Warning message
S660 proxy takes a path to MPLS
Oct 6th, 2013
I was just wondering if a proxy could be deployed in such a way that the egress traffic from it would take an MPLS path as opposed to the Internet.
Thanks.
_Greg
Vance Kwan Sun, 10/06/2013 - 23:42
  • Cisco Employee,
Hi Greg,
I'm not familiar with MPLS, but the WSA does not have anything special to accomodate MPLS setups.  I do not believe it needs it.  You can setup static routes for the egress traffic to use a separate interface if that is what you are asking.  As long as it has layer 3 connectivity, it really does not care what the upstream does.
