Warning message
Subscriber Manager Times-Ten problem
Oct 4th, 2013
Hey guys,
I'm trying to install the subscriber manager on a testing environment, using a Linux virtual machine; and after going theough the process I'm having this error massage that I couldn't find a soulution for, so I need help
thank you in advance
[[email protected]-scesm-test bin]$ ./p3sm --sm-status
SM is running.
SM operational state is Failure
Errors/warnings -  during SM startup:
Error - Times-Ten DB is not set up correctly:
[TimesTen][TimesTen 7.0.5.2.0 ODBC Driver][TimesTen]TT0836: Cannot create data store shared-memory segment, error 22 -- file "db.c", lineno 7787, procedure "sbDbCreate"
1) Error: [TimesTen][TimesTen 7.0.5.2.0 ODBC Driver][TimesTen]TT0836: Cannot create data store shared-memory segment, error 22 -- file "db.c", lineno 7787, procedure "sbDbCreate", sqlState: 08001, errorCode: 836 [TimesTen][TimesTen 7.0.5.2.0 ODBC Driver][TimesTen]TT0836: Cannot create data store shared-memory segment, error 22 -- file "db.c", lineno 7787, procedure "sbDbCreate"
2) Error occured while validating configuration: SMM:name=SMM: java.lang.NullPointerException
Use "--reset-sm-status" option in order to reset the errors.
Command terminated successfully
mirsad001 Wed, 07/16/2014 - 02:36
If you haven't found out already, the solution is to increase the shared memory maximum segment size. It is located in /etc/sysctl.conf....
Example:
#  ---- Begin settings for TimesTen
kernel.sem = 250 32000 100 100
kernel.shmmax = 536870912
#  ---- End of settings for TimesTen
Change to:
kernel.shmmax = 1073741824
Reboot the machine and the problem should be solved!
Related Content
