Warning message
sVTI , multiple traffic selector
Oct 1st, 2013
Anyone know if it's possible to have multiple traffic selector on a sVTI ipsec site to site interface when the router(cisco 2901 15.2) is the SA initiator?
To explain a little more, I have a tunnel (ikeV2) between 174.52.148.11 and 162.23.19.133 (not my reals IPs). I want network from 172.17.0.0/16 and 192.168.0.0/24 to go through it to 192.168.17.0/24
My problem is I only manage to have one child SA, (192.168.0.0/24 === 192.168.17.0/24) instead of two ( 172.17.0.0/16 192.168.0.0/24 === 192.168.17.0/24)
Is it a VTI limitation or a bad configuration on my side??
I know it is possible to have multiple Child SA working on a single tunnel when router is not the Initiator of SA but the responder. Unfortunatly in this case, I really need to be the initiator because I'm the spoke, and hub peers are only responders (and I don't control them).
Any Help?
Thannnkks
Here a very little of my configuration:
interface Tunnel1
ip unnumbered GigabitEthernet0/0
tunnel source 174.52.148.11
tunnel mode ipsec ipv4
tunnel destination 162.23.19.133
tunnel protection ipsec profile ipsec_profile_v2
ip route 192.168.0.0 255.255.255.0 172.19.0.1
ip route 172.17.0.0 255.255.0.0 172.19.0.1
ip route 192.168.17.0 255.255.255.0 Tunnel1
ip route 10.0.0.0 255.255.255.0 Tunnel2
Here, we can see there is no Child sa for 172.17.0.0/16 network:
Tunnel-id Local                 Remote                fvrf/ivrf            Status
2         174.52.148.11/500     162.23.19.133/500      none/none            READY
      Encr: AES-CBC, keysize: 256, Hash: SHA256, DH Grp:14, Auth sign: PSK, Auth verify: PSK
      Life/Active Time: 86400/28294 sec
      CE id: 1509, Session-id: 94
      Status Description: Negotiation done
      Local spi: 0EEE5DE1703ADD9A       Remote spi: 9F6C437C48B5BF0E
      Local id: 174.52.148.11
      Remote id: 162.23.19.133
      DPD configured for 300 seconds, retry 30
      Fragmentation not configured.
      Extended Authentication not configured.
      NAT-T is not detected
      Cisco Trust Security SGT is disabled
      Initiator of SA : Yes
Child sa: local selector  192.168.0.0/0 - 192.168.0.255/65535
          remote selector 192.168.17.0/0 - 192.168.17.255/65535
          ESP spi in/out: 0xE6866A92/0xC5F8491E
          AH spi in/out: 0x0/0x0
          CPI in/out: 0x0/0x0
          Encr: AES-CBC, keysize: 256, esp_hmac: SHA96
          ah_hmac: None, comp: IPCOMP_NONE, mode tunnel
Here An exemple of multiple Child SA working on a single Tunnel when i'm not the initiator (same router than previous exemple, but different tunnel):
1        174.52.148.11/4500    177.31.193.222/4500   none/none            READY
      Remote id: 177.31.193.222
      Initiator of SA : No
          remote selector 10.0.0.0/0 - 10.0.255.255/65535
          ESP spi in/out: 0x94D543DF/0xCD2F0076
          CPI in/out: 0x0/0x0
Child sa: local selector  172.17.0.0/0 - 172.17.255.255/65535
          ESP spi in/out: 0xB7362A6/0xCD93D913
          CPI in/out: 0x0/0x0
Marcin Latosiewicz Tue, 10/01/2013 - 04:38
  • Cisco Employee,
I spoke with few wise heads (thanks Olivier P.)
What you're looking for is not supported but should be out with IOS XE 3.12  the only thing SVTI should allow you to negotaite is one "any any" TS.
That it is "working" the way you're describing is puzzling, but maybe some facilities to accomodate upcoming changes were introduced into the code.
Mind sharing "show crypto ipsec sa" ?
1000mercis Tue, 10/01/2013 - 06:32
Hi Marcin,
Thanks for you answer! I guess I'll have to deal with crypto maps again instead VTI
Here the tunnel with two Child SA (responder, but 100% static VTI, no dynamic/templates).
#show  crypto ipsec sa peer 177.31.193.222  (full output)
interface: Tunnel3
    Crypto map tag: Tunnel3-head-0, local addr 174.52.148.11
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.0.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (10.0.0.0/255.255.0.0/0/0)
  current_peer 177.31.193.222
port 4500
     PERMIT, flags={}
    #pkts encaps: 3437, #pkts encrypt: 3437, #pkts digest: 3437
    #pkts decaps: 3275, #pkts decrypt: 3275, #pkts verify: 3275
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.:174.52.148.11
, remote crypto endpt.:177.31.193.222
     plaintext mtu 1422, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0
     current outbound spi: 0xC50EDA27(3306084903)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
      spi: 0x67479324(1732743972)
        transform: esp-256-aes esp-sha-hmac ,
        in use settings ={Tunnel UDP-Encaps, }
        conn id: 3949, flow_id: Onboard VPN:1949, sibling_flags 80000040, crypto map: Tunnel3-head-0
        sa timing: remaining key lifetime (k/sec): (4256218/1911)
        IV size: 16 bytes
        replay detection support: Y
        Status: ACTIVE(ACTIVE)
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 3950, flow_id: Onboard VPN:1950, sibling_flags 80000040, crypto map: Tunnel3-head-0
        sa timing: remaining key lifetime (k/sec): (4256278/1911)
        IV size: 16 bytes
     outbound ah sas:
     outbound pcp sas:
   local  ident (addr/mask/prot/port): (172.17.0.0/255.255.0.0/0/0)
port 4500
     PERMIT, flags={}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
, remote crypto endpt.: 177.31.193.222
     current outbound spi: 0xC29B00A5(3264938149)
     inbound esp sas:
      spi: 0xF0C4E925(4039436581)
        conn id: 3948, flow_id: Onboard VPN:1948, sibling_flags 80000040, crypto map: Tunnel3-head-0
        sa timing: remaining key lifetime (k/sec): (4364292/1891)
        IV size: 16 bytes
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 3947, flow_id: Onboard VPN:1947, sibling_flags 80000040, crypto map: Tunnel3-head-0
        IV size: 16 bytes
     outbound ah sas:
     outbound pcp sas:
   local  ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
   remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
port 500
     PERMIT, flags={origin_is_acl,}
     local crypto endpt.: 174.52.148.11
     plaintext mtu 1500, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0
     current outbound spi: 0x0(0)
Marcin Latosiewicz Tue, 10/01/2013 - 06:42
  • Cisco Employee,
Julien,
What you listed above should not work reliably, you have multiple SPDs, including overlap in your SADA.
responder side could could with multi-SA DVTI ...  have not seen it working with IKEv2 but principle remains the same.
M.
Related Content
