10-07-2013 01:03 AM - edited 07-04-2021 01:01 AM
Hello!
According to CCX compatible matrix, CCXv5 adapter supports Client MFP.
Client MFP requiments
I have two Linksys wireless adapters AE1000 and AE6000 with the latest software versions.
When I connect these adapters to WPA2 AES(CCMP)protected WLAN, in client details on the WLC I can see that client is CCXv5 but
no Management Frame Protection supported (MFP-WLC-01.jpg attachment).
Prime shows the same information about the client (MFP-Prime-01.jpg).
What can be the reason for this situation?
Is there any way to make these adapters support MFP?
10-07-2013 02:56 AM
So, you have MFP enabled on your infrastructure, (WLAN and APs) but it still shows you that MFP is not supported on your client?
Rating useful replies is more useful than saying "Thank you"
10-07-2013 04:21 AM
Hello!
Yes, that's right. MFP is enabled
(Cisco Controller) >show wps mfp summary
Global Infrastructure MFP state................ Enabled
Controller Time Source Valid................... True
Prime v1.3, CAP3602I, WLC 7.4.110
12-06-2016 03:37 PM
CCXv5 clients were allowed to *not* support MFP if the underlying WLAN hardware did not support it. I suspect that is the case here.
Dennis
dB Performance Inc.
