Manual NAT to override Auto NAT
Answered Question
Oct 2nd, 2013
Hi, i've an ASA with this relevant config:
ASA Version 9.1(1)
interface Ethernet0/0
nameif outside
security-level 0
ip address 1.1.1.1 255.255.255.248
object network obj-192.168.2.20
host 192.168.2.20
object network obj-1.1.1.2
host 1.1.1.2
access-list OUT_IN extended permit tcp any4 host 192.168.2.20 eq smtp
access-list OUT_IN extended permit tcp any4 host 192.168.2.20 eq pop3
access-list OUT_IN extended permit tcp any4 host 192.168.2.20 eq imap4
access-list OUT_IN extended permit tcp any4 host 192.168.2.20 eq https
nat (inside,outside) static obj-1.1.1.2
Now i have to allow access to a web server from a specific Internet Address  2.2.2.2.
Both web server and all other inbound access are made via a different IP Address 1.1.1.2
I'm having some problems configuring this second item, and I need help.
Which is the best way  to overcame this problem.
TIA
FR
Overall Rating: 3.6 (5 ratings)
Saqib Raza Wed, 10/02/2013 - 10:25
So you want to allow host 2.2.2.2 to access your webserver 1.1.1.2 ?  if so, you already have that access in place according to this ace
if you need to allow 2.2.2.2 to access at port 80 then just add an other ace
e.g
Julio Carvajal Wed, 10/02/2013 - 10:41
  • Purple, 4500 points or more
Hello Fran,
Not sure what you mean:
I mean you already have the policies in place for this:
So now a user on the outside 2.2.2.2 will be accessing your webserver,
Is your server 192.168.2.20 and also what do you mean by
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at [email protected]
Cheers,
Julio Carvajal Segura
francisco.j.romao Wed, 10/02/2013 - 15:33
Hello Saqib and Julio
many thnaks for your replies.
unfortunately could not be as clear as I would have been:
need to allow access to the web server with private ip 192.168.2.30 via the public IP: 1.1.1.2
internal web server is different from mail server (different machines as you can see int the picture)
I think twice nat solves my problem but I can not form the rule.
On the other hand need to keep the 1:1 NAT 192.168.2.20/1.1.1.2 or my emails become blacklisted.
once more
TIA
FR
Julio Carvajal Wed, 10/02/2013 - 16:03
Hello Francisco,
That's the thing. You are already using a map to map where you basically map all available ports on the 1.1.1.2 to the SMTP server.
You will need to have a different IP address in order to map port 80 to the Internal Server or instead of using a one to one tranlation for the SMTP server map the right ports and leave 80 available for the SMTP server
Cheers,
francisco.j.romao Wed, 10/02/2013 - 16:16
Hello Julio,
Here is where I need some help:
when I tried to map the "right ports and leave 80 available"... I got stuck on blacklists because the emails have gone out with the outside interface 1.1.1.1 not with 1.1.1.2
I couldnt solve this...
(I've already bookmarked your website)
Once more
Thanks for your help
FR
Julio Carvajal Wed, 10/02/2013 - 16:41
That's awesome hehe
Yeah, I have seen this in the past.
You could do that NAT (Leaving port 80 off) and also a policy nat basically saying that when that servers goes to any outside SMTP server gets Translated to 1.1.1.2.
Did you try that Policy NAT before?
Cheers,
francisco.j.romao Wed, 10/02/2013 - 16:47
Hello again Julio
Thank you very much for your support.
No I havent tried Policy NAT.
Could you please give me a clue??
Kind Regards
FR
Julio Carvajal Wed, 10/02/2013 - 17:09
This would be based on the requirement
Let's say your SMTP server will need to communicate to the host 8.8.8.8
So you can do the port-forwarding for the ports as you did before (when it was being blacklisted) so you can reserver port 80 TCP for the HTTP server and then
object network 8.8.8.8
host 8.8.8.8
exit
objetc service Dsmtp
service tcp destination eq 25
exit
Nat (inside,outside) source static obj-192.168.2.20  1.1.1.2 destination static 8.8.8.8 8.8.8.8  service Dsmtp Dsmtp
Cheers,
francisco.j.romao Wed, 10/02/2013 - 17:27
Julio
once more "muchas gracias"
since my smtp server has to be available "to the world" I can't do like you suggest.
May I use any any for destination? it would be based on service only.
something like:
Nat (inside,outside) source static obj-192.168.2.20  1.1.1.2 destination static any any  service Dsmtp Dsmtp
Or
since I know that my web server is only accessed by 2.2.2.2
Nat (inside,outside) source static obj-192.168.2.30  1.1.1.2 destination static 2.2.2.2 2.2.2.2
this would be at section 1 of NAT (before auto NAT or NAT 1:1 refered before)
I don't know if this statements conflits with each other
TIA
FR
francisco.j.romao Mon, 10/21/2013 - 13:21
thank you for your precious help.
i've forgotten mark your answer as correct but  thanks to your support I solved my case.
Big hug
FRancisco
