Warning message
CVP log file showing port utilization
Sep 22nd, 2013
I need to know where I can find in CVP VXML server the log file that shows VXML ports utilization.
Anyone knows which file is that?
Thank you,
Sahar Hanna
david.macias Mon, 09/23/2013 - 01:52
  • Blue, 1500 points or more
Check the OAMP logs, you might have better luck finding it there.
david
Shalid Kurunnan... Sat, 09/28/2013 - 01:04
Dear ,
From CVP omp console u can find the real time vxml port utilization.
check the statistics tab of cvp vxml server from oamp.
shalid
Nagabhushana .g Sat, 09/28/2013 - 10:50
There is folder called GlobalLogger in VXML server in that call_logYYYY-MM-DD.txt files..If you canvert this file to CSV you can see VXML port utilization for all VXML applications in use.
Logfile path..
C:\Cisco\CVP\VXMLServer\logs\GlobalCallLogger
If this helps ..please rate it.
Bhushan.
