Warning message
New Background Image Problem - CME
Sep 20th, 2013
I am having an odd issue with CME background image. I have created the correct directories, XML file, sized thumbnail and full size. When you go to images menu on the 7961, the thumbnail is there to "select" but is blank, you can't see the image on the thumbnail, just a blank square box. When you click to select, the error message "File not found" is displayed and it obviously can't be selected. I have the exact same configuration working on 7975 phones - I merely changed images and file names for the 7961. Config is as follows:
Directory of flash:/
    1  drw-           0   Apr 1 2012 16:29:14 +10:00  GUI
   55  drw-           0   Apr 1 2012 15:23:54 +10:00  ATA
   58  drw-           0   Apr 6 2012 12:10:08 +10:00  Rings
   74  drw-           0  May 26 2012 22:42:30 +10:00  Desktops
Directory of flash:/Desktops/
   75  drw-           0  Sep 27 2012 00:50:00 +10:00  320x216x16
  79  drw-           0  Sep 27 2012 00:50:18 +10:00  320x196x4
   86  -rw-       23167  Sep 27 2012 01:36:06 +10:00  OP-Color-7975.png
   88  -rw-        4027  Sep 27 2012 01:38:02 +10:00  TN-OP-Color.png
  89  -rw-       20983  Sep 27 2012 01:38:34 +10:00  OP-BW.png
   90  -rw-        3541  Sep 27 2012 01:39:00 +10:00  TN-OP-BW.png
Directory of flash:/Desktops/320x196x4/
  193  -rw-         132  Sep 21 2013 07:47:44 +10:00  7961-List.xml
7961-List.xml
<CiscoIPPhoneImageList>
<ImageItem Image="TFTP:/Desktops/TN-OP-BW.png"
URL="TFTP:/Desktops/OP-BW.png"/>
</CiscoIPPhoneImageList>
TFTP Bindings
tftp-server flash:/Desktops/TN-OP-BW.png alias Desktops/TN-OP-BW.png
tftp-server flash:/Desktops/OP-BW.png alias Desktops/OP-BW.png
tftp-server flash:/Desktops/320x196x4/7961-List.xml alias Desktops/320x196x4/List.xml
____________________
Suggestions?
Nic.
Hythim Ali El Hadad Fri, 09/20/2013 - 16:09
  • Silver, 250 points or more
You need to put your png files and the list xml file inside flash:/Desktops/320x196x4
then in your xml file
320x196x4/TN-OP-BW.png"
URL="TFTP:/Desktops/320x196x4/OP-BW.png"/>
and no need for alias commands then,
Or you can use alias while the files on the root flash directly
Haitham
NicP270591 Fri, 09/20/2013 - 17:35
Hi Haitham,
I understand that is the default procedure for adding backgrounds, however as mentioned my 7975 deployment is setup as I have shown above, with the images in the desktops folder, and it works perfectly. I have aliased for both locating the file, and the fact that each List.xml has a different file name dependant on the phone, so multiple phones can have XML lists on the router without a name confusion.
It is my understanding the alias command should prevent any issue as to not being able to locate the file. If it works for our 7975's on this router why wouldn't it work for the 7961's?
Nic.
Hythim Ali El Hadad Sat, 09/21/2013 - 03:47
Hi NIC,
I don't know if your IP Phone will know the new List.xml file name by itself !!
So you create a directory for each phone. The directory will contain the photos [big and small sizes] beside the List.xml file
And on configuration
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x16/Large.png
tftp-server flash:Desktops/320x212x16/Small.png
you point to each file
But if you need to use alias,,
You can put the files on root flash but you should use the directory in the alias command not as you used above
So please try the first method and feed back
Haitham
