Warning message
ACS v5.3 (user command line interface)
Answered Question
We have lost the user/pass of command line interface of our ACS, but we can access by Web Interface with all the privileges.
We are trying create one user from web interface for the command line interface, but I don´t find the manner of do it.
I create one user in <system Administration < Accounts  with all roles, but this user doesn´t work in command line interface.
Is possible to create one user for command line interface from web interface?
Correct Answer by Jatin Katyal about 3 years 10 months ago
Hello Juan,
I see you've already got it resolved. However just wanted to add little more to this discussion.
The credentials used to login to the ACS CLI are entirely different than those used to authenticate at the ACS GUI screen and have absolutely nothing to do with credentials specified elsewhere in the network (such as on an Active Directory server).  So if you have lost/forgot the ACS CLI credentials, the only way to recover them is to use Recovery DVD mentioned above by Aqeel. Once you have access to CLI, you can always reset the GUI or CLI user password.
~BR
Jatin Katyal
**Do rate helpful posts**
Correct Answer by Anonymous about 3 years 10 months ago
Complete these steps to reset the CLI administrator account.
  1. Insert the ACS 5.x Recovery DVD into the DVD drive  of ACS.
   2. Reboot the ACS 5.x.
   The console displays:
   “Welcome to Cisco Secure ACS 5.1 Recovery - CSACS 1121”
   3. To boot from hard disk press
                Available boot options:
[1] Cisco Secure ACS 5.1 Installation (Keyboard/Monitor)
[2] Cisco Secure ACS 5.1 Installation (Serial Console)
[3] Reset Administrator Password (Keyboard/Monitor)
[4] Reset Administrator Password (Serial Console)
Boot from hard disk
Please enter boot option and press .
Boot:
  4. To reset the administrator password, at the system  prompt, enter 3 if you are using a keyboard and video
       Monitor, or enter 4 if you are using a serial console  port.
  5. The console displays the name of all the  administrators configured on the ACS 5.x
Admin username:
[1]:david
[2]:john
Enter number of admin for password recovery:
6. Enter the number against the adminstrator username  of which you want to reset the password. For the user
    "david", enter 1 at the prompt.
7. Enter the new password for the administrator account  and verify it. Enter Y to save the new password.
     Password:
     Verify password:
     Save change&reeboot? [Y/N]:
8. Now, remove the ACS 5.x Recovery DVD and reboot the  ACS.
Overall Rating: 5 (5 ratings)
Correct Answer
aqjaved Mon, 10/07/2013 - 07:52
  • Bronze, 100 points or more
Boot from hard disk
Boot:
Admin username:
[1]:david
[2]:john
     Password:
     Verify password:
Thanks to both by answer.
Although the answer directly is NO.
## Any users that you create from the ACS web interface cannot automatically log in to the ACS CLI. You must explicitly create users with access to the CLI. To create these users, you must log in to the CLI using the Admin account that you created during setup; then, enter the Configuration mode, and run the username command. ##
I will follow the steps for reset the CLI admin account.
Correct Answer
Jatin Katyal Tue, 10/08/2013 - 01:21
  • Cisco Employee,
Hello Juan,
~BR
Jatin Katyal
