OK have a 4240 that I am trying to reset the password on I have followed the Cisco ROMMON reset info and here is what I get
Evaluating BIOS Options...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0
Platform IPS-4255-K9
Use BREAK or ESC to interrupt boot.
Use SPACE to begin boot immediately.
Boot interrupted.
Management0/0
Link is UP
MAC Address:000b.fcfa.d155
Use ? for help.
rommon #0> confreg 0x7
Update Config Register (0x7) in NVRAM...
rommon #1> boot
The IPS Reboots and I am asked to select one of two things
I choose the 2nd option which is IPS Recover, I am then booted into Busybox....what are the next steps? THe Cisco documentation stop after it says to type boot??
Cisco instructions
Step 1 Reboot the appliance.
Step 2 To interrupt the boot process, press ESC or Control-R (terminal server) or send a BREAK command (direct connection).
The boot code either pauses for 10 seconds or displays something similar to one of the following:
•Evaluating boot options
•Use BREAK or ESC to interrupt boot
Step 3 Enter the following commands to reset the password.
boot
My end game is to reset passwords and reset the IPS to factory defult...any help would be great
theDogger
