I can´t register phones in CallManagerExpress 15.3-3.M
Answered Question
I have a problem with CME, i upgraded 2911 for version ios universalk9-mz.SPA.153-3.M and when router startup cannot laod the phone files.
Warning: flash0:/IP_Phones/7942_7962/Sccp/SCCP6901.9-2-1-a.loads does not exist.  Command retained.
Warning: flash0:/IP_Phones/7942_7962/Sccp/SCCP6911.9-2-1-a.loads does not exist.  Command retained.
Warning: flash0:/IP_Phones/7942_7962/Sip/SCCP6911.9-2-1-a.loads does not exist.  Command retained.
Warning: flash0:/IP_Phones/7942_7962/Sip/SCCP6901.9-2-1-a.loads does not exist.  Command retained.
dir flash0:
3  -rw-         676   Oct 3 2013 12:49:02 +02:00  SCCP42.9-2-1S.loads
    4  -rw-         680   Oct 3 2013 12:49:12 +02:00  term42.default.loads
    5  drw-           0   Oct 3 2013 11:07:04 +02:00  CME 9.5.0 GUI
   24  -rw-         680   Oct 3 2013 12:49:28 +02:00  term62.default.loads
   25  -rw-         481   Oct 3 2013 16:05:40 +02:00  SCCP69xx.9-2-1-0.loads
   27  drw-           0   Oct 3 2013 11:08:58 +02:00  IP_Phones
#dir
Directory of flash0:/IP_Phones/
   28  drw-           0   Oct 3 2013 11:08:58 +02:00  6901_6911
   45  drw-           0   Oct 3 2013 11:11:28 +02:00  6921_6941_6961
   56  drw-           0   Oct 3 2013 11:12:18 +02:00  7942_7962
and i have tftp server configured:
tftp-server flash0:/IP_Phones/6921_6941_6961/Sccp/SCCP69xx.9-2-1-0.loads
tftp-server flash0:/IP_Phones/7942_7962/Sccp/SCCP6901.9-2-1-a.loads
tftp-server flash0:/IP_Phones/7942_7962/Sccp/SCCP6911.9-2-1-a.loads
tftp-server flash0:/IP_Phones/7942_7962/Sip/SCCP6911.9-2-1-a.loads
tftp-server flash0:/IP_Phones/6921_6941_6961/SIP/SIP69xx.9-2-1-0.loads
tftp-server flash0:/IP_Phones/7942_7962/Sip/SCCP6901.9-2-1-a.loads
tftp-server flash0:/IP_Phones/6901_6911/SIP/SIP6911.9-2-1-0.loads
tftp-server flash0:/IP_Phones/6901_6911/SIP/SIP6901.9-2-1-0.loads
tftp-server flash0:/IP_Phones/6901_6911/Sccp/SCCP6911.9-2-1-a.loads
tftp-server flash0:/IP_Phones/6901_6911/Sccp/SCCP6901.9-2-1-a.loads
tftp-server flash0:/IP_Phones/7942_7962/Sip/SIP42.9-2-1S.loads
tftp-server flash0:/IP_Phones/7942_7962/Sip/term42.default.loads
tftp-server flash0:/IP_Phones/7942_7962/Sip/term62.default.loads
tftp-server flash0:/IP_Phones/7942_7962/Sip/jar42sip.9-2-1TH1-13.sbn
tftp-server flash0:/IP_Phones/7942_7962/Sccp/jar42sccp.9-2-1TH1-13.sbn
tftp-server flash0:/IP_Phones/7942_7962/Sccp/SCCP42.9-2-1S.loads
tftp-server flash0:/IP_Phones/7942_7962/Sccp/term42.default.loads
tftp-server flash0:/IP_Phones/7942_7962/Sccp/term62.default.loads
What I am doing worng ???
Rgards,
Gil
Correct Answer by islam.kamal about 3 years 10 months ago
Hi Luis
In addition to the useful information which MR/Anas shared with you , please type under telephony-service no create cnf-files and then create cnf-files as the below
Telephony-service
no create cnf-files
create cnf-files.
Thank you
please rate all useful information
Correct Answer by Anas Abueideh about 3 years 10 months ago
what is the current firmware on the phones ?, if it is 9-3-1, it will not upgrade the phones.
also make sure you have the files on the flash, tray to use alias commnad like the below
tftp-server flash0:/IP_Phones/7942_7962/Sccp/term62.default.loads alias /term62.default.loads
Anas
please rate all helpful posts
Overall Rating: 5 (3 ratings)
Correct Answer
Anas Abueideh Fri, 10/04/2013 - 14:51
  • Blue, 1500 points or more
  • Community Spotlight Award,
    Best Doc/Video: December 2014
Anas
Hi Anas,
This works thank you for your help, the phones is registered right now
But i have another problem...i have Cisco Unified IP Conference Phone 8831 and i can´t register this conference... i have cme version 10 and i have the correct files in the flash but i cannot register the device.
RF-RT-01#sh telephony-service
CONFIG (Version=10.0)
Version 10.0
Max phoneload sccp version 17
Max dspfarm sccp version 18
RF-RT-01(config-telephony)#load ?
  12SP       12SP+ and 30VIP phones
  6901       Cisco IP Phone 6901
  6911       Cisco IP Phone 6911
  6921       Cisco IP Phone 6921
  6941       Cisco IP Phone 6941
  7985       Cisco IP Phone 7985....
  8941       Cisco IP Phone 8941
  8945       Cisco IP Phone 8945
  ata        ATA  phone emulation for analog phone
This means that CME not support Cisco Unified IP Conference Phone 8831??
Rgards,
Luís Gil
Pete Cowen Mon, 11/18/2013 - 06:17
Hello, did you manage to get the 8831 working on CME v10?
Correct Answer
islam.kamal Fri, 10/04/2013 - 15:08
  • Red, 2250 points or more
Hi Luis
Telephony-service
no create cnf-files
create cnf-files.
Thank you
Jonathan Schulenberg Sun, 10/06/2013 - 07:16
  • Cisco Designated VIP,
    2017 IP Telephony
Also don't forget about the EULA acceptance now. Phones will not be allowed to register until this is done.
conf t
license accept end user agreement
Please remember to rate helpful responses and identify helpful or correct answers.
