Warning message
Program Phone Button
Answered Question
Oct 7th, 2013
Ok, hopefully I am on the correct forum....
We currently have a main helpdesk number that after a few  rings, will ring over on other extentsions.  Since this number is different from the rest of the department, I would like to program a button on my phone/line so when the helpdesk line is called, the button on my phone will light up and display who is calling.  The model of phones I am looking to do this on is the Cisco 7962 and 7942.
Correct Answer by Jaime Valencia about 3 years 10 months ago
Yes, if you want to have a new/separate DN for that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Jaime Valencia Mon, 10/07/2013 - 07:58
  • Cisco Employee,
  • Hall of Fame,
    2011
You can add another line (if there's room on the phone) as a shared line, or add it as a line group, or use your current line on a line group.
java
techbeckk Mon, 10/07/2013 - 13:31
Created a new BLF SD and that was what I was looking for.  Thanks for setting me on the right track.
