Warning message
WLC2504 no GUI after upgrade to 7.5.102
Answered Question
Sep 23rd, 2013
Hi today I tried to upgrade software on my WLC2504 from 7.4.100 to 7.5.102 via GUI interface.
I disabled all my WLANs.
I downloaded image 7.5 with no errors, reboot device and watching console the WLC boot to new image with no errors. The CLI connection work, I was able to login asbefore but the web interface stop working, I had no respond via http or https.
Do you have any suggestion how to troubleshoot it? I had no problem in the past when I upgrade from 7.3 to 7.4
Below is my WLC sysinfo.
Primary Boot Image............................... 7.5.102.0
Backup Boot Image................................ 7.4.100.0 (default) (active)
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.100.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... WLC-2504
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
Last Reset....................................... Software reset
System Up Time................................... 0 days 1 hrs 42 mins 31 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +27 C
External Temperature............................. +31 C
Fan Status....................................... 4300 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 41
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Maximum number of APs supported.................. 15
Correct Answer by Rasika Nayanajith about 3 years 10 months ago
There is a workaround for this. You have to do the following configuration to get this working. It is required to reboot after this configuration
config network secureweb cipher-option rc4-preference enable
you can find the more detail in this post.
https://supportforums.cisco.com/message/4034423#4034423
"Chrome 29 adds TLS 1.2 support, and WLC is selecting a crypto suite over TLS 1.0 that apparently is breaking client"
Rasika
**** pls rate all useful responses ****
Overall Rating: 5 (2 ratings)
Verify if HTTP is enabled with command
show network summary
If this is not enabled try emabling this with below two commands
config network webmode enable and config network secureweb enable (must reboot if you enable https)
Hope that helps
Najaf
Please rate when applicable or helpful !!!
indiantrails Tue, 09/24/2013 - 07:26
Thanks Najaf KC
I started WLC again with 7.5 and find out that Google chrome doesn't work with new GUI interface. I tested in with Safari and works fine.
Correct Answer
Rasika Nayanajith Tue, 09/24/2013 - 12:34
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Rasika
indiantrails Wed, 09/25/2013 - 07:26
Tank you rasikanayanajith
It works perfect after change.
According to Wikipedia
http://en.wikipedia.org/wiki/Transport_Layer_Security#Cipher
This type of cipher "RC4" is insecure
Following post
http://www.cisco.com/en/US/docs/wireless/controller/5.2/configuration/guide/c52intf.html#wp1124863
I prefer to use
> config network secureweb cipher-option high enable
It is not supported by Chrome but gladly I have other web browsers that will support it
I hope next update from Google Chrome will fix that.
Thank again.
Rasika Nayanajith Wed, 09/25/2013 - 17:31
    2017 Wireless
Glad that worked for you & thanks for rating the answer.
I think it is more or less Cisco has to come up with a fix in future releases to work with TLS 1.2 supported browsers without manually configuring this workaround.
Rasika
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
