Recommendation for New Cisco Switch
Sep 22nd, 2013
Hi All,
Right now I'm using 2 cisco switches (redundant). The model for those switches is Catalyst SW-2960G-24TCL.
I'm planning to add more servers to the current network but all the ports in the two switches are occupied.
Could you please recommend a new switch with 16 ports which has similar features to the above switches, and what you think the best design will be?
Reza Sharifi Sun, 09/22/2013 - 08:10
  • Cisco Designated VIP,
    2017 LAN
The smalls switches are mostly 24 port or 48 ports.  There is 3560 8 ports but may not be good enough for servers.  So,  just get another SW-2960G-24TCL 24 port switch. This way, you are using the same IOS for all switches which makes life easier.
Leo Laohoo Sun, 09/22/2013 - 14:55
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Before doing anything, check your interface counters and make sure you don't have anything under "Total output drops".
If this counter increments periodically, then there's a significant chance your switch's buffer is unable to cope at the continuous traffic (inbound and outbound) from your servers.
