Warning message
Webauth Proxy redirection on wlc
Sep 18th, 2013
I have wireless network on cisco 5508 with ACS and external Proxy server for internet user.
I want to setup my guest network with my external proxy for mobile user. But I dont want to give external proxy config on mobile users.
I have seen in controller there is a feature where I can enable and disable web auth redirection with port. Its not working can you pls help me in that.
Sent from Cisco Technical Support Android App
Stephen Rodriguez Wed, 09/18/2013 - 21:15
  • Purple, 4500 points or more
That setting is to give the WLC other ports to listen on in case the clients have a proxy configured, not to force the client to use them to find the proxy.
You either need to return the proxy settings in the dhcp scope, or configure the proxy to listen in port 80.
Steve
Nalin Singh Mon, 11/11/2013 - 17:43
I had tried but it was not is there any other work around ...
