CUCM 9.1 compatibility matrix
tony loktu
I can't find a compatibility matrix for CUCM 9.1
All i can find is for CUCM 9.0
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/unified/communications/system/versions/IPTMtrix.html#wp1016708
Is there one for CUCM for 9.1?
/Tony
9 Replies 9
Jaime Valencia
9.1 is just a revision for 9.0, pretty much if it says it works with 9.0, it will work with 9.1
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
There is 1 exception for this (at least that I am aware off). IM&Presnece  has to match the major and minor CUCM release, hence, CUCM 9.1 would imply an upgrade in IM&Presence to 9.1 as well for it to work.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/im_presence/compatibility/9_1_1/IM_P_Compatibility.html
Refer to : IM and Presence Software Compatibility
"IM and Presence Service Release 9.1(x) is supported only with Cisco Unified Communications Manager Release 9.1(x)"
For 9.X versions of IM & Presence, what really matters is that major and minor version have to match. The structure of the versions is like this:
9.X.Y
9 = Major release, X= Minor release, Y= Maintenance release.
Hope this helps as well!
HI Jaime,
I have a client who is running CUCM 9.1.2.15900-7 and IMP PUB 9.1.1.91900-1 and IMP SUB 9.1.1.30000-3.
In order to match IMP PUB and SUB versions , I tried to switch version on IMP SUB but it is complaining and asking to match CUCM version 9.1.2.15900-7.
Please see below error on IMP SUB :
"admin:utils system switch-version
Active Master Version: 9.1.1.30000-3
Inactive Master Version: 9.1.1.91900-1
If you are switching to an earlier release, you must run:
utils dbreplication reset all
from the publisher after all the nodes are switched over.
Do you really want to switch between versions ?
Enter (yes/no)? yes
Switching Version and Restarting the Appliance ...
Switch version duration can vary depending on the database size
and platform configuration. Please continue to monitor the
switchover process from here.
Waiting .........
Operation failed
ERROR: Version mismatch. Primary host "IMP01" is running version 9.1.2.15900-7. Please switch versions on "IMP01" and try again."
Just wondering if the IMP version should match the exact CUCM version ?
Thank you
Saima
No, they don't need to match, as a matter in fact, even on the same train, like 10.5(2) they don't match, as each BU releases the version they considered to be the best candidate and do not align with each other.
Exactly how did you get that combo in the versions?
java
vartakdinesh
Why is there no 9.1 compatibility information here anymore?
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
I've already answered that, see my other reply.
java
Hi Jaime, but UCCE versions make a clear distinction between CUCM 9.1 and 9.0 right?
http://docwiki.cisco.com/wiki/Unified_CCE_Software_Compatibility_Matrix_for_9.0(x)
Also, how do I find compatibility information for CER with CUCM 9.1.x?
thanks,
Dinesh.
Review such info directly in the product documentation (usually RNs), in this case UCCE and CER, this info is always available there if you can't find it, and before this tool was developed.
java
Finally found a link for Compatibility Matrix for CUCM:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
But the section for CER just says this:
"You can research Cisco Emergency Responder compatibility with Cisco Unified Communications Manager releases by using the Cisco Unified Communications Compatibility Tool at the following URL:
I will go to the RNs to find out compatibility information.
