controller: WLC2106 accesspoint: AIR-CAP1602I-E-K9
we have a cisco wireless controller: WLC2106 running software version 7.0.235.0
We recently bought two new accesspoints: AIR-CAP1602I-E-K9
My reseller said they should be compatible with each other.
But when i connect them i receive these errors:
*Mar  1 00:13:18.575: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:13:18.575: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.3.4
*Mar  1 00:13:18.575: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'ITDS-WLC2106-01'running version 7.0.235.0 is rejected.
*Mar  1 00:13:18.575: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:13:18.575: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
Not in Bound state.
*Mar  1 00:13:33.571: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:13:36.579: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:13:36.647: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.3.112, mask 255.255.255.0, hostname AP4c00.829a.37ef
*Mar  1 00:13:44.571: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:13:54.571: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'ITDS-WLC2106-01'running version 7.0.235.0 is rejected.
*Mar  1 00:13:54.571: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:13:54.571: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:13:54.571: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:13:54.571: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.3.4
*Mar  1 00:13:54.575: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'ITDS-WLC2106-01'running version 7.0.235.0 is rejected.
*Mar  1 00:13:54.575: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:13:54.575: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:13:54.575: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
AP4c00.829a.37ef#
*Mar  1 00:14:04.575: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'ITDS-WLC2106-01'running version 7.0.235.0 is rejected.
*Mar  1 00:14:04.575: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:14:04.575: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:14:04.575: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:14:04.575: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.3.4
*Mar  1 00:14:14.571: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'ITDS-WLC2106-01'running version 7.0.235.0 is rejected.
*Mar  1 00:14:14.571: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:14:14.571: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:14:14.571: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:14:14.571: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.3.4
*Mar  1 00:14:14.575: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'ITDS-WLC2106-01'running version 7.0.235.0 is rejected.
*Mar  1 00:14:14.575: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:14:14.575: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:14:14.575: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
Does my controller have a software version to old for this accesspoint?
Rasika Nayanajith Wed, 09/25/2013 - 03:25
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
This is not compatible, 1600 series required  min 7.4.x WLC software version
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
2106 series controller only support upto 7.0.x software code. So you have to have 2504 WLC model (as it is the product to replace 21xx WLC)  in order to to support your AP
Rasika
**** Pls rate all useful responses ****
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
