UDLD support on UCS 6248 Fabric Interconnects?
Answered Question
Oct 1st, 2013
If possible I would like to see a UDLD neighbor between my 5548 Nexus swtiches and my 6248 Fabric Interconnects.
UDLD feature is supported on the 5548s and easily enabled.
However I can't find any information on how to enable it on the UCS FI ethernet uplink ports. Is it possible?
Thanks.
Correct Answer by padramas about 3 years 10 months ago
UDLD support for UCS FI will be available from next major release i.e UCSM 2.2
UDLD feature is currently not available on FI.
Padma
Overall Rating: 5 (1 ratings)
Correct Answer
padramas Tue, 10/01/2013 - 22:06
  • Cisco Employee,
Padma
