CUCM - 8.6.2
Hi All - Recently we have installed CUCM - 8.6.2 with PUB and SUB, After the installltion when we checked the DB Replication in CLI where it shows 2 for both PUB and SUB.
When i check the GUI, It throws below Error.
All necessary services are UP and Running.
Connection to RTMT on cucm-sub could not be Established in PUB
Connection to RTMT on cucm-PUB could not be Established in SUB
Replication Status in PUB:
PUB - 2 GOOD
SUB - N/A
Replication Status in SUB:
SUB - 2 GOOD
PUB - N/A
Attached Screenshot for referrence.
SIVANESAN R
SIVANESAN R
Check this bug CSCua09290
try this from cli and show us the result
show perf queryclass "Number of Replicates Created and State of Replication"
Haitham
Hi Siva,
In addition to what Mr. Haitham has said, You can also run the command utils dbreplication runtimestate on both servers in a cluster to know the DB replication status.
If it shows value of 2 , then I think it could be a cosmetic problem.
regds,
aman
