Polling snmp WCS 7.0
Oct 3rd, 2013
Hi all,
You can configure WCS in order to send alarms to an external event manager (for example, NetCool IMB Tivoli ó HPNNMi) configuring "Receiver Notification" including ports and IP's of the event manager. But, is also possible polling snmp by the event manager or is it necesary polling each WLC?
In MIB CISCO-WIRELESS-NOTIFICATION, you can check that:
cwNotificationHistoryTableMaxLength OBJECT-TYPE is read-write,
cWNotificationUpdatedTimestamp OBJECT-TYPE is read-only and
cWNotificationKey OBJECT-TYPE is read-only
So, it should be possible. Can anyone confirm this? Is it necessary to configure WCS in a particular way?
On the other hand, if you installed WCS in a server in which is running Windows, apart from disable snmp agent of Windows, have I be care of anything more?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
