Warning message
adsl_alc_20190_6.0.010.bin firmware on Cisco 877W
Oct 1st, 2013
Hello all,
I've got Cisco 877W but it didn't like when I applied what I think is the last firmware for ST Micro -
Any suggestions?
Many thanks
Dan
My version:
#show ver
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Compiled Wed 21-Mar-12 00:53 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI3, RELEASE SOFTWARE
System returned to ROM by reload at 10:42:22 GMT Fri Mar 1 2002
System restarted at 13:58:35 BST Tue Oct 1 2013
System image file is "flash:c870-advipservicesk9-mz.151-4.M4.bin"
Last reload reason: Reload Command
Cisco 877W (MPC8272) processor (revision 2.0) with 236544K/25600K bytes of memory.
Processor board ID FCZ105123PM
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
1 802.11 Radio
128K bytes of non-volatile configuration memory.
53248K bytes of processor board System flash (Intel Strataflash)
with the adsl_alc_20190_6.0.010.bin :
#show dsl int
ATM0
Alcatel 20190 chipset information
Line has not yet been activated.
Modem Status:           Down (DMTDSL_DO_OPEN)
DSL Mode:           Unknown
Interrupts:           37291 (0 spurious)
PHY Access Err:           0
Activations:           0
LED Status:           ON
LED On Time:           100
LED Off Time:           100
Init FW:           init_AMR_6.0.010.bin
Operation FW:           AMR-E-6.0.010.bin
FW Source:           external
DSL: Training log buffer capability is not enabled
with the original 4.0.015 firware:
#show dsl int
ATM0
                     ATU-R (DS)                              ATU-C (US)
Modem Status:           Showtime (DMTDSL_SHOWTIME)
DSL Mode:           ITU G.992.3 (ADSL2) Annex A
ITU STD NUM:            0x03                                         0x2
Chip Vendor ID:           'STMI'                                         'IFTN'
Chip Vendor Specific:  0x0000                               0x71C8
Chip Vendor Country:   0x0F                               0xB5
Modem Vendor ID: 'CSCO'                                         '    '
Modem Vendor Specific: 0x0000                               0x0000
Modem Vendor Country:  0xB5                               0x00
Serial Number Near:    FCZ105123P 877W-G-E 15.1
Serial Number Far:  Chip ID:            C196 (0)
DFE BOM:           DFE3.0 Annex A (1)
Capacity Used:           99%                                         100%
Noise Margin:            5.5 dB                                6.0 dB
Output Power:           16.0 dBm                               12.5 dBm
Attenuation:           61.0 dB                               38.0 dB
FEC ES Errors:            0                                          0
ES Errors:           11                                          0
SES Errors:            1                                          0
LOSES Errors:            1                                          0
UES Errors:            0                                         43
Defect Status:           None                            None
Last Fail Code:           None
Watchdog Counter: 0xEB
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:           0x00
Interrupts:           4201 (0 spurious)
PHY Access Err:           0
Activations:           1
LED Status:           ON
LED On Time:           100
LED Off Time:           100
Init FW:           init_AMR-4.0.015_no_bist.bin
Operation FW:           AMR-4.0.015.bin
FW Source:           embedded
FW Version:           4.0.15
Dan Jagor Tue, 10/01/2013 - 09:56
I see. I assume you're refering to the ADSL firware.
Well, I've got this one from Cisco http://software.cisco.com/download/release.html?mdfid=279624018&softwareid=282821763&release=6.0.010&relind=AVAILABLE&rellifecycle=&reltype=latest
and therefore I would assume it is recomended, if anything, to use it.
I would be surprise if Cisco put on their own web something what is not official and should not be used, but I could be wrong.
Thank you for your help
Dan
paolo bevilacqua Tue, 10/01/2013 - 06:44
  • Hall of Fame,
    Founding Member
[edited due to incorrect information]
