10-04-2013 10:51 AM - edited 03-10-2019 08:57 PM
Greetings,
We will be performing a live test of ISE Fail Open on our production system tomorrow night. When the policy nodes are all unavailable we want the switches to allow open access to all devices on all interfaces.
I have done some testing of this on an individual test switch by routing packets to the ISE policy nodes to null 0 to emulate a failure. It appears to be working well, but was hoping for more input from the community before my Live test tomorrow night.
First, I believe these to be the only commands needed to make this work correctly. Does anyone have any comment on this configuration? Am I missing anything? Do these timers seem OK? I'm wondering if the deadtime should be greater in case the nodes or the network connection are flapping?
Global Config:
radius-server dead-criteria time 5 tries 3
radius-server deadtime 5
dot1x critical eapol
Interface Config:
authentication event server dead action reinitialize vlan <normal data vlan>
authentication event server dead action authorize voice
authentication event server alive action reinitialize
Next, this is the behavior I am seeing after the policy nodes go down. Is this as it should be?
1. Absolutely nothing happens until an interface undergoes (re)authentication. All ports remain in current authentication/authorization state.
2. If an interface undergoes (re)authentication, the switch tries to reach one of the configured policy nodes. After 5 seconds there is a message the first node is dead. In another 5 seconds there is a mesage that the second node is dead.
3. After another ~20 seconds, the interface that was attempting (re)authentication goes into Critical Authorization:
TEST#sh auth sess int f1
Interface: FastEthernet1
MAC Address: 1234.5678.90ab
IP Address: Unknown
User-Name: UserName
Status: Authz Success
Domain: DATA
Oper host mode: multi-host
Oper control dir: in
Authorized By: Critical Auth
Vlan Policy: 2
Session timeout: N/A
Idle timeout: N/A
Common Session ID: 0A0A010B0000013D093F17CC
Acct Session ID: 0x0000072B
Handle: 0x5A00013E
Runnable methods list:
Method State
dot1x Authc Failed
mab Not run
Critical Authorization is in effect for domain(s) DATA
TEST#
All other interfaces remain in current mode, nothing on them changes so long as they don't attempt to (re)authenticate.
4. If another interface attempts to (re)authenticate, it goes into critical state immediately w/o trying to contact the dead policy nodes.
5. The switch will try every so often (every 5 minutes?) to reach the policy nodes. If one of them is up, all interfaces that were in critical state immediately transition to normal authc/authz modes. Normal timers apply, dot1x endpoints come up almost immediately, mab clients lose connectivity until dot1x times out.
To emulate a global fail for the organization, I plan to stop the ISE services on both of my policy nodes.
Thanks for any comments/insights/input.
10-07-2013 05:21 AM
FYI we had a Cisco TAC Engineer confirm this configuration is correct and complete. Our fail open test went great, everything performed as expected.
10-09-2013 02:18 AM
We appreciate the detailed scenario description, the question itself was very informative.
I used
critical VLAN=accessVLAN
instead of
