Prime 2.0 renders imported CAD drawing to black
Sep 26th, 2013
Hi All,
I running both Prime 1.3 and Prime 2.0 and when I import a CAD dwg drawing into
Prime 1.3 it renders fine, but doing the same in Prime 2.0 and the drawing appears with
a black background. I have checked Bug Track and found nothing, any answers ?
TIA
g.peart Thu, 09/26/2013 - 16:20
I found a fix, import CAD drawing into Prime 1.3 and then export, this exported file can now be imported in Prime 2.0, renders normally.
At least archiving of controller configurations works,
Prime 2.0 is still beta I think
dselfridge Fri, 11/15/2013 - 07:42
Having the same issue here.
Guess we'll just have to wait for 2.1 ;-)
(I'm doing a new install so exporting from 1.3 is too painful TBH)
Saurav Lodh Sun, 11/17/2013 - 23:39
  • Gold, 750 points or more
CAD file format must be AutoCAD version 2010 or earlier. Before you save a CAD file, ensure the following:
Zoom images to maximum.
Remove  unwanted layers from the CAD files, that is, layers that add  unnecessary artifacts to CAD files and layers that do not provide  significant information about the image on the CAD files.
