paolo bevilacqua Tue, 10/01/2013 - 07:53
  • Hall of Fame,
    Founding Member
Router is faulty and needs replacement.
Next time please use text copy and paste, not screenshots.
Leo Laohoo Tue, 10/01/2013 - 16:21
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hmmmm ... Remove all NM/NME or HWIC/EHWIC modules are try again.  If the problem persists or you don't have any modules attached, then RMA the appliance.  It's dead.
I wouldn't recommend you pop the lid and make sure the DRAM is properly inserted (or use a can of compressed air) because you risk the chance of voiding the warranty.
abentaoula Thu, 10/03/2013 - 02:17
Hello
thank you for yours reponses
effectively , after removing all modules installed on teh router, the problem persist
i think that the router must be remplaced
