Latest CME to use with AIM-CUE on 2800 series and 2600XM series
Sol Huebner
Equipment:
Cisco 2651XM
Cisco 2851
Cisco AIM-CUE (1GB)
My question is now:
Which is the latest version of CME I can use together with which version the AIM-CUE?
I already had a look at the "Cisco Unified CME and Cisco IOS Software Version Compatibility Matrix" and "Cisco Unity Express Compatibility Matrix".
According to the first link I can use the following CME version:
CME 8.6 on the Cisco 2851 as it supports IOS 15.1(4)M ?
CME 7.1 on the 2651XM as it supports IOS 12.4.25d(MD) ?
And according to the second link I can use the following AIM-CUE version:
Table 1 (Cisco Unity Express: Unified CM Express and Unified SRST Versions) tells me that
"Cisco Unified Communications Manager Express Version (on the left)" 8.6 and 7.1 support
"Cisco Unity Express Version (on the top)" 7.3 and 7.4 (so maybe also 7.4.1 as it is the latest version for the AIM-CUE)
[and CUCME 7.1 even CUE down to 3.2.x]
Questions:
Can I use AIM-CUE 7.4.1 on CUCME 8.6.x (maybe 8.6.6?) on the Cisco 2851
Can I use AIM-CUE 7.4.1 on CUCME 7.1.x on the Cisco 2651XM
As I only need <5 mailboxes do I have to buy any license for the AIM-CUE or does it just work?
(I read that CUE >7.1.x introduced another type of licensing?!)
Sorry for the questions but I tried to figure it out and searched a lot about this but I do net get the point and I just started with all that voice stuff and that is hard enough
I hope you can help me because I am confused and do not know how to get started now... If my selected versions are stupid please make a nice suggestion!
Thank you!
Jorge Armijo
Level 4
Level 4
According to the documentation:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
AIM-CUE can run up to 7.x CUE version:
Table 8. Cisco Unity Express: Hardware Requirements for AIM-CUE
Cisco Unity Express Versions
1.1.x2.0.x2.1.x2.2.x3.0.x7.x
2.3.x3.2.x
Cisco 2801
Cisco 2811
Cisco 2821
Cisco 2851
Cisco 3725
Cisco 3745
Cisco 3825
Cisco 3845
7.2 and 7.3 are special releases for AIM-CUE which supports CUCM 8.0 and 8.5 respectively
Then, the latest CME version that is compatible with CUE 7.x is CME 8.0:
Table 1: Cisco Unity Express: Unified CM Express and Unified SRST Versions
2.0.x2.1.x2.2.x2.3.x3.2.x7.0.x7.1.x7.2, 8.07.3, 7.4, 8.5, 8.6
3.1.x
Versions
and
Cisco Unified Survivable Remote Site Telephony Versions
3.0,
3.1
3.2,
3.2(1)
3.2(2)
3.3,
3.4
4.0
4.0(1), 4.0(2),
4.0(3)
4.1,
4.2
4.3/7.0
7.1
8.0
8.1
8.5, 8.6, 8.8, 9.x
Before version 4.1, Cisco Unified Communications Manager Express was known as Cisco Unified CallManager Express.
CME 8.6 on the Cisco 2851 as it supports IOS 15.1(4)M ? Yes
CME 7.1 on the 2651XM as it supports IOS 12.4.25d(MD) ? Don't think so, you may need to load the ios and run "show telephony-service", my guess is 4.x
-If you don't want to pay for the license, stay with CUE 7.0, you can doownload the licenses from cisco.com. Otherwise, yes, you'll have to buy licenses.
(I read that CUE >7.1.x introduced another type of licensing?!) Yes, a .lic file that need to be generated by the Licensing Team at cisco depending on the license UDI of the device
Hope this helps.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Jorge Armijo
Level 4
Level 4
2.3.x3.2.x
Cisco 2801
Cisco 2811
Cisco 2821
Cisco 2851
Cisco 3725
Cisco 3745
Cisco 3825
Cisco 3845
3.1.x
Versions
and
3.0,
3.1
3.2,
3.2(1)
3.2(2)
3.3,
3.4
4.0
4.0(1), 4.0(2),
4.0(3)
4.1,
4.2
4.3/7.0
7.1
8.0
8.1
8.5, 8.6, 8.8, 9.x
Hope this helps.
Jorge Armijo
Hi Jorge,
thank you for your answer!
I will try CME 7.1 on the 2851 then together with CUE 7.0.x but can someone confirm the latest CME I can use on the 2651XM together with CUE 7.0.x as my 2651XM is dead on arrival as it looks like and I only want to order a "new" one if I know if I can actually use it for this kind of use
Kind regards
