DA is globally administered
Answered Question
Sep 30th, 2013
hello everybody
i read about Ethernet_Technologies is cisco dacuments
in destination address i read about this part but i didn't understand what does that mean !
The second bit from the left indicates
whether the DA is globally administered (indicated by a 0) or locally administered (indicated by a 1).
what is it mean globally administered or locally administered
Correct Answer by Carlo Poggiarelli about 3 years 10 months ago
Glad to Help Mohammad.
Please remember to rate helpful posts and mark them as "Answered" if it gave you a solution.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Hi.
Globally administered address is the mac assigned by the manufacturer (original mac address).
Locally administered is the mac address modified by admin.
Carlo
Overall Rating: 5 (2 ratings)
Correct Answer
Carlo Poggiarelli Mon, 09/30/2013 - 07:36
  • Green, 3000 points or more
Hi.
Carlo
Correct Answer
Carlo Poggiarelli Tue, 10/01/2013 - 02:42
Carlo
