ASA Botnet Filter
kdietz
I have recently added the Botnet filter license to an ASA5510.  Im needing assistance with viewing the config and being able to know that it is working.  How can i test?  Thanks
5 Replies 5
Here is a document that should get you started:
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/white_paper_c11-532091.html
If there are more questions after going through that doc, fell free to ask.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
johnlloyd_13
Level 9
Level 9
hi kevin,
here's some show commands as per my FIREWALL notes and a useful link that i've bookmarked.
usually the ASA will generate a syslog if a bad or infected machine is detected.
https://supportforums.cisco.com/docs/DOC-8782
Commands to Verify Botnet Traffic Filtering Operation
Function                                Command Syntax
Dynamic database status        ciscoasa# show dynamic-filter updater-client
Connections filtered                ciscoasa# show dynamic-filter statistics
List infected hosts                  ciscoasa# show dynamic-filterreport infected-hosts
Top-n botnet activity                ciscoasa# show dynamic-filter top [infected-hosts | malware-ports | malware-sites]
I have to enable botnet filter as well for one of our customer. So is it possible to enable botnet filter in monitoring mode only, means without dropping any traffic or impacting the production environment ?
hi,
the answer is no. the ASA will intercept DNS queries and match it against the configured blacklist sites on its database and drops the traffic.
My filter was origanly set to monitor mode which wasnt dropping the malicous requests - Scenerio;  I have a DNS server where the filter is detecting as a malicouis host naking DNS requests.  My question is,  does this necessarily imply that the DNS server is infected or is it another host on my network using this DNS server for name resolution.
