Access to my ASDM ASA5505
Oct 4th, 2013
Hi I have been using a few days the firewall ASA5505 they've completely put new, the ASA Version 8.4 (2) have been playing and the ASDM version 6.4 (9). I have the Basic Config loaded with the command "conf t" and "Facorty default-config."
Now I want to connect to this firewall, but this is not because he always says he unable to connect to the firewall. The IP settings I have the following: IP address 192.168.1.6 Subnet: 255.255.255.0 Gateway: 192.168.1.1. How can I connect to or what I'm doing wrong?
Executing command: interface Ethernet 0/0
Executing command: switchport access vlan 2
Executing command: no shutdown
Executing command: exit
Executing command: interface Ethernet 0/1
Executing command: switchport access vlan 1
Executing command: interface Ethernet 0/2
Executing command: interface Ethernet 0/3
Executing command: interface Ethernet 0/4
Executing command: interface Ethernet 0/5
Executing command: interface Ethernet 0/6
Executing command: interface Ethernet 0/7
Executing command: interface vlan2
Executing command: nameif outside
INFO: Security level for "outside" set to 0 by default.
Executing command: ip address dhcp setroute
Executing command: interface vlan1
Executing command: nameif inside
INFO: Security level for "inside" set to 100 by default.
Executing command: ip address 192.168.1.1 255.255.255.0
Executing command: security-level 100
Executing command: allow-ssc-mgmt
ERROR: SSC card is not available
Executing command: object network obj_any
Executing command: subnet 0.0.0.0 0.0.0.0
Executing command: nat (inside,outside) dynamic interface
Executing command: http server enable
Executing command: http 192.168.1.0 255.255.255.0 inside
Executing command: dhcpd address 192.168.1.5-192.168.1.36 inside
Executing command: dhcpd auto_config outside
Executing command: dhcpd enable inside
Executing command: logging asdm informational
Factory-default configuration is completed
ciscoasa(config)#  wr
Building configuration...
Cryptochecksum: ee2b2e47 c2886bf3 b45f3afb bccbfb1e
Marvin Rhoads Fri, 10/04/2013 - 07:55
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Please provide output of "show ssl". You may need to add strong cipher support.
Reference.
Marvin Rhoads Fri, 10/04/2013 - 14:29
  • Hall of Fame,
Newer browsers do not allow you to connect to SSL servers running weak encyption algorithms (e.g. des).
Last year Cisco started turning off the strong algorithms (aes and 3des) by default on ASAs.
You can check using the command I suggested above.
When I run that I get the following.
ciscoasa# show ssl
Accept connections using SSLv2, SSLv3 or TLSv1 and negotiate to SSLv3 or TLSv1
Start connections using SSLv3 and negotiate to SSLv3 or TLSv1
Enabled cipher order: des-sha1
Disabled ciphers: 3des-sha1 rc4-md5 rc4-sha1 aes128-sha1 aes256-sha1 null-sha1
No SSL trust-points configured
Certificate authentication is not enabled
What should I change?
Thanks.
Marvin Rhoads Fri, 10/04/2013 - 14:50
  • Hall of Fame,
Yep - note the section that says the only enabled cipher is des-sha1.
Fix it by:
conf t
     ssl encryption aes128-sha1 aes256-sha1 3des-sha1
     exit
wr mem
Then re-check ASDM.
Marvin Rhoads Fri, 10/04/2013 - 14:54
  • Hall of Fame,
Ah yes, as you note the (free) 3DES-AES license needs to be active to use strong encryption.
