Warning message
Disable Login in UCCX
Answered Question
Sep 23rd, 2013
We are using UCCX9.0 with CUCM 9.1
By default Agents should need to log to CAD and put ready to answer calls, can we disabe this ? I need to get calls to Agents without login, basically no neet use CAD for Agents, only Phone is enough, how can we do this ?
Regds
Correct Answer by islam.kamal about 3 years 10 months ago
Hello
1-Are you need to make you agent to login automatically without enter (ID,Pwd,Ext)?. If this please find my answer below
A- On Device - phone services - Add new -  create a new IPCC service and use the below URL http://xxx.xxx.xxx.xx:6293ipphone/jsp/sciphonexml/IPAgentLogin.jsp    , where (xxx.xxx.xxx.xx  the IP address of UCCX). After that enabled the service , then add new parameters (Ext,ID,Pwd).
B-Go to CUCM , Device-Phone-subscribe your phone to the new service whish you addes on step a. You will be asked to fill out the paramters which you added on step A. When the agent press service , select the service will log on automatically.
2-If your question to make your agents to be ready , this issue famous after no answer. Please use my below answer
paramater "Agent State after Ring No Answer* " to "Ready" state in UCCX Admin->System->System Parameter page
If my answers not meet your requirements , let me know.
Please rate all usefule information
Correct Answer by Chakshu Piplani about 3 years 10 months ago
Hi Fernando,
The agent will need to login to get calls through CCX, but they have option like either to login to phone using IPPA (one button login)
Or use CAD application on there desktop.
By using IPPA they will not need CAD on there desktop they will login to CCX through a service configured on CUCM that service will have CCX IP and they can change states through phone itself.
This doc is quite old but the config is same.
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a008029e6d5.shtml
Let me know if you need help configuring this.
There is no way for agents to take calls without IPPA or CAD for ACD.
Chuck
Please rate helpful posts and identify correct answers.
Overall Rating: 5 (8 ratings)
Correct Answer
Chakshu Piplani Mon, 09/23/2013 - 06:52
  • Cisco Employee,
Hi Fernando,
Chuck
Correct Answer
islam.kamal Mon, 09/23/2013 - 10:12
  • Red, 2250 points or more
Hello
W S H FERNANDO Tue, 09/24/2013 - 05:57
Hi Islam and Chuck
This is working fine, thanks for the support,
Cheers !!!!!!!!!!!!
Regds
Related Content
