Warning message
Can you use an Extended ACLs for NAT?
Answered Question
Oct 4th, 2013
I tried looking this up, but frankly I didn't know what to make of the results.
Someone designed a lab, they specified that they want to use NAT.
In the instructions:
Access-list 100 will be used for the permit statement for when you're dynamically assigning an address from the NAT pool.
My problem with this is that I'm under the impression that you can only use a Standard ACL for this.
Am I correct? Or am I overlooking something?
example:
ip nat pool POOL_NAME first-ip last-ip netmask x.x.x.x overload
access-list 1 permit (local IP network)
ip nat inside source list <1-99> pool POOL_NAME
I cannot see how this would work with an extended list considering that an extended ACL implies the need for a destination address of some sort or another.
Example:
access-list 100 permit ip (local net) (destination net)
This doesn't make any sense to me when it comes to NAT.
Help?
Correct Answer by cadet alain about 3 years 10 months ago
suppose you are using the same link for Internet access and for an IPSec VPN then you must deny the traffic using the VPN from being natted and in this case you must use an extended ACL like this:
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
acces-list 101 permit ip 192.168.1.0 0.0.0.255 any
The first line denies VPN traffic between the LANs and the second permits the Internet destined traffic.
Alain
Overall Rating: 5 (1 ratings)
John Blakley Sat, 10/05/2013 - 05:01
  • Purple, 4500 points or more
You can. It probably depends on the type of platform you're on, or IOS version:
R4(config)#ip nat inside source list ?
  <1-2699>  Access list number for local addresses
  WORD      Access list name for local addresses
HTH,
John
*** Please rate all useful posts ***
Guillermo Rodriguez Sat, 10/05/2013 - 17:56
Looks like I left out some critical information. The lab in question was directly related to VPNs, so thanks for throwing that response out there -- it really did come into place.
It makes sense to me know and I got some good knowledge out of it.
Thank you.
Correct Answer
cadet alain Sat, 10/05/2013 - 11:03
Alain
