Warning message
Cisco 1142 - WLC 5508
Oct 8th, 2013
Hi All,
Having an issue with AP 1142N, attached to WLC 5508.
Initially configured the AP with IOS c1140-k9w8-tar.152-4.JA1.tar though all other AP's in the network are running12.4 version. Decided to change the OS from 15.2 to 12.4.
Migrated LWAPP to IOS which worked fine and AP become Autonomous.
However, when I try to migrate (IOS to LWAPP)  with c1140-rcvk9w8-tar.124-23c.JA7.tar, the AP goes through all the processes gets reloaded and comes back with 15.2 image.  Not sure where it is picking up the image from. I want to remove the image from WLC and get this AP in 12.4 only. Does anyone faced this issue before, could you provide me help to resolve this please.
Srini K
Rasika Nayanajith Tue, 10/08/2013 - 13:37
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Why do you want to your LWAPP to have 12.4 ?  What's the problem of your LWAPP getting 15.2 ?
The image use for conversion is just recovery image just to enable AP to register for a WLC. Once register WLC will push the complete image for AP to download.
Rasika
**** Pls rate all useful responses ****
Srinivasan K Tue, 10/08/2013 - 14:28
Rasika, thanks for the reply. I've got 5 WiFi profiles on our WLC. While on 15.2, the AP is getting only one of those 5.
All other AP's (14) are currently running 12.4 which picks up all the 5 profiles. This is the reason I want to move it back to 12.4
Rasika Nayanajith Tue, 10/08/2013 - 19:07
    2017 Wireless
That cannot be AP image related. What are the WLAN ID used for those profiles ? Are you using AP-group to control SSID advertisement or everything in default-apgroup ?
Rasika
Abhishek Abhishek Tue, 10/08/2013 - 14:43
  • Gold, 750 points or more
That might be the issue of upgrade to 15.2 Please send a copy of config for proper view of the problem.
Srinivasan K Tue, 10/08/2013 - 14:51
Building configuration...
Current configuration : 17798 bytes
! Last configuration change at 20:53:30 UTC Tue Oct 8 2013
version 15.2
no service pad
service password-encryption
hostname CH2F
logging rate-limit console 9
enable secret 5 $1$GG1Q$sGVWQtvpoHcJ5ps3H37wA1
aaa new-model
aaa authentication login default local
aaa session-id common
ip cef
eap profile lwapp_eap_profile
method fast
crypto pki trustpoint airespace-old-root-cert
revocation-check none
rsakeypair Cisco_IOS_MIC_Keys
crypto pki trustpoint airespace-new-root-cert
crypto pki trustpoint airespace-device-root-cert
crypto pki trustpoint cisco-root-cert
crypto pki trustpoint Cisco_IOS_MIC_cert
crypto pki certificate chain airespace-old-root-cert
certificate ca 00
  30820406 3082032F A0030201 02020100 300D0609 2A864886 F70D0101 04050030
  818F310B 30090603 55040613 02555331 13301106 03550408 130A4361 6C69666F
  726E6961 3111300F 06035504 07130853 616E204A 6F736531 16301406 0355040A
  130D6169 72657370 61636520 496E6331 0D300B06 0355040B 13046E6F 6E65310B
  30090603 55040313 02636131 24302206 092A8648 86F70D01 09011615 73757070
  6F727440 61697265 73706163 652E636F 6D301E17 0D303330 32313232 33333835
  355A170D 31323131 31313233 33383535 5A30818F 310B3009 06035504 06130255
  53311330 11060355 0408130A 43616C69 666F726E 69613111 300F0603 55040713
  0853616E 204A6F73 65311630 14060355 040A130D 61697265 73706163 6520496E
  63310D30 0B060355 040B1304 6E6F6E65 310B3009 06035504 03130263 61312430
  2206092A 864886F7 0D010901 16157375 70706F72 74406169 72657370 6163652E
  636F6D30 81DF300D 06092A86 4886F70D 01010105 000381CD 003081C9 0281C100
  DB9D3901 30059DD1 05CB2793 9B9907F8 1FF57FA9 24065BF7 1A5865F8 B9CFCCB3
  679354D4 69BAB847 1CA327AE EA006AAC 90479C9D C23B67DE FACC0D28 32C6103F
  A59C41E2 E8B4250B 4D2903EB 52629A99 D618B747 C4A94151 1AB995BB 14905404
  5F4A0B9F F387F346 D5F3A249 2AED1B6A 3DD639D8 4924366A 1234DD2D B13CD489
  7E2EA101 63BCCC82 2F7A6D0B 33AB5705 3C784A6D A3DD1E5B 96CF54C6 CF4D59BC
  1BFD6CB6 E72FCB29 88DCBE6D 4D76FB83 1FAF5683 E4E20822 00A9EB2E 3BEF0DF9
  02030100 01A381EF 3081EC30 1D060355 1D0E0416 04149457 DF7D1482 2D31BB28
  772E8996 1886DA46 84BA3081 BC060355 1D230481 B43081B1 80149457 DF7D1482
  2D31BB28 772E8996 1886DA46 84BAA181 95A48192 30818F31 0B300906 03550406
  13025553 31133011 06035504 08130A43 616C6966 6F726E69 61311130 0F060355
  04071308 53616E20 4A6F7365 31163014 06035504 0A130D61 69726573 70616365
  20496E63 310D300B 06035504 0B13046E 6F6E6531 0B300906 03550403 13026361
  31243022 06092A86 4886F70D 01090116 15737570 706F7274 40616972 65737061
  63652E63 6F6D8201 00300C06 03551D13 04053003 0101FF30 0D06092A 864886F7
  0D010104 05000381 C100AEB0 349DC0F9 2AAA3A57 75B3A79C 5421A9D0 15389261
  95C03479 04DA81D4 120F58FA E2299223 BEB54A90 6D70F7F7 2192EFAF A4B0F488
  604E3094 BBCC77A3 60A88129 0849B87B 5CA1AA17 21922A55 6B68E0D3 1ADC7264
  C4C4D6B2 33345C86 254E4988 096645CD 40F12761 8BC37E71 DAD91677 25322361
  71D87A16 F92AF7C1 51CB8892 443BC666 59BEA47B 985E8866 68A1EBD4 88BBF6E7
  A949FDF8 7711D518 A80E203D A12BEBDC 6963EDA7 B76079A3 22380C96 0CB8D324
  CADD949D EA39E0EF 033D
        quit
crypto pki certificate chain airespace-new-root-cert
certificate ca 00
  3082045A 30820383 A0030201 02020100 300D0609 2A864886 F70D0101 04050030
  81A6310B 30090603 55040613 02555331 13301106 03550408 130A4361 6C69666F
  726E6961 3111300F 06035504 07130853 616E204A 6F736531 17301506 0355040A
  130E4169 72657370 61636520 496E632E 31143012 06035504 0B130B45 6E67696E
  65657269 6E67311A 30180603 55040313 11416972 65737061 63652052 6F6F7420
  43413124 30220609 2A864886 F70D0109 01161573 7570706F 72744061 69726573
  70616365 2E636F6D 301E170D 30333037 33313133 34313232 5A170D31 33303432
  39313334 3132325A 3081A631 0B300906 03550406 13025553 31133011 06035504
  08130A43 616C6966 6F726E69 61311130 0F060355 04071308 53616E20 4A6F7365
  31173015 06035504 0A130E41 69726573 70616365 20496E63 2E311430 12060355
  040B130B 456E6769 6E656572 696E6731 1A301806 03550403 13114169 72657370
  61636520 526F6F74 20434131 24302206 092A8648 86F70D01 09011615 73757070
  6F727440 61697265 73706163 652E636F 6D3081DF 300D0609 2A864886 F70D0101
  01050003 81CD0030 81C90281 C100CCA0 F92330BD 49E947A4 3FA2ACF3 A4827F66
  77BB66F4 6B1636BA 84EF0966 9CCAE0EA CA6F1D0F BA90FEFA 58B8502C 10FC78DC
  C9D126D8 8F2AD059 A8A69BFE 90324BD6 4553CED9 131B99B0 282A73D9 8655EFAF
  5EA54096 22E54B9F C4258988 78F1A51F F47B16F2 0C0A37A3 52603A5A B0DC4533
  B0C0B7C8 02DF25F0 585DFF5F 43FDAE1F 48A34BDF F80AC27E 30BE931B D3490ADE
  C81FF6F9 974F1408 55C8813F D334F1B8 A1892B0A 10D98A44 7DBF213E 64520D20
  E78E9322 DA11CA7A 46ACEB41 46AB0203 010001A3 82011430 82011030 1D060355
  1D0E0416 0414538D 8360478D C20F8066 3232E9E1 7070552B 17EA3081 D3060355
  1D230481 CB3081C8 8014538D 8360478D C20F8066 3232E9E1 7070552B 17EAA181
  ACA481A9 3081A631 0B300906 03550406 13025553 31133011 06035504 08130A43
  616C6966 6F726E69 61311130 0F060355 04071308 53616E20 4A6F7365 31173015
  06035504 0A130E41 69726573 70616365 20496E63 2E311430 12060355 040B130B
  456E6769 6E656572 696E6731 1A301806 03550403 13114169 72657370 61636520
  526F6F74 20434131 24302206 092A8648 86F70D01 09011615 73757070 6F727440
  61697265 73706163 652E636F 6D820100 300C0603 551D1304 05300301 01FF300B
  0603551D 0F040403 02010630 0D06092A 864886F7 0D010104 05000381 C10006E3
  653D4B19 FAA0C3B9 8EAE23C5 A3305E42 4522A961 BE1B5B88 56ED2E5A E42F7AC0
  26AA2805 9824080D 1512169B 44E42847 2EBBA573 29F070DB 56011C7B E9F3A240
  399A3557 A50384EC A0353DCF 49E8EC01 94047469 0BC12079 2764873D 25943DCD
  66A9726F 4A79EB40 1C7C6897 4E925D80 2313C126 1F604763 A9D9AC1F DF0092F6
  57DF1AB4 9B904E22 CE5515CD 44F68A00 4E2BC861 FBC1540D C1F3A66B 8CDDC1C2
  7C442027 E6241198 B0E002DE 9E06D64F 0D538987 96C1C0DB 12B0F581 6FED
        quit
crypto pki certificate chain airespace-device-root-cert
certificate ca 03
  3082047F 308203A8 A0030201 02020103 300D0609 2A864886 F70D0101 04050030
  70616365 2E636F6D 301E170D 30353034 32383232 33373133 5A170D31 35303132
  36323233 3731335A 3081A831 0B300906 03550406 13025553 31133011 06035504
  040B130B 456E6769 6E656572 696E6731 1C301A06 03550403 13134169 72657370
  61636520 44657669 63652043 41312430 2206092A 864886F7 0D010901 16157375
  70706F72 74406169 72657370 6163652E 636F6D30 81DF300D 06092A86 4886F70D
  01010105 000381CD 003081C9 0281C100 A93C0158 E7284E75 FF86A57A 886ACA37
  430BECF0 7582F56B DB6AC514 554FB06E AA327B3E CE3C9391 03C93BA4 0C0AF932
  A6CB5DA3 F1C3C528 53BF4E19 2C1BFC48 467EBD93 06B4974A 1273BF35 8AD8540F
  261E612B A2673B68 D239C87E 1E9E967B 2654D285 45BB7F78 5F4E9D4B 7B8001AA
  2F455CFF 4552ECDB 5667E3FC E7093E06 8FAE353D 4228B48D 8B415D9B F496342D
  C1459987 B69BFA4B 51FB67B4 A0C21E7F C6269A39 47EB1D48 5E83B129 8B079E5E
  1EDAB5A0 BE5E1DE0 109FF0BD 4750E32B 02030100 01A38201 37308201 33300C06
  03551D13 04053003 0101FF30 2E060960 86480186 F842010D 0421161F 41697265
  73706163 65204465 76696365 20434120 43657274 69666963 61746530 1D060355
  1D0E0416 04140A52 3BB12570 523B9CEA 747FB2AD 3D8F95EA 3FCC3081 D3060355
  61697265 73706163 652E636F 6D820100 300D0609 2A864886 F70D0101 04050003
  81C100A0 E8D59D9B DA9EED0C 96045DFE A37084EC 59B5C3D3 71694DB0 70664E0C
  8060D69E E366E81F 9F3CCF68 8AB0498E CCFA6CA7 2854F2D8 046690C9 8FEC84EF
  2F7F0F08 C90F719D C0F4C125 CED1B525 6DD93E51 777BD5E8 7F1DC79F CC502DC2
  0242C05D 1682DEE3 DF7541B8 C55B433C 10DFE2BF D2E802E7 D923329A 23A2076F
  86BCC048 D569B383 59AC8979 97F02C55 6F8FE318 754F605C 43CDA7C8 1847B085
  1DADF0D6 CD62C8DE A86E6E12 4A7CDCBF A6FCC7E1 852A1DB1 529D63B3 688305F6 7BD25F
        quit
crypto pki certificate chain cisco-root-cert
certificate ca 5FF87B282B54DC8D42A315B568C9ADFF
  30820343 3082022B A0030201 0202105F F87B282B 54DC8D42 A315B568 C9ADFF30
  0D06092A 864886F7 0D010105 05003035 31163014 06035504 0A130D43 6973636F
  20537973 74656D73 311B3019 06035504 03131243 6973636F 20526F6F 74204341
  20323034 38301E17 0D303430 35313432 30313731 325A170D 32393035 31343230
  32353432 5A303531 16301406 0355040A 130D4369 73636F20 53797374 656D7331
  1B301906 03550403 13124369 73636F20 526F6F74 20434120 32303438 30820120
  300D0609 2A864886 F70D0101 01050003 82010D00 30820108 02820101 00B09AB9
  ABA7AF0A 77A7E271 B6B46662 94788847 C6625584 4032BFC0 AB2EA51C 71D6BC6E
  7BA8AABA 6ED21588 48459DA2 FC83D0CC B98CE026 68704A78 DF21179E F46105C9
  15C8CF16 DA356189 9443A884 A8319878 9BB94E6F 2C53126C CD1DAD2B 24BB31C4
  2BFF8344 6FB63D24 7709EABF 2AA81F6A 56F6200F 11549781 75A725CE 596A8265
  EFB7EAE7 E28D758B 6EF2DD4F A65E629C CF100A64 D04E6DCE 2BCC5BF5 60A52747
  8D69F47F CE1B70DE 701B20D6 6ECDA601 A83C12D2 A93FA06B 5EBB8E20 8B7A91E3
  B568EEA0 E7C40174 A8530B2B 4A9A0F65 120E824D 8E63FDEF EB9B1ADB 53A61360
  AFC27DD7 C76C1725 D473FB47 64508180 944CE1BF AE4B1CDF 92ED2E05 DF020103
  A351304F 300B0603 551D0F04 04030201 86300F06 03551D13 0101FF04 05300301
  01FF301D 0603551D 0E041604 1427F3C8 151E6E9A 020916AD 2BA08960 5FDA7B2F
  AA301006 092B0601 04018237 15010403 02010030 0D06092A 864886F7 0D010105
  05000382 0101009D 9D8484A3 41A97C77 0CB753CA 4E445062 EF547CD3 75171CE8
  E0C6484B B6FE4C3A 198156B0 56EE1996 62AA5AA3 64C1F64E 5433C677 FEC51CBA
  E55D25CA F5F0939A 83112EE6 CBF87445 FEE705B8 ABE7DFCB 4BE13784 DAB98B97
  701EF0E2 8BD7B0D8 0E9DB169 D62A917B A9494F7E E68E95D8 83273CD5 68490ED4
  9DF62EEB A7BEEB30 A4AC1F44 FC95AB33 06FB7D60 0ADEB48A 63B09CA9 F2A4B953
  0187D068 A4277FAB FFE9FAC9 40388867 B439C684 6F57C953 DBBA8EEE C043B2F8
  09836EFF 66CF3EEF 17B35818 2509345E E3CBD614 B6ECF292 6F74E42F 812AD592
  91E0E097 3C326805 854BD1F7 57E2521D 931A549F 0570C04A 71601E43 0B601EFE
  A3CE8119 E10B35
        quit
crypto pki certificate chain Cisco_IOS_MIC_cert
certificate 1994FEBE0000000201AD
  3082046C 30820354 A0030201 02020A19 94FEBE00 00000201 AD300D06 092A8648
  86F70D01 01050500 30393116 30140603 55040A13 0D436973 636F2053 79737465
  6D73311F 301D0603 55040313 16436973 636F204D 616E7566 61637475 72696E67
  20434130 1E170D31 32303730 32323030 3531345A 170D3232 30373032 32303135
  31345A30 818C310B 30090603 55040613 02555331 13301106 03550408 130A4361
  6C69666F 726E6961 3111300F 06035504 07130853 616E204A 6F736531 16301406
  0355040A 130D4369 73636F20 53797374 656D7331 1B301906 03550403 13124331
  3134302D 64343863 62356230 31663366 3120301E 06092A86 4886F70D 01090116
  11737570 706F7274 40636973 636F2E63 6F6D3082 0122300D 06092A86 4886F70D
  01010105 00038201 0F003082 010A0282 010100D6 B172C5C3 DFBE5F46 27F4F148
  662C8F48 9964713F 37C84FB5 CCD54B24 7361C4FB 1F0F0F8D 6AF3130E 951CB1BA
  0172ABDA 29D0BCC3 A636E035 73B21279 4077B31D 4FC21575 9FD24E2F 070B0C91
  A4133205 E884E03F C291320E C271B9AC D6F38DEE 7C5DB787 642BE22C 7E5ACEB4
  71204DFD 0160748D E8AC797E 263033A1 F7C233B4 9A27F0B3 9F6337DF A15D8302
  060317C7 E7A2D3B3 7FC61965 41593653 A09CBF8A 763232E7 3D78D715 D13B1085
  281226FA 9D70E7B5 8A58BFB7 9056BF64 5F3E0775 9C5A62E9 10640E41 15B838F4
  726FACC7 B705D227 89F8FBC1 8A9F04D7 A5DC18E7 97707C4B A1371536 0384FE76
  E43945B2 E02D79A4 01816BD0 574E75B6 453AEF02 03010001 A3820120 3082011C
  300E0603 551D0F01 01FF0404 030205A0 301D0603 551D0E04 16041425 B9E89D49
  CD2271E0 9C9A24E8 53251363 E350C330 1F060355 1D230418 30168014 D0C52226
  AB4F4660 ECAE0591 C7DC5AD1 B047F76C 303F0603 551D1F04 38303630 34A032A0
  30862E68 7474703A 2F2F7777 772E6369 73636F2E 636F6D2F 73656375 72697479
  2F706B69 2F63726C 2F636D63 612E6372 6C304806 082B0601 05050701 01043C30
  3A303806 082B0601 05050730 02862C68 7474703A 2F2F6369 73636F2E 636F6D2F
  73656375 72697479 2F706B69 2F636572 74732F63 6D63612E 63657230 3F06092B
  06010401 82371402 04321E30 00490050 00530045 00430049 006E0074 00650072
  006D0065 00640069 00610074 0065004F 00660066 006C0069 006E0065 300D0609
  2A864886 F70D0101 05050003 82010100 1366997A EC96B330 F8534553 3C838023
  2A6846D0 C9722984 75EF80B1 C39AF732 E0425507 8B0C9D29 FE8F3C25 A3B801C8
  0BF8D685 C48AD3D7 CADB5126 417F7189 1079E042 611C4FB5 85095434 8D77726C
  486383C7 CC6610C5 9B90BFF1 7288333B F59AFB91 D5F488AC EFF588E7 62AF418C
  D7E398B1 94BAD457 708406D2 25E39CBB A3025D6D DA054A82 0A41BB56 7F95080F
  B3FB1A11 5D0E6453 43FCB52E 9F55F77E 7348530B F3B9FAD6 F82F5720 6F3CC930
  2106698B 34657FEB FF6C5346 0F20678C 0D9DE97B 2D261D11 48033668 2664B884
  41921DEF 0A20F984 A53C1E67 A57286F7 C8EDF7F8 3C1B4B96 45778D0D 204BC723
  7EB44DDC 71A3D32C 374D822C C809E556
        quit
certificate ca 6A6967B3000000000003
  308204D9 308203C1 A0030201 02020A6A 6967B300 00000000 03300D06 092A8648
  86F70D01 01050500 30353116 30140603 55040A13 0D436973 636F2053 79737465
  6D73311B 30190603 55040313 12436973 636F2052 6F6F7420 43412032 30343830
  1E170D30 35303631 30323231 3630315A 170D3239 30353134 32303235 34325A30
  39311630 14060355 040A130D 43697363 6F205379 7374656D 73311F30 1D060355
  04031316 43697363 6F204D61 6E756661 63747572 696E6720 43413082 0120300D
  06092A86 4886F70D 01010105 00038201 0D003082 01080282 010100A0 C5F7DC96
  943515F1 F4994EBB 9B41E17D DB791691 BBF354F2 414A9432 6262C923 F79AE7BB
  9B79E807 294E30F5 AE1BC521 5646B0F8 F4E68E81 B816CCA8 9B85D242 81DB7CCB
  94A91161 121C5CEA 33201C9A 16A77DDB 99066AE2 36AFECF8 0AFF9867 07F430EE
  A5F8881A AAE8C73C 1CCEEE48 FDCD5C37 F186939E 3D71757D 34EE4B14 A9C0297B
  0510EF87 9E693130 F548363F D8ABCE15 E2E8589F 3E627104 8726A415 620125AA
  D5DFC9C9 5BB8C9A1 077BBE68 92939320 A86CBD15 75D3445D 454BECA8 DA60C7D8
  C8D5C8ED 41E1F55F 578E5332 9349D5D9 0FF836AA 07C43241 C5A7AF1D 19FFF673
  99395A73 67621334 0D1F5E95 70526417 06EC535C 5CDB6AEA 35004102 0103A382
  01E73082 01E33012 0603551D 130101FF 04083006 0101FF02 0100301D 0603551D
  0E041604 14D0C522 26AB4F46 60ECAE05 91C7DC5A D1B047F7 6C300B06 03551D0F
  04040302 01863010 06092B06 01040182 37150104 03020100 30190609 2B060104
  01823714 02040C1E 0A005300 75006200 43004130 1F060355 1D230418 30168014
  27F3C815 1E6E9A02 0916AD2B A089605F DA7B2FAA 30430603 551D1F04 3C303A30
  38A036A0 34863268 7474703A 2F2F7777 772E6369 73636F2E 636F6D2F 73656375
  72697479 2F706B69 2F63726C 2F637263 61323034 382E6372 6C305006 082B0601
  05050701 01044430 42304006 082B0601 05050730 02863468 7474703A 2F2F7777
  772E6369 73636F2E 636F6D2F 73656375 72697479 2F706B69 2F636572 74732F63
  72636132 3034382E 63657230 5C060355 1D200455 30533051 060A2B06 01040109
  15010200 30433041 06082B06 01050507 02011635 68747470 3A2F2F77 77772E63
  6973636F 2E636F6D 2F736563 75726974 792F706B 692F706F 6C696369 65732F69
  6E646578 2E68746D 6C305E06 03551D25 04573055 06082B06 01050507 03010608
  2B060105 05070302 06082B06 01050507 03050608 2B060105 05070306 06082B06
  01050507 0307060A 2B060104 0182370A 0301060A 2B060104 01823714 02010609
  2B060104 01823715 06300D06 092A8648 86F70D01 01050500 03820101 0030F330
  2D8CF2CA 374A6499 24290AF2 86AA42D5 23E8A2EA 2B6F6923 7A828E1C 4C09CFA4
  4FAB842F 37E96560 D19AC6D8 F30BF5DE D027005C 6F1D91BD D14E5851 1DC9E3F7
  38E7D30B D168BE8E 22A54B06 E1E6A4AA 337D1A75 BA26F370 C66100A5 C379265B
  A719D193 8DAB9B10 11291FA1 82FDFD3C 4B6E65DC 934505E9 AF336B67 23070686
  22DAEBDC 87CF5921 421AE9CF 707588E0 243D5D7D 4E963880 97D56FF0 9B71D8BA
  6019A5B0 6186ADDD 6566F6B9 27A2EE2F 619BBAA1 3061FDBE AC3514F9 B82D9706
  AFC3EF6D CC3D3CEB 95E981D3 8A5EB6CE FA79A46B D7A25764 C43F4CC9 DBE882EC
  0166D410 88A256E5 3C57EDE9 02A84891 6307AB61 264B1A13 9FE4DCDA 5F
        quit
memory validate-checksum 30
username Cisco secret 5 $1$6VBf$qsf93jjIbMK.00i0wDxht0
ip ssh version 2
bridge irb
interface Dot11Radio0
antenna gain 0
mbssid
power client local
packet retries 64 drop-packet
no cdp enable
interface Dot11Radio1
antenna gain 0
mbssid
power client local
no cdp enable
interface GigabitEthernet0
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 spanning-disabled
no bridge-group 1 source-learning
interface BVI1
ip address 10.44.4.20 255.255.255.0
ip default-gateway 10.44.4.1
ip forward-protocol nd
no ip http server
logging trap emergencies
logging origin-id string AP:d48c.b5b0.1f3f
logging facility kern
logging snmp-trap notifications
logging snmp-trap informational
logging snmp-trap debugging
logging 255.255.255.255
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line vty 0 4
transport input telnet
line vty 5 15
end
Leo Laohoo Tue, 10/08/2013 - 14:55
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
See the filename with a prefix "RCV"?  It's called a "Recovery" file.  I'd like to call this as a "lite" IOS.  It's designed to be used by APs to operate in a BASIC status.  It is NOT designed to operate in production.  The main function of the RCV file is to FIND the WLC.  Once the AP is able to join to a WLC, the WLC will then push the correct or "full" IOS down to the AP.
It doesn't matter if you manually upload the full IOS to the AP, at the end of the day, the WLC will decide which IOS your AP should use (in a controller-based environment).
So don't even bother deciphering why your controller-based AP is using 12.4 or 15.0 IOS as it won't make any difference.
Srinivasan K Tue, 10/08/2013 - 15:04
Thanks for the message Leo.
I know about the lite IOS. The problem here is none of my other AP's (most same models) receive 15.2 except the problamatic one.
Even I thought it wouldn't make any difference, but while on 15.2 the AP couldn't see any more than 1 WiFi profile. Not sure if its a bug or some configuration issue. Remaining 14 AP's in my network connected to the same WLC, works fine with all 5 profiles (Running 12.4)
Scott Fella Tue, 10/08/2013 - 15:20
  • Hall of Fame,
    2017 Wireless
What everyone is saying is that the WLC provides the firmware to the access points. Post a screen shot of what your seeing.
Leo Laohoo Tue, 10/08/2013 - 16:14
  • Hall of Fame,
    2017 LAN, Wireless
This has got NOTHING to do with whether or not your AP is running 12.4 or 15.0 so you need to refrain from thinking this is the case.  (You confuse people who don't know/read and they will start posting recommendatations that doesn't make sense or relevance.)
It sounds like you've got issues with your AP Groups configuration.
Post the output to the command "sh wlan apgroup".
Abha Jha Tue, 10/08/2013 - 15:22
  • Cisco Employee,
Have you used upgrade tool method or the archive-download method??
If upgrade tool have you checked for any errors during conversion and have you tried the other method??
Cisco recommends to clear the configuration before you convert an AP to
LWAPP.
Then clear all config and only leave env_vars and the IOS image in flash:.
You can then upgrade again.
These tips can be used when you upgrade from autonomous to LWAPP       mode:
  • If the NVRAM is not cleared when the controller tries to write to it           after the conversion, problems are caused. Cisco recommends to clear the           configuration before you convert an AP to LWAPP. In order to clear the           configuration:
    • From the IOS GUI—Go to System Software > System             Configuration > Reset to Defaults, or Reset to Defaults             Except IP.
    • From CLI—Issue the write erase and             reload commands at the CLI and do not allow the             configuration to be saved when prompted.
      This also makes the text file of APs to be converted by the Upgrade             Tool more simple to create as the entries become ,Cisco,Cisco,Cisco.
  • Cisco recommends that you use the tftp32. You can download the latest           TFTPD server at http://tftpd32.jounin.net/ leavingcisco.com.
  • If a firewall or an access control list is enabled during the upgrade           process, the upgrade tool can become unable to copy the file that contains           environmental variables from a workstation to an AP.
    If a firewall or access control list blocks the copy operation and           you select the Use Upgrade Tool TFTP Server option, you cannot proceed with the           upgrade because the tool cannot update the environmental variables, and the           image upload to the AP fails.
  • Double check the image you are trying to upgrade to. The upgrade from           IOS to LWAPP images is different from the normal IOS images.
    Under My Documents/My Computer--> Tools--> Folder Options, make           sure you uncheck the Hide file extensions for known file types check box.
  • Always make sure to use the latest available Upgrade Tool and Upgrade           Recovery Image. The latest versions are available in the Wireless Software           Center.
  • An AP can not boot a .tar image file. It is an           archive, similar to zip files. You need to unbundle the .tar file into AP flash with the archive download command, or else pull the bootable image out of the tar file first then put the           bootable image into AP flash.
Srinivasan K Tue, 10/08/2013 - 15:47
Thanks Jha, I used archive-download method. Infact I went to a level of doing factory reset on the AP.
