ISDN switch types supported on MGCP
Overall Rating: 5 (1 ratings)
Carlo Poggiarelli Mon, 09/23/2013 - 05:51
  • Green, 3000 points or more
Hi.
TSS is an Ericsson Soft Switch which support the use of signaling protocol such as SIP and H.323.
Are you going to implement this System with a CUCM?
If yes you can use one of the mentioned protocol
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Carlo Poggiarelli Mon, 09/23/2013 - 06:31
Hi .
CUCM 9.x and earlier version support only Cisco Hardware with MGCP protocol
Carlo
Additionally this is a pri circuit offered by the telco and the switch type available is TSS, what is the isdn switch type that i can use on the cisco cucm or router to establish a layer 2 connection with the telco? Since i didnt see that as an option on the isdn switch type on cisco router or cucm.
Aman Soi Mon, 09/23/2013 - 06:42
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
I think you can also QSIG integration between Ericsson and Cisco Router configured as MGCP provided E1. QSIG is supported.
MGCP would be used for integration between call manager and VG 2921.
regds,
aman
Carlo Poggiarelli Mon, 09/23/2013 - 06:55
Hi.
I mentioned SIP and H.323 only because are protocols supported from both CUCM and TSS.
TSS of course supports other ISDN standard such as QSIG  which could be used to interconnect TSS with CUCM but , as Aman correctly mentioned (+5 A), you'll need a further hardware to integrate those two systems.
If you want, instead, to replace TSS with a Cisco Solution, I guess that the ISDN cirtuit actually connected to the TSS could be an E1 R2 which is applicable on a cisco Voice gateway.
Carlo
