Warning message
LMS Prime 4.2.2 Device Configuration Change Report
AFROJ AHMAD Mon, 09/30/2013 - 19:41
  • Cisco Employee,
Hi Ray ,
You can use the feature called Change Audit to achive your Goal:
Change Audit clients are RME applications that  record change  information. Applications, such as Software Management,  send messages to  Change Audit when they make a change to the network,  for example,  uploading a new Cisco IOS image.
For more information , you can check the below link:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.2/user/guide/chgaud.html#wp1031857
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.2/user/guide/chgaud.html#wp1034685
You can also create AUTOMATED Action bases on SYSLOGS to track or email the chnages to you :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.2/user/guide/syslog.html#wp1211314
Thanks-
Afroz
[Do rate the useful post]
Related Content
