Warning message
BVI not responding to ARP requests ?
I have a 2811 router running IOS c2800nm-adventerprisek9-mz.124-22.YB8 with a wireless module ( HWIC-AP-G-A ) configured with an ipsec vpn.
Because of the wireless module, I believe that I need to have the inside ip address on the BVI.
When I do this, my vpn clients are unable to communicate with computers on the private network.
After a lot of debugging, I believe the reason to be that the BVI does not seem to respond to ARP requests from computers on the private network.
If I put the inside ip address on f0/1, then the VPN works the way it is supposed to but my wireless clients are unable to get an ip address due the BVI not having a network presence without an ip address.
debug arp output when I ping the vpn client from a computer on the private net and the inside ip is on f0/1:
Oct  7 00:05:20.075: IP ARP: rcvd req src 10.0.0.102 001c.c0ef.dc08, dst 10.0.0.153 FastEthernet0/1
Oct  7 00:05:20.075: IP ARP: sent rep src 10.0.0.153 001e.f760.8f11,
                 dst 10.0.0.102 001c.c0ef.dc08 FastEthernet0/1
debug arp output when I ping the vpn client from a computer on the private net and the inside ip is on bvi1:
Oct  7 00:09:22.971: IP ARP: rcvd req src 10.0.0.102 001c.c0ef.dc08, dst 10.0.0.154 BVI1
and no reply is ever sent.
This config works for VPN clients but not for wireless clients:
interface FastEthernet0/1
description House LAN
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface BVI1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
This config works for wireless clients but not for VPN clients:
no ip address
bridge-group 1
duplex auto
speed auto
interface BVI1
ip nat inside
no ip redirects
no ip unreachables
no ip proxy-arp
Is this a bug ?
Here's the config:
version 12.4
service password-encryption
hostname xxx-2811
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging buffered
enable secret 5 $1$5OZ2$iYMxqrGokppZb91bQmD.V/
aaa new-model
aaa authentication login default local-case
aaa authorization network xxx-vpn local
aaa session-id common
clock timezone EST -5
clock summer-time EST recurring
dot11 syslog
dot11 ssid XXX2811
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 01425F520C5353052B
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.1 10.0.0.99
ip dhcp excluded-address 10.0.0.151 10.0.0.255
ip dhcp pool dhcppool
   network 10.0.0.0 255.255.255.0
   dns-server 75.75.75.75 75.75.76.76
   default-router 10.0.0.1
ip domain name xxx.local
ip ddns update method no-ip
HTTP
  add http:[email protected]/nic/update?hostname=[email protected]/nic/update?hostname=<h>&myip=<a>
  remove http:[email protected]/nic/update?hostname=[email protected]/nic/update?hostname=<h>&myip=<a>
interval maximum 2 0 0 0
interval minimum 1 0 0 0
login on-failure log
login on-success log
no ipv6 cef
username xxx privilege 15 password 7 065756771B165C330F
archive
log config
  hidekeys
crypto logging session
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
crypto isakmp client configuration address-pool local vpnpool
crypto isakmp client configuration group xxx-vpn
key xxx
dns 75.75.75.75 75.75.76.76
pool vpnpool
acl 101
include-local-lan
split-dns xxx.local
max-logins 2
crypto ipsec transform-set transform-1 esp-aes esp-sha-hmac
crypto dynamic-map vpnmap 10
set transform-set transform-1
reverse-route
crypto map vpnmap client authentication list default
crypto map vpnmap isakmp authorization list xxx-vpn
crypto map vpnmap client configuration address initiate
crypto map vpnmap client configuration address respond
crypto map vpnmap 10 ipsec-isakmp dynamic vpnmap
ip ssh maxstartups 3
ip ssh authentication-retries 2
ip ssh version 2
bridge irb
interface FastEthernet0/0
description Comcast WAN
ip ddns update hostname xxx.no-ip.biz
ip ddns update no-ip
ip address dhcp client-id FastEthernet0/0
ip access-group IncomingTrafficACL in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
crypto map vpnmap
ip nat inside
duplex auto
speed auto
interface Dot11Radio0/3/0
description House WAN
no ip address
encryption mode ciphers aes-ccm tkip
ssid XXX2811
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
world-mode dot11d country US both
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface BVI1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip local pool vpnpool 10.0.0.151 10.0.0.160
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip dns server
ip nat inside source route-map RM-POLICY-NAT interface FastEthernet0/0 overload
ip access-list extended ACL-POLICY-NAT
remark Deny_10_Network_NAT_Permit_all_other
deny   ip 10.0.0.0 0.0.0.255 10.0.0.0 0.0.0.255
permit ip 10.0.0.0 0.0.0.255 any
ip access-list extended IncomingTrafficACL
remark ACCEPT-ESTABLISHED
permit tcp any any established
remark ACCEPT-DNS-IN
permit udp any eq domain any
remark ACCEPT-NTP-IN
permit udp any eq ntp any
remark ACCEPT-DHCP-IN
permit udp any eq bootps any
remark ACCEPT-IPSEC-VPN
permit udp any any eq isakmp
permit udp any any eq non500-isakmp
permit esp any any
remark DENY-SSH
deny   tcp any any eq 22 log
remark DENY-ALL-OTHER
deny   ip any any log
logging trap debugging
logging 10.0.0.102
access-list 101 permit ip 10.0.0.0 0.0.0.255 10.0.0.0 0.0.0.255 log
access-list 101 remark VPN Access List
route-map RM-POLICY-NAT permit 10
match ip address ACL-POLICY-NAT
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login  Authorized Users only.  This is a monitored network.
line con 0
line aux 0
line vty 0 4
privilege level 15
transport input ssh
scheduler allocate 20000 1000
ntp server 18.85.44.118
end
