Warning message
Add a call to queue with priority in UCCX 8.5
Answered Question
Sep 25th, 2013
I want to assign a call in queue with high priority than other, how can i do that?
I am adding customers call to a queue using "Select Resource" Method, but i dont know how can i prioritize calls.
Correct Answer by Jonathan Schulenberg about 3 years 10 months ago
Use the Set Contact Priority step. All calls are a one (1) by default so the higher the number the more important they are.
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_9_0/programming/guide/SeriesVol2.pdf
Please remember to rate helpful responses and identify helpful or correct answers.
Overall Rating: 5 (2 ratings)
Correct Answer
Jonathan Schulenberg Wed, 09/25/2013 - 06:58
  • Cisco Designated VIP,
    2017 IP Telephony
Chris Deren Wed, 09/25/2013 - 08:17
  • Hall of Fame,
    2017 IP Telephony, Contact Center, Unified Communications
Exactly (+5 for Jonathan), this has been asked many times before with some really good answers/examples.
HTH,
Chris
Muhammad Usman Wed, 10/02/2013 - 00:28
Thanks Jonathan. Kindly also confirm that i will add the "Set priority Step" before the "Select resource Step"?
Jonathan Schulenberg Wed, 10/02/2013 - 05:17
    2017 IP Telephony
In your case yes, before the Select Resource step; however, it is also possible to raise the priority within the queued branch.
