Multilink interface taking multiple input, frame and overrun errors
We have a Cisco 2811 running IOS version 15.0M(1).  We have been noticing multiple input, frame, overrun errors on the multilink interface but none on the two serial interfaces.  I'll display some commands I issued below.  Can you tell me if this is a hardware, software or provider issue?
NY2811#sh int multilink 1
Multilink1 is up, line protocol is up
  Hardware is multilink group interface
  Description: Primary WAN link
  Internet address is x.x.x.x/30
  MTU 1500 bytes, BW 3072 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 40/255, rxload 39/255
  Encapsulation PPP, LCP Open, multilink Open
  Open: IPCP, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 2 seconds on reset
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 1d00h
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 478000 bits/sec, 284 packets/sec
  5 minute output rate 487000 bits/sec, 282 packets/sec
     12825903 packets input, 2843869655 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     108796 input errors, 0 CRC, 107987 frame, 809 overrun, 0 ignored, 0 abort
     12443765 packets output, 2655074326 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 carrier transitions
NY2811#sh int s0/0/0
Serial0/0/0 is up, line protocol is up
  Hardware is GT96K with integrated T1 CSU/DSU
  Description: First T1
  MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 25/255, rxload 27/255
  Link is a member of Multilink bundle Multilink1, loopback not set
  Last input 00:00:00, output 00:00:00, output hang never
  5 minute input rate 163000 bits/sec, 82 packets/sec
  5 minute output rate 155000 bits/sec, 80 packets/sec
     6461925 packets input, 1503757355 bytes, 0 no buffer
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     6241892 packets output, 1329049826 bytes, 0 underruns
     0 output errors, 0 collisions, 177 interface resets
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
NY2811#sh int s0/1/0
Serial0/1/0 is up, line protocol is up
  Description: Second T1
     reliability 255/255, txload 23/255, rxload 23/255
  5 minute input rate 144000 bits/sec, 74 packets/sec
  5 minute output rate 139000 bits/sec, 73 packets/sec
     6463749 packets input, 1503783785 bytes, 0 no buffer
     6243632 packets output, 1329901349 bytes, 0 underruns
     0 output errors, 0 collisions, 178 interface resets
Joshua Senft Wed, 09/25/2013 - 14:19
Can you please post the interface configurations as well for each of the serial as well as the multilink interfaces? Also, provide the output of 'show ppp multi'. Thanks.
cherlerle Tue, 03/11/2014 - 09:19
Hi!
I have the same problem with Multilink input errors, can you share the solution that you implemented please?
