Warning message
NCS Prime Infra-appliance1.3 - root password not working
Answered Question
Sep 24th, 2013
Hello!
I´m trying to get root access to ADE-OS by issuing the "root" command from CLI. But it says I´ve got the wrong password: "Permission denied (publickey,gssapi-with-mic,password)"
But as I remember its should be the password to the root account and it works using the same password to log into the NCS Prime web-gui as root.
Just to be clear:
Web-gui-access: root account works
CLI-access to ADE-OS w/ root account from CLI: password wrong ie. permisson denied
Any ideas?
Correct Answer by Rob Johnson about 3 years 10 months ago
root_disable
root_enable
root
commands you can execute from the CLI
If you don't know the root enable password, simply enter root_disable then root_enable, set yourself a new root password then enter root and boom, you're in.
There are 2 seperate root accounts::
1 to access the webui
1 to access the cli
Correct Answer by Scott Fella about 3 years 10 months ago
Overall Rating: 5 (2 ratings)
Correct Answer
Scott Fella Tue, 09/24/2013 - 05:06
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Scott Fella Tue, 09/24/2013 - 09:33
  • Hall of Fame,
    2017 Wireless
Oh I hear ya... I get worried every time I have to reboot NCS or Prime:)
Correct Answer
Rob Johnson Tue, 09/24/2013 - 15:11
  • Cisco Employee,
root_disable
root_enable
root
1 to access the cli
Rob Johnson Tue, 09/24/2013 - 15:12
  • Cisco Employee,
oh yea,
to change the password for the webui
ncs password root password
Phreddan Hm Tue, 09/24/2013 - 23:34
Thanks for the info Rob!
When I thought about it yesterday something about another password came up. I will look at it today.
Phreddan Hm Wed, 09/25/2013 - 01:05
Found the password! :-)
Thanks for all help guys!
Phreddan Hm Tue, 09/24/2013 - 23:32
Haha! Yes I always close my eyes and then open eye at the time when looking at the screen after reboot. :-)
Trending Topics - Security & Network
