Warning message
Site-to-Site VPN Using Router and ASA
Answered Question
Sep 24th, 2013
I have a Cisco 1812 router which is setup for remote access VPN using IPSec (Cisco VPN Client), my question is can I configure a Cisco ASA 5505 to connect to the router as a site-to-site VPN.
Karl
Correct Answer by shijomon scaria about 3 years 10 months ago
Dear Karl,
Yor are right, in this case either you can created a site to site vpn tunnel between the devices or you can setup your ASA as a VPN hardware client. ie; Easy VPN.
For the same you can refer the below document.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808a61f4.shtml
Shijo.
Overall Rating: 5 (1 ratings)
karl_009 Tue, 09/24/2013 - 05:51
Hi Shijo,
Thanks for document very helpful, one last question?
Since I already have the router setup for remote access for end users to VPN into the local LAN can I use the existing setup on the router, an just configure the ASA to connect to the router.
I know on routers you can setup an Easy VPN Remote which connects to an Easy VPN Server which is what I have setup, so the ASA should be able to do the same would you agree?
Many Thanks
Karl
Karsten Iwen Tue, 09/24/2013 - 05:37
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
As mentioned by Shijo, it is no problem to do that. Just make sure that the crypto-map-sequence that you use to apply your dynamic crypto-map is always higher then the sequences you use for site-to-site. That's a config-mistake I have seen more then once.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Related Content
