Warning message
A problem with Switch HP 5500 EI
Oct 1st, 2013
hi everybody,
I have a problem with SW HP 5500 EI J377A. I format flash of switch. After reset, the switch can't run normal, it has norfitication as: "No correct default file to boot!", and boot menu as attach picture
I've search, but i can't have a solution to troubleshoot this problem
Can you help me please, thanks alot.
cadet alain Wed, 10/02/2013 - 04:09
  • Purple, 4500 points or more
You formatted flash so you deleted the OS so it can't boot anymore, you'll have to install a valid OS but you'll surely find the answer of how to do on a specific HP forum like Rolf told you.
Alain
