All SSIDs are not broadcasting...
Answered Question
Sep 18th, 2013
I have a  serious issue with my Cisco 4404 WLC. In from WLC, only some SSIDs are broadcasting the others are not broadcasting.... If I make a new WLAN and select it as broadcasting, but its not broadcasting correctly. I cannot see this in my device. What can be reason? Is there any restriction to the number of broadcasting SSIDs.
Correct Answer by Scott Fella about 3 years 11 months ago
That's too many SSID's.... 3-4 is max I would go.  What I would do is make sure your not using AP Groups and if you are, then make sure all the WLANS are in the ap group.  WLAN ID 1-16 will be the only SSID's that are broadcasted on the AP, and WLAN 17 and up will not be and you will need to use ap groups for that.  If this is all fine, then delete the ssid that is the issue and recreate it.  You might have too many beacons in the air causing the clients not to see certain ones.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
No... You can broadcast all your SSID's if you want by checking the box next to broadcast ssid. The problem is that your client doesn't see the ssid, correct?
Overall Rating: 5 (2 ratings)
Scott Fella Wed, 09/18/2013 - 05:24
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Well... It's bet to have only 3-4 SSID's. how many SSID's do you have? The more SSID's, the more beacons in the air and then you can have clients that see the ssid and then it disappears.
Correct Answer
Scott Fella Wed, 09/18/2013 - 05:48
  • Hall of Fame,
    2017 Wireless
lzakariya Wed, 09/18/2013 - 06:05
Yes, exactly. my clients are seeing only 2 SSIDs....remaining cannot be seen..why? How is it possible make the clients see all the WLANs?
Scott Fella Wed, 09/18/2013 - 06:10
  • Hall of Fame,
    2017 Wireless
How many ssid's do you have?  post your show wlan summary
Scott
lzakariya Wed, 09/18/2013 - 06:21
I have 10 SSIDs out of which 9 are enabled and 3 are broadcasting... But  my clients are showing only 2
Correct Answer
Scott Fella Wed, 09/18/2013 - 06:38
  • Hall of Fame,
    2017 Wireless
Scott
ericgarnel Wed, 09/18/2013 - 06:21
  • Gold, 750 points or more
Are the clients dual band and are the SSIDs bound to both radios of the AP?
If your clients are 2.4 GHz only and some SSIDs are only bound to the 802.11a/n (5 GHz), then yes, they will not see them.
More information would be helpful.
Eric
lzakariya Wed, 09/18/2013 - 06:24
SSIDs are bound to all the radios
Clients are dual band tooo
Jacob Snyder Wed, 09/18/2013 - 07:53
  • Bronze, 100 points or more
Are the WLANs in the AP group the AP is in?
lzakariya Thu, 09/19/2013 - 00:09
Scott, you are right... but I checked all this... I deleted and re-created the WLAN, but still the same issue...
maldehne Thu, 09/19/2013 - 00:14
  • Cisco Employee,
Please attach show run
What is the client you are using ?
Scott Fella Thu, 09/19/2013 - 05:16
  • Hall of Fame,
    2017 Wireless
Like Maldehne mentioned, we need to look at your configuration. Make sure you post the show run-config:
config paging disable
show run-config
Attach that as a txt file
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
