Warning message
John Blakley Fri, 09/20/2013 - 08:52
  • Purple, 4500 points or more
Are you wanting to use it as source/destination for the tunnel termination, or are you just wanting to advertise the loopback over the tunnel?
HTH,
John
*** Please rate all useful posts ***
csco11579831 Fri, 09/20/2013 - 08:58
hi John,
is to put in a next hop for route map,therefore, source / destination, is not it?
James,
John Blakley Fri, 09/20/2013 - 10:00
You can apply a next-hop to a tunnel interface. For example if you have 2 ends of a tunnel:
192.168.1.1 - side A
192.168.1.2 - side B
Your route-map on side A can set a next-hop to 192.168.1.2 to force traffic over the tunnel if needed....
HTH,
John
csco11579831 Fri, 09/20/2013 - 10:28
That is doesn't working,i wat just how set up a lookback whith a tunnel GRE plz,
