Warning message
internet connection / VPN connection
Answered Question
Sep 30th, 2013
hi expert,
I have a cisco router and I use it for internet and VPN
currently I have a internet access, but I don't have the VPN connection, I applied the correct configuration for the VPN.
regards,
Correct Answer by Hardi Ahmed about 3 years 10 months ago
Hi Christo,
the most important point in your configuration is to check the VPN result.
did you checked your router and along with VPN connection? you can use below commands to check the status of the PVN:
show crypto isakmp sa
show crypto ipsec sa
show crypto session
show crypto isakmp peer
also you can use debug commands
regards,
Overall Rating: 5 (2 ratings)
Correct Answer
Hardi Ahmed Mon, 09/30/2013 - 09:21
  • Gold, 750 points or more
Hi Christo,
show crypto session
regards,
