, 1817049996 bytes, 0 underruns
1 input reset drops, 0 output reset drops, 0 tx hangs
  Traffic Statistics for "outside":
3695726 packets input, 1872167313 bytes
3902697 packets output, 1746555040 bytes
3249 packets dropped
      1 minute input rate 41 pkts/sec,  23836 bytes/sec
      1 minute output rate 36 pkts/sec,  4112 bytes/sec
      5 minute input rate 40 pkts/sec,  23718 bytes/sec
      5 minute output rate 36 pkts/sec,  4166 bytes/sec
Interface number is 5
Interface Management0/0 "management", is down, line protocol is down
  Hardware is i82557, BW 100 Mbps, DLY 100 usec
Input flow control is unsupported, output flow control is unsupported
MAC address 001b.2a34.d131, MTU 1500
IP address 192.168.1.1, subnet mask 255.255.255.0
0 L2 decode drops
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max packets): hardware (0/0) software (0/0)
output queue (curr/max packets): hardware (1/0) software (0/0)
  Traffic Statistics for "management":
0 packets dropped
      1 minute input rate 0 pkts/sec,  0 bytes/sec
      1 minute output rate 0 pkts/sec,  0 bytes/sec
      5 minute input rate 0 pkts/sec,  0 bytes/sec
      5 minute output rate 0 pkts/sec,  0 bytes/sec
Management-only interface. Blocked 0 through-the-device packets
0 IPv4 packets originated from management network
0 IPv4 packets destined to management network
0 IPv6 packets originated from management network
0 IPv6 packets destined to management network
Interface number is 6
------------------ show cpu usage ------------------
CPU utilization for 5 seconds = 0%; 1 minute: 1%; 5 minutes: 1%
------------------ show cpu hogging process ------------------
Process:      rtcli async executor process, PROC_PC_TOTAL: 1, MAXHOG: 3, LASTHOG: 3
LASTHOG At:   09:54:47 EDT Sep 16 2013
PC:           0x0914eb33 (suspend)
Process:      rtcli async executor process, NUMHOG: 1, MAXHOG: 3, LASTHOG: 3
Call stack:   0x0806b131  0x0914eb33  0x0916bee2  0x0928e878  0x09267c79  0x0927955d  0x09268a40
              0x09294223  0x09267c79  0x0927955d  0x09268a40  0x0925fef1  0x09266f6b  0x0926716f
Process:      Unicorn Admin Handler, PROC_PC_TOTAL: 2, MAXHOG: 13, LASTHOG: 4
LASTHOG At:   15:51:46 EDT Sep 16 2013
PC:           0x084c44e2 (suspend)
Process:      Unicorn Admin Handler, NUMHOG: 2, MAXHOG: 13, LASTHOG: 4
Call stack:   0x084c44e2  0x085fb9ad  0x084c37a0  0x084b7555  0x0806f3de  0x08c70e9d  0x0806f3de
              0x0855230d  0x0854b41d  0x0854b65c  0x0854b94e  0x08551b6b  0x0806922c
Process:      Unicorn Admin Handler, PROC_PC_TOTAL: 9, MAXHOG: 36, LASTHOG: 36
LASTHOG At:   15:52:04 EDT Sep 16 2013
PC:           0x0910b21e (suspend)
Process:      Unicorn Admin Handler, NUMHOG: 9, MAXHOG: 36, LASTHOG: 36
Call stack:   0x0910b21e  0x0910b4e2  0x08552692  0x0854b41d  0x0854b65c  0x0854b94e  0x08551b6b
              0x0806922c
Process:      rtcli async executor process, PROC_PC_TOTAL: 2, MAXHOG: 4, LASTHOG: 4
LASTHOG At:   15:52:24 EDT Sep 16 2013
PC:           0x0914e19b (suspend)
Process:      rtcli async executor process, NUMHOG: 2, MAXHOG: 4, LASTHOG: 4
Call stack:   0x0806b131  0x0914e19b  0x091503dd  0x09150495  0x7459cac8
Process:      Dispatch Unit, PROC_PC_TOTAL: 2, MAXHOG: 4, LASTHOG: 4
LASTHOG At:   22:58:00 EDT Sep 16 2013
PC:           0x0827e8d2 (suspend)
Process:      Dispatch Unit, NUMHOG: 2, MAXHOG: 4, LASTHOG: 4
Call stack:   0x0827e8d2  0x0806922c
Process:      Dispatch Unit, PROC_PC_TOTAL: 29, MAXHOG: 11, LASTHOG: 3
LASTHOG At:   00:27:29 EDT Sep 17 2013
PC:           0x0827e9aa (suspend)
Process:      Dispatch Unit, NUMHOG: 29, MAXHOG: 11, LASTHOG: 3
Call stack:   0x0827e9aa  0x0806922c
Process:      Dispatch Unit, PROC_PC_TOTAL: 1, MAXHOG: 4411, LASTHOG: 4411
LASTHOG At:   05:47:16 EDT Sep 17 2013
PC:           0x0986ced9 (suspend)
Process:      Dispatch Unit, NUMHOG: 1, MAXHOG: 4411, LASTHOG: 4411
Call stack:   0x0986ced9  0x0986dcf0  0x08d8ff10  0x08db9211  0x0806456f  0x08064bba  0x08eb53a0
              0xffffe410  0x08a5e1af  0x09144857  0x0827eab9  0x0806922c
CPU hog threshold (msec):  2.844
Last cleared: None
------------------ show process ------------------
    PC       SP       STATE       Runtime    SBASE     Stack Process
Lwe 0x080596a4 0x6e6ea17c 0x0ad37aa8          0 0x6e6e6290 15760/16384 block_diag
M*  0x0983dedb 0x68b3ff2c 0x0ad38468     493339 0x6e6fd980 120632/131072 Dispatch Unit
Msi 0x08854a74 0x6e737e04 0x0ad37bd0         81 0x6e733ef8 15688/16384 WebVPN KCD Process
Mwe 0x084c6b6d 0x6e73ed9c 0x0ad37bd0          0 0x6e73af50 15680/16384 CF OIR
Mwe 0x08eafaec 0x6e742fb4 0x0abda120          0 0x6e73f0e8 16072/16384 lina_int
Mwe 0x0807209d 0x6e82dbfc 0x0ad37bd0          0 0x6e825d40 32192/32768 Reload Control Thread
Mwe 0x08086369 0x6e838bac 0x0ad3918c          0 0x6e835010 12248/16384 aaa
Mwe 0x0916ad6d 0x6f858ad4 0x0ad37bd0          2 0x6e8391a8 15056/16384 UserFromCert Thread
Mwe 0x0916ad6d 0x6f80e694 0x0ad37bd0          2 0x6e83d380 14528/16384 aaa_shim_thread
Mwe 0x080bae3c 0x6e84dfcc 0x0ad3a234          0 0x6e8460f0 32144/32768 CMGR Server Process
Mwe 0x080bd4ad 0x6e852134 0x0ad37bd0          0 0x6e84e288 15832/16384 CMGR Timer Process
Mwe 0x0816d455 0x6e86ec5c 0x0ad37bd0          0 0x6e86adb0 15832/16384 CTM Daemon
Mwe 0x081df2c5 0x6e87534c 0x0ad37bd0          0 0x6e8714c0 15624/16384 SXP CORE
Mwe 0x081d7041 0x6e87e644 0x0ad37bd0          0 0x6e87a7a8 15488/16384 RBM CORE
Mwe 0x081cde3c 0x6e8974cc 0x0ad45288          0 0x6e88f750 31704/32768 cts_task
Mwe 0x081cf2ed 0x6e89b7a4 0x0ad37bd0          0 0x6e8978e8 15672/16384 cts_timer_task
Lwe 0x0827c804 0x6e8ac24c 0x0ad4a9c0          0 0x6e8a8360 15632/16384 dbgtrace
Msi 0x0856b194 0x6e8bca1c 0x0ad37bd0        282 0x6e8b8b10 15688/16384 557mcfix
Msi 0x0856b126 0x6e8c0bc4 0x0ad37bd0          0 0x6e8bcca8 15672/16384 557statspoll
Mwe 0x0859389d 0x6e8cf67c 0x0ad37bd0          0 0x6e8c77e0 31680/32768 idfw_proc
Mwe 0x0859f56b 0x6e8d7824 0x0ad37bd0          0 0x6e8cf978 32216/32768 idfw_service
Mwe 0x085ab0e5 0x6e8db97c 0x0ad37bd0          0 0x6e8d7b10 15524/16384 idfw_adagent
Mwe 0x0820b305 0x6e8ef424 0x0ad37bd0          0 0x6e8eb568 15656/16384 cluster interface health monitor
Mwe 0x0916ad6d 0x6f241a04 0x0ad37bd0          0 0x6e939428 15280/16384 netfs_thread_init
Mwe 0x098099d5 0x6e951a94 0x0ad37bd0          0 0x6e94dc18 15848/16384 Chunk Manager
Msi 0x08cadf8e 0x6ef44024 0x0ad37bd0        533 0x6ef40138 15304/16384 PIX Garbage Collector
Mwe 0x08c89f2a 0x6ef5a304 0x0abc49c4          0 0x6ef56418 13908/16384 IP Address Assign
Mwe 0x08f10fda 0x6f0f32fc 0x0ac41198          0 0x6f0ef410 16104/16384 QoS Support Module
Mwe 0x08d3941a 0x6f0f74d4 0x0abc5928          0 0x6f0f35e8 16104/16384 Client Update Task
Lwe 0x0987e775 0x6f0fc194 0x0ad37bd0       4017 0x6f0f82e8 15608/16384 Checkheaps
Mwe 0x08f1651d 0x6f111d64 0x0ad37bd0          0 0x6f109ef8 31776/32768 Quack process
Mwe 0x08f9817d 0x6f119f1c 0x0ad37bd0         81 0x6f112090 30804/32768 Session Manager
Mwe 0x090fb11d 0x6f12620c 0x7424d7e8          5 0x6f1223c0 15464/16384 uauth
Mwe 0x09084331 0x6f12a444 0x0ac54b10          0 0x6f126558 15632/16384 Uauth_Proxy
Msp 0x090c92bf 0x6f13693c 0x0ad37bd0         59 0x6f132a20 15704/16384 SSL
Mwe 0x090f8e14 0x6f13aa84 0x0ac5cdd4          0 0x6f136bb8 15708/16384 SMTP
Mwe 0x090f312c 0x6f13ebdc 0x0ac5c0f8      30228 0x6f13ad50 14000/16384 Logger
Mwe 0x090f173d 0x6f142d64 0x0ad37bd0          0 0x6f13eee8 15784/16384  Syslog Retry Thread
Mwe 0x090ec9e5 0x6f146f2c 0x0ad37bd0          0 0x6f143080 15600/16384 Thread Logger
Mwe 0x090f6b37 0x6f16bfc4 0x0ac5c7a0          0 0x6f1680d8 15592/16384 syslogd
Mwe 0x0937cdc2 0x6f188acc 0x0ac96428          0 0x6f184c00 15328/16384 vpnlb_thread
Mwe 0x094526cc 0x6f1990fc 0x0ac9b7c8          0 0x6f195260 16024/16384 pci_nt_bridge
Mwe 0x0945a89d 0x6f19d234 0x0ad37bd0         24 0x6f1993f8 15200/16384 scansafe_poll
Mwe 0x08366895 0x6f2282e4 0x0ad37bd0          0 0x6f224458 15864/16384 TLS Proxy Inspector
Msi 0x08fb69cc 0x6f2a5944 0x0ad37bd0        159 0x6f2a1a38 15688/16384 emweb/cifs_timer
Mwe 0x08962fb4 0x6f2fa644 0x0a65c824          0 0x6f2f6768 15712/16384 netfs_mount_handler
Msi 0x0878bcf8 0x6e8b8864 0x0ad37bd0        713 0x6e8b4978 15456/16384 arp_timer
Mwe 0x0879676e 0x6e8e3cdc 0x0ad85710          0 0x6e8dfe40 16024/16384 arp_forward_thread
Mwe 0x08855766 0x6e9248ac 0x0ad8e440          0 0x6e9209e0 15768/16384 Lic TMR
Mwe 0x08855515 0x6f109c3c 0x0a658980         31 0x6f105d60 15800/16384 Lic HA Cluster
Mwe 0x090ff5e7 0x6e94d95c 0x0ac5d840          0 0x6e949a80 15672/16384 tcp_fast
Mwe 0x09108028 0x6e930e2c 0x0ac5d840          0 0x6e92cf60 15656/16384 tcp_slow
Mwe 0x09146474 0x6e85a494 0x0ac657d0          0 0x6e8565b8 16072/16384 udp_timer
Mwe 0x0812d75d 0x6e8c4cec 0x0ad37bd0          0 0x6e8c0e40 15832/16384 CTCP Timer process
Mwe 0x09317075 0x6e941504 0x0ad37bd0          0 0x6e93d668 15816/16384 L2TP data daemon
Mwe 0x093198e5 0x6e945534 0x0ad37bd0          0 0x6e941698 15816/16384 L2TP mgmt daemon
Mwe 0x09305f2e 0x70ecf844 0x0ac8af2c         63 0x70ecb998 16040/16384 ppp_timer_thread
Msi 0x0937d12d 0x70ed38a4 0x0ad37bd0        436 0x70ecf9c8 15640/16384 vpnlb_timer_thread
Mwe 0x0815acba 0x712cb0f4 0x6f12e4a0        205 0x712c7268 8864/16384 IPsec message handler
Msi 0x081735b4 0x712cf0e4 0x0ad37bd0       7486 0x712cb298 13208/16384 CTM message handler
Mwe 0x08264cc0 0x712feebc 0x0a5d67c0       1517 0x712df160 120484/131072 tmatch compile thread
Mwe 0x08f47eed 0x73fe6ee4 0x0ad37bd0          0 0x73fe3028 15848/16384 ICMP event handler
Mwe 0x092a9f4d 0x73feb06c 0x0ad37bd0          0 0x73fe71c0 15832/16384 Dynamic Filter VC Housekeeper
Mwe 0x08b34422 0x7404bf4c 0x0ad37bd0        123 0x740480a0 13536/16384 IP Background
Mwe 0x08e1c923 0x74369e34 0x0ad37bd0          0 0x74365f88 15832/16384 Crypto CA
Mwe 0x08e5bd58 0x7436dfcc 0x0ad37bd0          0 0x7436a120 15896/16384 CERT API
Mwe 0x08e1b295 0x74377f24 0x0ad37bd0          0 0x74374058 15928/16384 Crypto PKI RECV
Lsi 0x08cc2589 0x6e8dfbc4 0x0ad37bd0          5 0x6e8dbca8 15704/16384 uauth_urlb clean
Lwe 0x08c95dc6 0x6f1326e4 0x0ad37bd0        715 0x6f12e868 12408/16384 pm_timer_thread
Mwe 0x0861ab2d 0x6f11e0d4 0x0ad37bd0          2 0x6f11a228 14116/16384 IKE Common thread
Mwe 0x086532f5 0x6f122084 0x0ad37bd0       1257 0x6f11e258 15480/16384 IKE Timekeeper
Mwe 0x08641b3b 0x7442812c 0x0a654490      14708 0x74420570 24808/32768 IKE Daemon
Mwe 0x086f9223 0x6e91eafc 0x0ad37bd0         68 0x6e91afb0 11400/16384 IKEv2 Daemon
Mwe 0x086f8772 0x7442c44c 0x0ad37bd0        131 0x744285a0 15640/16384 IKEv2 DPD Client Process
Mwe 0x0909bf14 0x7444c7ac 0x0ac5a274          0 0x744488e0 16072/16384 RADIUS Proxy Event Daemon
Mwe 0x0905b923 0x74450784 0x744baf20          0 0x7444ca78 14800/16384 RADIUS Proxy Listener
Mwe 0x0909b63d 0x74454abc 0x0ad37bd0          0 0x74450c10 15832/16384 RADIUS Proxy Time Keeper
Mwe 0x0877a6e4 0x74458bb4 0x0ad856c8          0 0x74454da8 15264/16384 Integrity FW Task
Mrd 0x08370f9a 0x7449d744 0x0ad38468          0 0x74499888 14552/16384 CP Threat-Detection Processing
Mwe 0x082984ce 0x744dbd3c 0x09f9b57c          0 0x744bc600 124848/131072 ci/console
Mrd 0x08507430 0x6e8562ec 0x0ad38468        224 0x6e852420 14496/16384 fover_thread
Mrd 0x092eae2c 0x744e04bc 0x0ad38468         16 0x744dc630 15648/16384 lu_ctl
Msi 0x08cdd5cc 0x744e457c 0x0ad37bd0       8658 0x744e0660 14004/16384 update_cpu_usage
Msi 0x08cdcea4 0x744e859c 0x0ad37bd0          0 0x744e4690 15688/16384 health_check
Mwe 0x091198f5 0x744ec4fc 0x0ad37bd0         40 0x744e86c0 15604/16384 npshim_thread
Msi 0x08cdd664 0x744f850c 0x0ad37bd0          0 0x744f4720 13120/16384 NIC status poll
Mwe 0x0850171c 0x6f1018bc 0x0ad79f80          0 0x6f0fda30 16008/16384 fover_rx
Mwe 0x085032b6 0x7450861c 0x0ad7a27c          0 0x745047e0 15928/16384 fover_tx
Mwe 0x085032b6 0x7450c64c 0x0ad7a284          0 0x74508810 15928/16384 fover_tx_2
Mwe 0x084f3c9c 0x7451062c 0x0ad85ce8          0 0x7450c840 15816/16384 fover_ip
Mwe 0x0850c704 0x7451453c 0x0ad7a298          0 0x74510870 15560/16384 fover_rep
Mrd 0x085015f4 0x7451c44c 0x0ad38468        150 0x745148a0 31652/32768 fover_parse
Mwe 0x084e0aad 0x7452077c 0x0ad37bd0          0 0x7451c8d0 15832/16384 fover_fail_check
Mrd 0x084dea50 0x7452479c 0x0ad38468         40 0x74520900 16024/16384 fover_ifc_test
Mwe 0x084e2936 0x745287cc 0x0ad37bd0          0 0x74524930 15816/16384 fover_health_monitoring_thread
Mwe 0x0851d64f 0x74530bbc 0x0ad37bd0          0 0x7452cd90 15704/16384 ha_trans_ctl_tx
Mwe 0x0851d64f 0x74556c1c 0x0ad37bd0          0 0x74552df0 15704/16384 ha_trans_data_tx
Mwe 0x08513aed 0x7455ecdc 0x0ad37bd0          0 0x74556e20 32040/32768 fover_FSM_thread
Mwe 0x092eace5 0x7456779c 0x0ad85c88          0 0x7455f8b0 32456/32768 lu_rx
Lwe 0x092ead34 0x7456b7dc 0x0afe0528          0 0x745678e0 16120/16384 lu_dynamic_sync
Mwe 0x0916ad6d 0x7460f6c4 0x0ad37bd0        190 0x74594ca0 26600/32768 rtcli async executor process
Mwe 0x08fea744 0x74857764 0x0ac498c8         28 0x74853888 12776/16384 SNMP Notify Thread
Mwe 0x08785b0e 0x7490d27c 0x0ad85d6c       1501 0x749053c0 31864/32768 IP Thread
Mwe 0x0878d2de 0x74911434 0x0ad85700       1190 0x7490d558 8948/16384 ARP Thread
Mwe 0x0857089e 0x7491562c 0x0ad85d28        155 0x74911880 13064/16384 icmp_thread
Mwe 0x09147041 0x74919894 0x0ad37bd0        610 0x74915a18 15696/16384 udp_thread
Mwe 0x09102974 0x7491d70c 0x0ad85dec          0 0x74919bb0 15192/16384 tcp_thread
Mwe 0x0905b923 0x749f4fec 0x743a0ae8          0 0x749f12f0 15304/16384 EAPoUDP-sock
Mwe 0x082c07dd 0x749f8ef4 0x0ad37bd0          0 0x749f5378 15016/16384 EAPoUDP
Lwe 0x0828b634 0x749cb84c 0x0ad37bd0          4 0x749c79a0 15608/16384 dns_cache_timer
Mwe 0x08287ed9 0x749cf77c 0x0ad37bd0          0 0x749cb9d0 15576/16384 dns_process
Mwe 0x082fa14a 0x74d5df34 0x0ad37bd0         37 0x74d5a518 14096/16384 emweb/https
Mwe 0x082ef425 0x74d62ee4 0x0ad37bd0         17 0x74d5f028 15624/16384 Timekeeper
Mwe 0x0916ad6d 0x74eb2694 0x0ad37bd0        265 0x74ddf0e8 15008/16384 Unicorn Proxy Thread
Mwe 0x09145c99 0x752a1f04 0x6fa7bf00      13495 0x7529e378 12760/16384 snmp
Mwe 0x0905b923 0x752e725c 0x752e9f78        498 0x752e3650 15064/16384 IKE Receiver
Mwe 0x09110128 0x75331664 0x752fbae8          0 0x7532d948 15536/16384 listen/telnet
Mwe 0x09110128 0x75335694 0x749968a0          0 0x75331978 15536/16384 listen/ssh
Mwe 0x082a1121 0x753486e4 0x0ad37bd0         11 0x75344828 15624/16384 DHCPD Timer
Mwe 0x082a2de1 0x7535082c 0x0ad37bd0         39 0x7534c9d0 6484/16384 dhcp_daemon
Mwe 0x08b0afd3 0x7537d63c 0x0ad37bd0       1014 0x75379790 8804/16384 NTP
Mwe 0x09353964 0x755cac34 0x0ac960b8          0 0x755c2d58 32472/32768 vpnfol_thread_msg
Msi 0x0935c832 0x755ceddc 0x0ad37bd0        323 0x755caef0 15656/16384 vpnfol_thread_timer
Mwe 0x0935a892 0x755d2f04 0x0ac96100          0 0x755cf088 15992/16384 vpnfol_thread_sync
Msi 0x0935c5be 0x755d710c 0x0ad37bd0       1855 0x755d3220 15656/16384 vpnfol_thread_unsent
Lwe 0x08d22c66 0x755db234 0x0ad37bd0          4 0x755d73b8 15560/16384 vPif_stats_cleaner
Mwe 0x08776c05 0x6f18077c 0x0ad37bd0          0 0x6f17c8d0 15832/16384 Integrity Fw Timer Thread
Msi 0x089632c6 0x7450066c 0x0ad37bd0         24 0x744fc780 15656/16384 netfs_vnode_reclaim
-           -          -          -          0          -      -      DATAPATH-0-518
-           -          -          -   71720888          -      -      scheduler
-           -          -          -   72341990          -      -      total elapsed
------------------ show kernel process ------------------
PID PPID PRI  NI       VSIZE      RSS                WCHAN STAT  RUNTIME    GTIME   CGTIME COMMAND
   1    0  20   0     2084864      612           3725686580    S     3663        0        0 init
   2    0  15 - 5           0        0           3725738556    S        0        0        0 kthreadd
   3    2  15 - 5           0        0           3725692956    S        0        0        0 ksoftirqd/0
   4    2  15 - 5           0        0           3725728656    S        3        0        0 events/0
   5    2  15 - 5           0        0           3725728656    S        0        0        0 khelper
  50    2  15 - 5           0        0           3725728656    S        0        0        0 kblockd/0
  53    2  15 - 5           0        0           3726777703    S        0        0        0 kseriod
112    2  20   0           0        0           3725848262    S        0        0        0 pdflush
113    2  20   0           0        0           3725848262    S        0        0        0 pdflush
114    2  15 - 5           0        0           3725861131    S        0        0        0 kswapd0
115    2  15 - 5           0        0           3725728656    S        0        0        0 aio/0
116    2  15 - 5           0        0           3725728656    S        0        0        0 nfsiod
227    2  15 - 5           0        0           3725728656    S        0        0        0 hid_compat
228    2  15 - 5           0        0           3725728656    S        0        0        0 rpciod/0
253    1  16 - 4     1789952      620           3725997327    S        2        0        0 udevd
314  253  18 - 2     1916928      628           3725997327    S        0        0        0 udevd
319  253  18 - 2     1916928      504           3725997327    S        0        0        0 udevd
483    1  20   0     5206016     1604           4294967295    S        0        0        0 lwsmd
485  483  20   0    16736256     3604           4294967295    S       55        0        0 lwregd
510    1  20   0     2088960      516           3725686580    S        0        0        0 sh
511  510  20   0    10186752      524           4294967295    S        0        0        0 lina_monitor
513  511   0 -20  2005774336    65656           4294967295    S  7222232        0        0 lina
------------------ show kernel cgroup-controller detail ------------------
memory controller:
memory.limit_in_bytes: unlimited
memory.usage_in_bytes: 66301952   (3%)
memory.max_usage_in_bytes: 69898240   (3%)
memory.failcnt: 0
tasks:
group "normal"
  memory.usage_in_bytes: 241664   (0%)
  memory.max_usage_in_bytes: 708608   (0%)
  memory.failcnt: 0
  tasks:
       PID         RSS COMMAND
         1      626688 init
         2           0 kthreadd
         3           0 ksoftirqd/0
         4           0 events/0
         5           0 khelper
        50           0 kblockd/0
        53           0 kseriod
       112           0 pdflush
       113           0 pdflush
       114           0 kswapd0
       115           0 aio/0
       116           0 nfsiod
       227           0 hid_compat
       228           0 rpciod/0
       253      634880 udevd
       314      643072 udevd
       319      516096 udevd
       510      528384 sh
group "privileged"
  memory.usage_in_bytes: 31678464   (2%)
  memory.max_usage_in_bytes: 31682560   (2%)
  memory.failcnt: 0
  tasks:
       PID         RSS COMMAND
       511      536576 lina_monitor
       512           0 lina_monitor
       513    67239936 lina
       514           0 lina
       515           0 lina
       516           0 lina
       517           0 lina
       518           0 lina
group "restricted"
  memory.limit_in_bytes: 23068672   (1%)
  memory.usage_in_bytes: 1732608   (0%)
  memory.max_usage_in_bytes: 1908736   (0%)
  memory.failcnt: 0
  tasks:
       PID         RSS COMMAND
       483     1642496 lwsmd
       484           0 lwsmd
       485     3690496 lwregd
       487           0 lwregd
       488           0 lwregd
       489           0 lwregd
       490           0 lwregd
       491           0 lwregd
       492           0 lwsmd
       493           0 lwsmd
       494           0 lwsmd
       495           0 lwsmd
       496           0 lwsmd
cpu controller:
cpu.shares: 1024
cpuacct.usage: 72249966545801
tasks:
group "normal"
  cpu.shares: 4106
  cpuacct.usage: 14455184439   (0%)
  tasks:
       PID         RSS COMMAND
         1      626688 init
         2           0 kthreadd
         3           0 ksoftirqd/0
         4           0 events/0
         5           0 khelper
        50           0 kblockd/0
        53           0 kseriod
       112           0 pdflush
       113           0 pdflush
       114           0 kswapd0
       115           0 aio/0
       116           0 nfsiod
       227           0 hid_compat
       228           0 rpciod/0
       253      634880 udevd
       314      643072 udevd
       319      516096 udevd
       510      528384 sh
       512           0 lina_monitor
       513    67239936 lina
       514           0 lina
       515           0 lina
       516           0 lina
       517           0 lina
group "privileged"
  cpu.shares: 65696
  cpuacct.usage: 72197691496502   (100%)
  tasks:
       PID         RSS COMMAND
       518           0 lina
group "restricted"
  cpu.shares: 1024
  cpuacct.usage: 652164089   (0%)
  tasks:
       PID         RSS COMMAND
       483     1642496 lwsmd
       484           0 lwsmd
       485     3690496 lwregd
       487           0 lwregd
       488           0 lwregd
       489           0 lwregd
       490           0 lwregd
       491           0 lwregd
       492           0 lwsmd
       493           0 lwsmd
       494           0 lwsmd
       495           0 lwsmd
       496           0 lwsmd
------------------ show failover ------------------
Failover Off
Failover unit Secondary
Failover LAN Interface: not Configured
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 4 of 160 maximum
------------------ show failover history ------------------
From State                 To State                   Reason
09:44:00 EDT Sep 16 2013
Not Detected               Disabled                   No Error
------------------ show traffic ------------------
inside:
received (in 72207.320 secs):
3665721 packets          1743981705 bytes
50 pkts/sec          24033 bytes/sec
transmitted (in 72207.320 secs):
3458045 packets          1682315845 bytes
47 pkts/sec          23001 bytes/sec
VoIP:
0 packets          0 bytes
0 pkts/sec          0 bytes/sec
1 packets          28 bytes
outside2:
1253359 packets          82078439 bytes
17 pkts/sec          1017 bytes/sec
229102 packets          283216507 bytes
3 pkts/sec          3030 bytes/sec
outside:
3695726 packets          1872167313 bytes
51 pkts/sec          25035 bytes/sec
3902697 packets          1746555040 bytes
54 pkts/sec          24009 bytes/sec
management:
0 packets          0 bytes
0 packets          0 bytes
Aggregated Traffic on Physical Interface
GigabitEthernet0/0:
3665753 packets          1820362916 bytes
50 pkts/sec          25031 bytes/sec
3458046 packets          1750989333 bytes
47 pkts/sec          24011 bytes/sec
      1 minute input rate 37 pkts/sec,  3208 bytes/sec
      1 minute output rate 41 pkts/sec,  22380 bytes/sec
      5 minute input rate 37 pkts/sec,  3413 bytes/sec
      5 minute output rate 41 pkts/sec,  22301 bytes/sec
GigabitEthernet0/1:
0 packets          0 bytes
0 packets          0 bytes
GigabitEthernet0/2:
1253569 packets          104827145 bytes
17 pkts/sec          1035 bytes/sec
229102 packets          287393860 bytes
3 pkts/sec          3028 bytes/sec
      1 minute input rate 32 pkts/sec,  2737 bytes/sec
      1 minute output rate 0 pkts/sec,  12 bytes/sec
      5 minute input rate 33 pkts/sec,  2736 bytes/sec
      5 minute output rate 0 pkts/sec,  91 bytes/sec
GigabitEthernet0/3:
3688872 packets          1940467468 bytes
51 pkts/sec          26040 bytes/sec
3902697 packets          1817049996 bytes
54 pkts/sec          25045 bytes/sec
      1 minute input rate 41 pkts/sec,  24572 bytes/sec
      1 minute output rate 36 pkts/sec,  4769 bytes/sec
      5 minute input rate 40 pkts/sec,  24449 bytes/sec
      5 minute output rate 36 pkts/sec,  4815 bytes/sec
Management0/0:
0 packets          0 bytes
0 packets          0 bytes
------------------ show perfmon ------------------
PERFMON STATS:                     Current      Average
Xlates                                0/s          0/s
Connections                           3/s          5/s
TCP Conns                             2/s          3/s
UDP Conns                             0/s          1/s
URL Access                            2/s          3/s
URL Server Req                        0/s          0/s
TCP Fixup                            49/s         13/s
TCP Intercept Established Conns       0/s          0/s
TCP Intercept Attempts                0/s          0/s
TCP Embryonic Conns Timeout           0/s          0/s
HTTP Fixup                           49/s         13/s
FTP Fixup                             0/s          0/s
AAA Authen                            0/s          0/s
AAA Author                            0/s          0/s
AAA Account                           0/s          0/s
VALID CONNS RATE in TCP INTERCEPT:    Current      Average
                                       N/A         N/A
------------------ show counters ------------------
Protocol     Counter                             Value   Context
IP           IN_PKTS                            108698   Summary
IP           OUT_PKTS                            77853   Summary
IP           TO_ARP                              30929   Summary
IP           TO_UDP                              75111   Summary
IP           TO_ICMP                              2658   Summary
UDP          IN_PKTS                             75111   Summary
UDP          OUT_PKTS                            75133   Summary
ICMP         IN_PKTS                              2658   Summary
ICMP         OUT_PKTS                             2423   Summary
ICMP         PORT_UNREACH                          227   Summary
SSLERR       BAD_PROTOCOL_VERSION_NUMBER             1   Summary
SSLERR       BAD_SIGNATURE                           2   Summary
SSLALERT     RX_CLOSE_NOTIFY                         2   Summary
SSLALERT     RX_WARNING_ALERT                        2   Summary
SSLALERT     TX_CLOSE_NOTIFY                       422   Summary
SSLALERT     TX_WARNING_ALERT                      422   Summary
SSLDEV       NEW_CTX                                 1   Summary
SSL_NP       OPEN_CONN                               2   Summary
SSL_NP       HANDSHAKE_START                       436   Summary
SSL_NP       HANDSHAKE_DONE                        428   Summary
SSL_NP       DOWNSTREAM_CLOSE                     1063   Summary
SSL_NP       DOWNSTREAM_CLOSE_NEXT                 436   Summary
SSL_NP       UPSTREAM_CLOSE                        446   Summary
SSL_NP       UPSTREAM_CLOSE_NEXT                   436   Summary
SSL_NP       FREE_CONN                             436   Summary
SSL_NP       NEW_CONN_SERVER                       436   Summary
SSL_NP       IN_PKTS_RX                           2465   Summary
SSL_NP       IN_PKTS_TX                            763   Summary
SSL_NP       OUT_PKTS_RX                        517006   Summary
SSL_NP       OUT_PKTS_TX                        518292   Summary
SSL_NP       SESSIONS_CLEARED                      427   Summary
NPSHIM       CTX_ALLOC                             431   Summary
NPSHIM       CTX_FREE                              426   Summary
NPSHIM       WRITE_UNBLOCKED                      2033   Summary
NPSHIM       READ_RECV                             337   Summary
VPIF         BAD_VALUE                              75   Summary
VPIF         NOT_FOUND                          964334   Summary
IPSEC        IN_SA_CREATED                         327   Summary
IPSEC        OUT_SA_CREATED                        327   Summary
IPSEC        IN_SA_ACTIVATED                         7   Summary
SSLENC       CONTEXT_CREATED                       436   Summary
SSLENC       CONTEXT_UPDATED                       428   Summary
SSLENC       CONTEXT_DESTROYED                     436   Summary
------------------ show service-policy ------------------
Global policy:
  Service-policy: global_policy
    Class-map: inspection_default
      Inspect: ftp, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: h323 h225 _default_h323_map, packet 0, drop 0, reset-drop 0, v6-fail-close 0
               tcp-proxy: bytes in buffer 0, bytes dropped 0
        h245-tunnel-block drops 0 connection
      Inspect: h323 ras _default_h323_map, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: rsh, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: rtsp, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: sqlnet, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: skinny , packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: sunrpc, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: xdmcp, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: tftp, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: sip FreePBXsip, packet 23015, drop 0, reset-drop 0, v6-fail-close 0
        max-forwards-validation drop log, packet 0
      Inspect: http, packet 5248207, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: icmp, packet 4927, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: icmp error, packet 7574, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: pptp, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: dns _default_dns_map, packet 74455, drop 1699, reset-drop 0, v6-fail-close 0
        dns-guard, count 31146
        protocol-enforcement, drop 0
        nat-rewrite, count 0
    Class-map: class-default
      Default Queueing          Packet recieved 15840, sent 12122, attack 41
------------------ show mode ------------------
Security context mode: single
------------------ show history ------------------
------------------ show firewall ------------------
Firewall mode: Router
Cannot open disk0:/csco_config/97/bookmarks/index.ini
------------------ show startup-config errors ------------------
Reading from flash...
Configuration Compatibility Warning:
The version 9.1(2)0 configuration may contain syntax that is
not backward compatible with the 9.1(1) image that is loaded.
*** Output from config line 4, "ASA Version 9.1(2) "
WARNING: All traffic destined to the IP address of the outside interface is being redirected.
WARNING: Users may not be able to access any service enabled on the outside interface.
*** Output from config line 238, "nat (outside,outside) af..."
ssh key-exchange group dh-group1-sha1
ERROR: % Invalid Hostname
*** Output from config line 450, "ssh key-exchange group d..."
------------------ console logs ------------------
Message #1 :
Total SSMs found: 0
Message #2 :
Total NICs found: 7
Message #3 : mcwa Message #4 : i82557 Ethernet at irq 11Message #5 :   MAC: 001b.2a34.d131
Message #6 : mcwa Message #7 : i82557 Ethernet at irq  5Message #8 :   MAC: 0000.0001.0001
Message #9 : i82547GI rev00 Gigabit Ethernet @ irq11 dev 1 index 05Message #10 :  MAC: 0000.0001.0002
Message #11 : i82546GB rev03 Gigabit Ethernet @ irq09 dev 2 index 03Message #12 :  MAC: 001b.2a34.d135
Message #13 : i82546GB rev03 Gigabit Ethernet @ irq09 dev 2 index 02Message #14 :  MAC: 001b.2a34.d134
Message #15 : i82546GB rev03 Gigabit Ethernet @ irq09 dev 3 index 01Message #16 :  MAC: 001b.2a34.d133
Message #17 : i82546GB rev03 Gigabit Ethernet @ irq09 dev 3 index 00Message #18 :  MAC: 001b.2a34.d132
Message #19 : Verify the activation-key, it might take a while...
Message #20 : Running Permanent Message #21 : Activation Key: Message #22 : 0xa534487a Message #23 : 0x4860630d Message #24 : 0xfcb07990 Message #25 : 0x9d28e488 Message #26 : 0x0e0e25ac Message #27 :
Message #28 :
Licensed Message #29 : features for this platform:
Message #30 : Maximum Physical Interfaces       : Unlimited      perpetual
Message #31 : Maximum VLANs                     : 150            perpetual
Message #32 : Inside Hosts                      : Unlimited      perpetual
Message #33 : Failover                          : Active/Active  perpetual
Message #34 : Encryption-DES                    : Enabled        perpetual
Message #35 : Encryption-3DES-AES               : Enabled        perpetual
Message #36 : Security Contexts                 : 2              perpetual
Message #37 : GTP/GPRS                          : Disabled       perpetual
Message #38 : AnyConnect Premium Peers          : 2              perpetual
Message #39 : AnyConnect Essentials             : Disabled       perpetual
Message #40 : Other VPN Peers                   : 750            perpetual
Message #41 : Total VPN Peers                   : 750            perpetual
Message #42 : Shared License                    : Disabled       perpetual
Message #43 : AnyConnect for Mobile             : Disabled       perpetual
Message #44 : AnyConnect for Cisco VPN Phone    : Disabled       perpetual
Message #45 : Advanced Endpoint Assessment      : Disabled       perpetual
Message #46 : UC Phone Proxy Sessions           : 2              perpetual
Message #47 : Total UC Proxy Sessions           : 2              perpetual
Message #48 : Botnet Traffic Filter             : Disabled       perpetual
Message #49 : Intercompany Media Engine         : Disabled       perpetual
Message #50 : Cluster                           : Disabled       perpetual
Message #51 :
Message #52 :
Message #53 : Encryption hardware device : Cisco ASA-55xx on-board accelerator (revision 0x0)
Message #54 :                              Boot microcode        : CN1000-MC-BOOT-2.00
Message #55 :                              SSL/IKE microcode     : CNLite-MC-SSLm-PLUS-2.03
Message #56 :                              IPSec microcode       : CNlite-MC-IPSECm-MAIN-2.08
Message #57 :
Message #58 :
Message #59 :   ****************************** Warning *******************************
Message #60 :   This product contains cryptographic features and is
Message #61 :   subject to United States and local country laws
Message #62 :   governing, import, export, transfer, and use.
Message #63 :   Delivery of Cisco cryptographic products does not
Message #64 :   imply third-party authority to import, export,
Message #65 :   distribute, or use encryption. Importers, exporters,
Message #66 :   distributors and users are responsible for compliance
Message #67 :   with U.S. and local country laws. By using this
Message #68 :   product you agree to comply with applicable laws and
Message #69 :   regulations. If you are unable to comply with U.S.
Message #70 :   and local laws, return the enclosed items immediately.
Message #71 :
Message #72 :   A summary of U.S. laws governing Cisco cryptographic
Message #73 :   products may be found at:
Message #74 :   http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
Message #75 :
Message #76 :   If you require further assistance please contact us by
Message #77 :   sending email to export@cisco.com.
Message #78 :   ******************************* Warning *******************************
Message #79 :
Message #80 : This product includes software developed by the OpenSSL Project
Message #81 : for use in the OpenSSL Toolkit (http://www.openssl.org/)
Message #82 : Copyright (C) 1995-1998 Eric Young (eay@cryptsoft.com)
Message #83 : All rights reserved.
Message #84 : Copyright (c) 1998-2011 The OpenSSL Project.
Message #85 : All rights reserved.
Message #86 : This product includes software developed at the University of
Message #87 : California, Irvine for use in the DAV Explorer project
Message #88 : (http://www.ics.uci.edu/~webdav/)
Message #89 : Copyright (c) 1999-2005 Regents of the University of California.
Message #90 : All rights reserved.
Message #91 : Busybox, version 1.16.1, Copyright (C) 1989, 1991 Free Software Foundation, Inc.
Message #92 : 51 Franklin St, Fifth Floor, Boston, MA 02110-1301  USA
Message #93 : Busybox comes with ABSOLUTELY NO WARRANTY.
Message #94 : This is free software, and you are welcome to redistribute it under the General
Message #95 : Public License v.2 (http://www.gnu.org/licenses/gpl-2.0.html)
Message #96 : See User Manual (''Licensing'') for details.
Message #97 : DOSFSTOOLS, version 2.11, Copyright (C) 1989, 1991 Free Software Foundation, Inc.
Message #98 : 59 Temple Place, Suite 330, Boston, MA 02111-1307
Message #99 : 675 Mass Ave, Cambridge, MA 02139
Message #100 : DOSFSTOOLS comes with ABSOLUTELY NO WARRANTY.
Message #101 : This is free software, and you are welcome to redistribute it under the General
Message #102 : Public License v.2 (http://www.gnu.org/licenses/gpl-2.0.html)
Message #103 : See User Manual (''Licensing'') for details.
Message #104 : grub, version 0.94, Copyright (C) 1989, 1991 Free Software Foundation, Inc.
Message #105 : 59 Temple Place, Suite 330, Boston, MA 02111-1307
Message #106 : grub comes with ABSOLUTELY NO WARRANTY.
Message #107 : This is free software, and you are welcome to redistribute it under the General
Message #108 : Public License v.2 (http://www.gnu.org/licenses/gpl-2.0.html)
Message #109 : See User Manual (''Licensing'') for details.
Message #110 : libgcc, version 4.3, Copyright (C) 2007 Free Software Foundation, Inc.
Message #111 : libgcc comes with ABSOLUTELY NO WARRANTY.
Message #112 : This is free software, and you are welcome to redistribute it under the General
Message #113 : Public License v.2 (http://www.gnu.org/licenses/gpl-2.0.html)
Message #114 : See User Manual (''Licensing'') for details.
Message #115 : libstdc++, version 4.3, Copyright (C) 2007 Free Software Foundation, Inc.
Message #116 : libstdc++ comes with ABSOLUTELY NO WARRANTY.
Message #117 : This is free software, and you are welcome to redistribute it under the General
Message #118 : Public License v.2 (http://www.gnu.org/licenses/gpl-2.0.html)
Message #119 : See User Manual (''Licensing'') for details.
Message #120 : Linux kernel, version 2.6.29.6, Copyright (C) 1989, 1991 Free Software
Message #121 : Foundation, Inc.
Message #122 : 51 Franklin St, Fifth Floor, Boston, MA 02110-1301  USA
Message #123 : Linux kernel comes with ABSOLUTELY NO WARRANTY.
Message #124 : This is free software, and you are welcome to redistribute it under the General
Message #125 : Public License v.2 (http://www.gnu.org/licenses/gpl-2.0.html)
Message #126 : See User Manual (''Licensing'') for details.
Message #127 : module-init-tools, version 3.10, Copyright (C) 1989, 1991 Free Software
Message #128 : Foundation, Inc.
Message #129 : 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
Message #130 : module-init-tools comes with ABSOLUTELY NO WARRANTY.
Message #131 : This is free software, and you are welcome to redistribute it under the General
Message #132 : Public License v.2 (http://www.gnu.org/licenses/gpl-2.0.html)
Message #133 : See User Manual (''Licensing'') for details.
Message #134 : numactl, version 2.0.3, Copyright (C) 2008 SGI.
Message #135 : Author: Andi Kleen, SUSE Labs
Message #136 : Version 2.0.0 by Cliff Wickman, Chritopher Lameter and Lee Schermerhorn
Message #137 : numactl comes with ABSOLUTELY NO WARRANTY.
Message #138 : This is free software, and you are welcome to redistribute it under the General
Message #139 : Public License v.2 (http://www.gnu.org/licenses/gpl-2.0.html)
Message #140 : See User Manual (''Licensing'') for details.
Message #141 : pciutils, version 3.1.4, Copyright (C) 1989, 1991 Free Software Foundation, Inc.
Message #142 : 51 Franklin St, Fifth Floor, Boston, MA 02110-1301  USA
Message #143 : pciutils comes with ABSOLUTELY NO WARRANTY.
Message #144 : This is free software, and you are welcome to redistribute it under the General
Message #145 : Public License v.2 (http://www.gnu.org/licenses/gpl-2.0.html)
Message #146 : See User Manual (''Licensing'') for details.
Message #147 : readline, version 5.2, Copyright (C) 1989, 1991 Free Software Foundation, Inc.
Message #148 : 59 Temple Place, Suite 330, Boston, MA 02111 USA
Message #149 : readline comes with ABSOLUTELY NO WARRANTY.
Message #150 : This is free software, and you are welcome to redistribute it under the General
Message #151 : Public License v.2 (http://www.gnu.org/licenses/gpl-2.0.html)
Message #152 : See User Manual (''Licensing'') for details.
Message #153 : udev, version 146, Copyright (C) 1989, 1991 Free Software Foundation, Inc.
Message #154 : 51 Franklin St, Fifth Floor, Boston, MA 02110-1301  USA
Message #155 : udev comes with ABSOLUTELY NO WARRANTY.
Message #156 : This is free software, and you are welcome to redistribute it under the General
Message #157 : Public License v.2 (http://www.gnu.org/licenses/gpl-2.0.html)
Message #158 : See User Manual (''Licensing'') for details.
Message #159 : Cisco Adapative Security Appliance Software, version 9.1,
Message #160 : Copyright (c) 1996-2012 by Cisco Systems, Inc.
Message #161 : Certain components of Cisco ASA Software, Version 9.1 are licensed under the GNU
Message #162 : Lesser Public License (LGPL) Version 2.1.  The software code licensed under LGPL
Message #163 : Version 2.1 is free software that comes with ABSOLUTELY NO WARRANTY.  You can
Message #164 : redistribute and/or modify such LGPL code under the terms of LGPL Version 2.1
Message #165 : (http://www.gnu.org/licenses/lgpl-2.1.html).  See User Manual for licensing
Message #166 : details.
Message #167 :                 Restricted Rights Legend
Message #168 : Use, duplication, or disclosure by the Government is
Message #169 : subject to restrictions as set forth in subparagraph
Message #170 : (c) of the Commercial Computer Software - Restricted
Message #171 : Rights clause at FAR sec. 52.227-19 and subparagraph
Message #172 : (c) (1) (ii) of the Rights in Technical Data and Computer
Message #173 : Software clause at DFARS sec. 252.227-7013.
Message #174 :                 Cisco Systems, Inc.
Message #175 :                 170 West Tasman Drive
Message #176 :                 San Jose, California 95134-1706
: End_Crash
Overall Rating: 4 (1 ratings)
barry@nettitude... Tue, 09/17/2013 - 10:15
  • Gold, 750 points or more
Hi Garry
You're probably best off raising a TAC case, however I did find this in the 9.1(2) release notes.
CSCub98434
ASA: Nested Crash in Thread Dispatch Unit - cause: SQLNet Inspection
Fixed in 9.1(2).
You could also try turning off your application inspection process, as in my experience, most ASA crashes are caused by them.
HTH.
Barry Hesk
Intrinsic Network Solutions
recklesstuning Tue, 09/17/2013 - 10:58
unfortunatly I don't have support so I don't think thats possible for me...
