Warning message
I can Ping FW inside interface but can not connect to remote resources
Sep 30th, 2013
dear all
i configer my asa 5520 through ASDM to enable VPN Connection , i follow the cisco steps and it works fine and the anyconnect version 3.1 in Windows 8 - one day troubleshoot for this point only - can connect and have an IP address from the range , but i have something wrong in NAT may be because all guides talking about old ASDM ( NAT Exempt) but i am confeused to apply it on the new ASDM.
i can ping the inside interface  from my labtop which using anyconnect , but i can not access anything else inside my network
Please anyone has a solution , please describe it using ASDM , thanks for help
This is my configuration
interface GigabitEthernet0/1
description
nameif SRV_ZONE
security-level 50
interface GigabitEthernet0/2
description
nameif TRUST_ZONE
security-level 100
ip address 172.17.200.1 255.255.255.0
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif MGMT
security-level 0
ip address 10.10.10.1 255.255.255.0
dns server-group DefaultDNS
domain-name xxx.xxx.xxx
object network obj-192.168.1.11
host 192.168.1.11
object network obj-xxx.xxx.xxx.xxx
host xxx.xxx.xxx.xxx
object service obj-tcp-source-eq-25
service tcp source eq smtp
object network obj-192.168.1.12
host 192.168.1.12
object network obj-192.168.1.0
subnet 192.168.1.0 255.255.255.0
object service obj-tcp-eq-25
service tcp destination eq smtp
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network obj-0.0.0.0
host 0.0.0.0
object network obj_any-01
object network obj-172.17.8.8
host 172.17.8.8
object network obj-172.17.0.0
subnet 172.17.0.0 255.255.0.0
object network obj_any-02
object network obj_any-03
object network obj_any-04
object network obj_any-05
object network obj_any-06
object network obj.172.17.8.115
host 172.17.8.115
object network obj.xxx.xxx.xxx.xxx
object service http
service tcp source eq www destination eq www
object service https
service tcp source eq https destination eq https
object service newservice
service tcp source eq pop3 destination eq pop3
object network mail
host 172.17.8.8
description mail
object network 192.168.1.11
host 192.168.1.11
description smtp
object service smtpnew
service tcp source eq 587 destination eq 587
object network VPN_RANGE
description VPN ACCESS RANGE
object network VPN_PoOL
subnet 172.17.16.0 255.255.255.0
description vpn
object-group network DM_INLINE_NETWORK_1
network-object host 192.168.1.11
network-object host 192.168.1.12
object-group network Eighth_Floor
network-object 172.17.8.0 255.255.255.0
object-group service WEB_SERVICES
service-object tcp destination eq www
object-group network ENT_SERVERS
object-group network DM_INLINE_NETWORK_2
network-object 172.17.200.0 255.255.255.0
object-group service DM_INLINE_TCP_2 tcp
port-object eq www
port-object eq https
port-object eq smtp
object-group service web tcp
port-object eq www
port-object eq xxx
port-object eq ftp
port-object eq xxx
port-object eq xxx
object-group service xxx_Web_and_Email
service-object object http
service-object tcp destination eq pop3
service-object tcp destination eq smtp
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object udp
protocol-object tcp
object-group protocol DM_INLINE_PROTOCOL_2
protocol-object ip
object-group protocol DM_INLINE_PROTOCOL_3
protocol-object ip
access-list DMZ_access_in extended permit ip 192.168.1.0 255.255.255.0 172.17.0.0 255.255.0.0
access-list DMZ_access_in extended permit ip 192.168.1.0 255.255.255.0 any
access-list justice_splitTunnelAcl standard permit 10.100.100.0 255.255.255.0
access-list xxx-VPN_splitTunnelAcl remark vpn
access-list xxx-VPN_splitTunnelAcl standard permit 172.17.16.0 255.255.255.0
access-list xxx-VPN_splitTunnelAcl standard permit any
access-list cap extended permit tcp any host xxx.xxx.xxx.xxx eq smtp log
access-list cap1 extended permit tcp host 192.168.1.11 any eq smtp
access-list SRV_ZONE_nat_outbound extended permit tcp 192.168.1.0 255.255.255.0 any eq smtp
access-list SRV_ZONE_nat_outbound extended permit ip host 192.168.1.11 any
access-list TRUST_ZONE_access_in extended permit ip host 172.17.88.108 any
access-list TRUST_ZONE_access_in extended permit object-group DM_INLINE_PROTOCOL_2 10.10.3.0 255.255.255.0 any
access-list TRUST_ZONE_access_in extended permit object-group DM_INLINE_PROTOCOL_3 10.10.50.0 255.255.255.0 any
access-list TRUST_ZONE_access_in extended permit ip 172.17.8.0 255.255.255.0 any
access-list TRUST_ZONE_access_in extended permit ip 172.17.200.0 255.255.255.0 any
access-list TRUST_ZONE_access_in extended permit ip 172.17.0.0 255.255.0.0 host 192.168.1.12
access-list TRUST_ZONE_cryptomap extended permit ip xxx.xxx.xxx.xxx 255.255.255.248 any
access-list outside_access_in extended permit tcp any host 192.168.1.11 eq smtp
access-list outside_access_in extended permit tcp any host 172.17.8.8 eq www
access-list outside_access_in extended permit tcp any host 192.168.1.12 object-group web
access-list outside_access_in extended permit tcp any host 172.17.8.8 eq pop3
access-list outside_access_in extended permit ip 172.17.16.0 255.255.255.0 any inactive
access-list vpn remark vpn
access-list vpn standard permit 172.17.16.0 255.255.255.0
pager lines 24
logging enable
logging trap informational
logging asdm informational
logging host TRUST_ZONE 172.17.8.100
mtu INT_ZONE 1500
mtu SRV_ZONE 1500
mtu TRUST_ZONE 1500
mtu MGMT 1500
ip local pool VPN_POOL 172.17.16.100-172.17.16.254 mask 255.255.255.0
ip verify reverse-path interface INT_ZONE
ip verify reverse-path interface SRV_ZONE
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any SRV_ZONE
icmp permit any TRUST_ZONE
asdm image disk0:/asdm-635.bin
no asdm history enable
arp timeout 14400
nat (SRV_ZONE,INT_ZONE) source static obj-192.168.1.11 obj-xxx.xxx.xxx.xxx service any obj-tcp-source-eq-25
nat (SRV_ZONE,INT_ZONE) source static obj-192.168.1.12 obj-xxx.xxx.xxx.xxx
nat (SRV_ZONE,INT_ZONE) source dynamic obj-192.168.1.0 interface service obj-tcp-eq-25 obj-tcp-eq-25
nat (INT_ZONE,SRV_ZONE) source static any any destination static 192.168.1.11 obj-172.17.8.8 service obj-tcp-source-eq-25 obj-tcp-source-eq-25
nat (TRUST_ZONE,INT_ZONE) source static VPN_PoOL VPN_PoOL destination static VPN_PoOL VPN_PoOL
nat (SRV_ZONE,INT_ZONE) dynamic obj-0.0.0.0
nat (SRV_ZONE,MGMT) dynamic obj-0.0.0.0
nat (TRUST_ZONE,INT_ZONE) static xxx.xxx.xxx.xxx service tcp www www
nat (TRUST_ZONE,SRV_ZONE) static 172.17.0.0
nat (TRUST_ZONE,INT_ZONE) dynamic interface
nat (TRUST_ZONE,SRV_ZONE) dynamic interface
nat (TRUST_ZONE,INT_ZONE) dynamic obj-0.0.0.0
nat (TRUST_ZONE,SRV_ZONE) dynamic obj-0.0.0.0
nat (TRUST_ZONE,MGMT) dynamic obj-0.0.0.0
nat (TRUST_ZONE,INT_ZONE) static obj.xxx.xxx.xxx.xxx service tcp www www
object network mail
nat (TRUST_ZONE,INT_ZONE) static obj-xxx.xxx.xxx.xxx service tcp pop3 pop3
nat (TRUST_ZONE,INT_ZONE) after-auto source static obj-172.17.8.8 obj-xxx.xxx.xxx.xxx service https https
access-group outside_access_in in interface INT_ZONE
access-group DMZ_access_in in interface SRV_ZONE
access-group TRUST_ZONE_access_in in interface TRUST_ZONE
route INT_ZONE 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx 1
route TRUST_ZONE 10.10.0.0 255.255.0.0 172.17.200.254 1
route TRUST_ZONE 10.11.0.0 255.255.0.0 172.17.200.254 1
route TRUST_ZONE 10.12.0.0 255.255.0.0 172.17.200.254 1
route TRUST_ZONE 10.13.0.0 255.255.0.0 172.17.200.254 1
route TRUST_ZONE 172.17.0.0 255.255.0.0 172.17.200.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authentication serial console LOCAL
http server enable
http 172.17.8.0 255.255.255.0 TRUST_ZONE
http 172.17.8.155 255.255.255.255 TRUST_ZONE
http 172.17.8.45 255.255.255.255 TRUST_ZONE
http 10.10.10.2 255.255.255.255 MGMT
http 192.168.1.12 255.255.255.255 SRV_ZONE
http 0.0.0.0 0.0.0.0 INT_ZONE
http 172.17.200.0 255.255.255.0 TRUST_ZONE
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map pol 1 match address TRUST_ZONE_cryptomap
crypto dynamic-map pol 1 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map INT_ZONE_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map TRUST_ZONE_map0 1 ipsec-isakmp dynamic pol
crypto map TRUST_ZONE_map0 interface TRUST_ZONE
crypto map INT_ZONE_map0 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map INT_ZONE_map0 interface INT_ZONE
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
fqdn SEC-xxx-FW1
subject-name CN=SEC-xxx-FW1
no client-types
proxy-ldc-issuer
crl configure
crypto ca trustpoint ASDM_TrustPoint1
enrollment self
keypair sslvpnkeypair
crl configure
crypto ca certificate chain ASDM_TrustPoint0
certificate 31
    57f4e52e 6b851966 77515d62 c209a0df 1c32ce94 bb90cbce 497cfd04 6745ea85
    efb75f85 2ae1ad35 344d94ab 915e01ab d3292626 ac697a52 b4ed6632 d3ed2332 ae
  quit
crypto ca certificate chain ASDM_TrustPoint1
certificate e6054352
    c64f3661 30f14c3d 06b5f039 9f14560d 3b154fd1 42782268 7531689e 8e547d91
    85e88415 e326f653 74733a6c a3f5c935 f7e83f56 f6
  quit
crypto isakmp enable INT_ZONE
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 INT_ZONE
ssh 172.17.8.0 255.255.255.0 TRUST_ZONE
ssh 10.10.10.2 255.255.255.255 MGMT
ssh timeout 5
console timeout 0
management-access TRUST_ZONE
vpn load-balancing
interface lbpublic INT_ZONE
interface lbprivate INT_ZONE
priority-queue INT_ZONE
  tx-ring-limit 256
threat-detection basic-threat
threat-detection scanning-threat
threat-detection statistics host number-of-rate 3
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_TrustPoint1 INT_ZONE
webvpn
enable INT_ZONE
svc image disk0:/anyconnect-win-2.1.0148-k9.pkg 1
svc enable
tunnel-group-list enable
group-policy xxx-VPN internal
group-policy xxx-VPN attributes
dns-server value xx.xx.xx.xx xx.xx.xx.xx
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value xxx-VPN_splitTunnelAcl
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol webvpn
group-policy GPNEW internal
group-policy GPNEW attributes
dns-server value 172.17.8.41
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
default-domain value xxx.xxx.xxx
address-pools value VPN_POOL
username VPNAM password xxx encrypted
username VPNAM attributes
service-type remote-access
vpn-group-policy xxx-VPN
tunnel-group xxx-VPN type remote-access
tunnel-group xxx-VPN general-attributes
dhcp-server 172.17.8.41
tunnel-group xxx-VPN ipsec-attributes
pre-shared-key *****
tunnel-group pol type ipsec-l2l
tunnel-group pol ipsec-attributes
trust-point ASDM_TrustPoint0
tunnel-group SSLClientProfile type remote-access
tunnel-group SSLClientProfile general-attributes
address-pool VPN_POOL
default-group-policy GPNEW
tunnel-group SSLClientProfile webvpn-attributes
group-alias SSLVPNClient enable
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect ip-options
  inspect pptp
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:78a941e3f509dec8f3570c60061eedaa
: end
ahmedshaker Tue, 10/01/2013 - 08:39
thanks god
i solve the problem
the problem is in NAT
i creat an object with the ip address host from VPN pool and name it vpn
then i do the nat from inside to that host as the following picture...
trust zone is the inside zone
vpn is the outside vpn host...
thanks and hope it helps anyone else...
Related Content
