ā10-01-2013 09:47 PM - edited ā03-01-2019 02:42 PM
Hi!
Cisco SCE 8000 working normally while traffic through it not pass. When i connect optical links and start passing traffic throught cisco, i have a problem. SCE watchdog run software reboot with error:
2013-09-30 13:54:40 | FATAL | CPU #000 | A problem occurred in the SCE8000 Service Control Module Extended (SCM-E) slot 1 ,Please report to Cisco's customer support.
2013-09-30 13:54:40 | ERROR | CPU #000 | SE Watchdog Module: An Error occurred. Please report to Cisco's customer support
2013-09-30 13:54:41 | WARN | CPU #000 | SE Watchdog Module: A problem occurred. Please report to Cisco's customer support
2013-09-30 13:54:41 | INFO | CPU #000 | Party data base was closed.
In debug file i found:
Interrupt Received from: SimbaDPT[0].Tx[0].CTX_ISR.ECCMultiErrorInt - description: RLDRAM ECC multi bit error interrupt.
What the problem could be?
ā10-03-2013 04:40 AM
Hi Mike,
Which SCOS version do you use? We have such issue with SCOS 3.8.0. There are no problems after upgrade to 3.8.5.
ā10-08-2013 06:50 PM
I have tried 3.7.2, 3.8.5, 4.0.0. Unfortunately, the result is the same. I think that hardware problem (RAM).
