Warning message
Call goes in one direction
Oct 10th, 2013
Hello.
I have the next scheme:
9971(1000,1003) --- cisco 3945 ---- cisco 2901 --- 7742(1020)
Calls from 7742 goes to 9971 but if I dial number of 7742 on 9971 - I get immediate drop and complete silence. What it could be? Dial peers config:
3945#sh run | s dial
dial-peer voice 1001 voip
destination-pattern 1020
session protocol sipv2
session target ipv4:10.2.4.254
2901:
dial-peer voice 1000 voip
destination-pattern 100[0-4]
session target ipv4:10.2.4.120
Carlo Poggiarelli Thu, 10/10/2013 - 04:54
  • Green, 3000 points or more
Hi Volodymyr.
Where IP Phones are registered? (CUCM/CME).
In case of 2 clusters of CUCM, did you check if the incoming calling search space is correct to call those extensions?
Let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Carlo Poggiarelli Thu, 10/10/2013 - 04:59
Please attach a debug ccsip messages during a non working call
Carlo
Volodymyr Khrystenko Thu, 10/10/2013 - 06:07
Via: SIP/2.0/UDP 10.2.4.120:5060;branch=z9hG4bK292CB3
Remote-Party-ID: "Khrystenko" ;party=calling;screen=yes;privacy=off
To:
Date: Thu, 10 Oct 2013 13:01:25 GMT
Call-ID: [email protected]
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3871121503-0820122083-2396055902-0007138101
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1381410085
Contact:
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 231
v=0
o=CiscoSystemsSIP-GW-UserAgent 520 7684 IN IP4 10.2.4.120
s=SIP Call
c=IN IP4 10.2.4.120
t=0 0
m=audio 17792 RTP/AVP 18 19
c=IN IP4 10.2.4.120
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:19 CN/8000
a=ptime:20
014183: Oct 10 15:01:25.298 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 488 Not Acceptable Media
To: ;tag=19BA1630-20DA
CSeq: 101 INVITE
Warning: 304 10.2.4.254 "Media Type(s) Unavailable"
Reason: Q.850;cause=65
Server: Cisco-SIPGateway/IOS-15.2.4.M1
Content-Length: 0
014184: Oct 10 15:01:25.298 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:[email protected]:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
014185: Oct 10 15:01:29.126 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 10.2.4.120:5060;branch=z9hG4bK295788
To:
Date: Thu, 10 Oct 2013 13:01:29 GMT
Min-SE:  1800
Cisco-Guid: 3910213195-0820122083-2396580190-0007138101
CSeq: 101 INVITE
Timestamp: 1381410089
Contact:
Expires: 180
Max-Forwards: 69
Content-Length: 232
Andrey Chertolyas Thu, 10/10/2013 - 06:22
SIP/2.0 488 Not Acceptable Media - this message most likely means that there is a codec mismatch issue. Please provide dial peers configuration from both sides.
Kind regards,
Andrew C.
Carlo Poggiarelli Thu, 10/10/2013 - 06:57
Hi.
On 3945:
codec g711ulaw
dtmf-relay rtp-nte
no vad
on 2901
codec g711ul
dtmf-relay rtp-nte
no vad
Carlo
Volodymyr Khrystenko Thu, 10/10/2013 - 07:05
How I got fast busy tone and :
Oct 10 17:05:08.899 UTC+3: //2441/CDD3F5308FC1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
Via: SIP/2.0/UDP 10.5.150.2:5060;branch=z9hG4bK14c9a4e8
From: "Khrystenko" ;tag=58971ecd6808003759df5365-370a1d29
To: ;tag=66C0C534-12F1
Date: Thu, 10 Oct 2013 14:05:07 GMT
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Reason: Q.850;cause=47
Content-Length: 0
Oct 10 17:05:08.905 UTC+3: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:[email protected];user=phone SIP/2.0
Date: Thu, 10 Oct 2013 14:05:08 GMT
CSeq: 101 ACK
Content-Length: 0
Oct 10 17:05:08.913 UTC+3: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.5.150.254:5060;branch=z9hG4bK2D5253D
To: ;tag=58971ecd68080038757a51d9-676f638a
CSeq: 102 SUBSCRIBE
Server: Cisco-CP9971/9.2.1
Contact:
Expires: 0
Content-Length: 0
Carlo Poggiarelli Thu, 10/10/2013 - 07:13
Can you please attach both vg configuration?
Carlo
Andrey Chertolyas Thu, 10/10/2013 - 07:14
To: ; - that's strange, do you really have a phone with number 1 registered? Could you provide full telephony-related configuration from both gateways?
Kind regards,
Andrew C.
Volodymyr Khrystenko Thu, 10/10/2013 - 07:34
On 2901:
Building configuration...
Current configuration : 8352 bytes
! Last configuration change at 17:25:44 UTC+3 Thu Oct 10 2013 by vkhrystenko
! NVRAM config last updated at 19:49:41 UTC+3 Fri Oct 4 2013 by vkhrystenko
version 15.1
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime
service password-encryption
hostname DMZ-ISR-L
boot-start-marker
boot-end-marker
enable secret 4 50orVilsugq550D3ZKx/scefA8kvn3WdHZm7.0/Vta2
no aaa new-model
clock timezone UTC+3 3 0
clock summer-time sumkiev recurring last Sun Mar 4:00 last Sun Sep 4:00
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.5.150.254
ip dhcp pool VOICE_SCOPE
network 10.5.150.0 255.255.255.0
default-router 10.5.150.254
option 150 ip 10.5.150.254
dns-server 10.2.4.23 8.8.8.8
ip dhcp pool DATA
network 10.5.100.0 255.255.255.0
default-router 10.5.100.254
option 150 ip 10.5.100.254
dns-server 8.8.8.8
no ip domain lookup
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-88597495
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-88597495
revocation-check none
rsakeypair TP-self-signed-88597495
crypto pki certificate chain TP-self-signed-88597495
certificate self-signed 01
  30820227 30820190 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  2F312D30 2B060355 04031324 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 38383539 37343935 301E170D 31323132 32393038 31333338
  5A170D32 30303130 31303030 3030305A 302F312D 302B0603 55040313 24494F53
  2D53656C 662D5369 676E6564 2D436572 74696669 63617465 2D383835 39373439
  3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281 8100D9A8
  3C31C925 35DB0391 C1FAD203 F5FB0805 EC0A9FD0 82211E5E C6C0075F 35513F76
  142E9957 7C188477 D37F8074 BF98C3E5 BD28E1D7 2AE4E722 17E14147 6AA9C691
  45236E40 A809F91E 7006C909 282C41FF 7EC3AD48 34E22680 D3187B85 04AF7CCC
  B5F69A04 CD019CB6 B3BC19AE 234B46F4 1DA9C0AE 8884C480 43A58B02 AD170203
  010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603 551D2304
  18301680 140F7BF9 CE4D76C6 55D095A1 E3CD3608 A7EEC8C5 1F301D06 03551D0E
  04160414 0F7BF9CE 4D76C655 D095A1E3 CD3608A7 EEC8C51F 300D0609 2A864886
  F70D0101 05050003 81810024 5BD07113 BC712B2F E1E820B2 3294CEB8 BC4C5B36
  8299CDAC D33534DE 921E5344 4AF508EE 522CD168 6486F581 3422D79F F4D71C21
  62F09B3A 9AB1CB6A 212CAE5A F8E21F35 4368C175 836B0D07 15E66805 7E578CFA
  1057513A E22CF31F F083166B F1130406 3AE085EE 7956750E D0C809A4 29365D28
  095A0809 01EE39D2 74D809
      quit
voice-card 0
voice service voip
allow-connections sip to sip
no supplementary-service sip handle-replaces
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server expires max 3600 min 120
voice register global
mode cme
source-address 10.5.150.254 port 5060
max-dn 10
max-pool 10
load 9971 sip9971.9-2-2SR1-9.loads
authenticate register
timezone 31
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 000201490805545A
voice register dn  1
number 1000
name Khrystenko
label Khrystenko Vlad 1
voice register dn  2
number 1003
name Khrystenko
label Khrystenko Vlad 2
voice register dn  9
number 3636
name 3636
label 3636
voice register pool  1
id mac 5897.1ECD.6808
type 9971
number 1 dn 1
number 2 dn 2
dtmf-relay sip-notify
username vkhrystenko password XXXX
description Khrystenko
voice register pool  2
id mac 7C1E.B300.49FF
number 1 dn 9
username 3636 password 3636
license udi pid C3900-SPE250/K9 sn FOC1651515Y
license accept end user agreement
hw-module pvdm 0/0
username vkhrystenko privilege 15 password 7 071B20434051415D4F
redundancy
interface GigabitEthernet0/0
description for_mgmt_temporary
ip address 10.2.4.120 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.5
encapsulation dot1Q 5
ip address 10.5.5.254 255.255.255.0
interface GigabitEthernet0/1.100
encapsulation dot1Q 100
ip address 10.5.100.254 255.255.255.0
interface GigabitEthernet0/1.254
encapsulation dot1Q 150
ip address 10.5.150.254 255.255.255.0
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.2.4.254
ip route 10.0.0.0 255.0.0.0 10.2.4.254
access-list 100 permit ip 10.0.0.0 0.255.255.255 any
nls resp-timeout 1
cpd cr-id 1
tftp-server flash:/Cisco9971/dkern9971.100609R2-9-2-2SR1-9.sebn alias dkern9971.100609R2-9-2-2SR1-9.sebn
tftp-server flash:/Cisco9971/kern9971.9-2-2SR1-9.sebn alias kern9971.9-2-2SR1-9.sebn
tftp-server flash:/Cisco9971/rootfs9971.9-2-2SR1-9.sebn alias rootfs9971.9-2-2SR1-9.sebn
tftp-server flash:/Cisco9971/sboot9971.031610R1-9-2-2SR1-9.sebn alias sboot9971.031610R1-9-2-2SR1-9.sebn
tftp-server flash:/Cisco9971/sip9971.9-2-2SR1-9.loads alias sip9971.9-2-2SR1-9.loads
tftp-server flash:/Cisco9971/skern9971.022809R2-9-2-2SR1-9.sebn alias skern9971.022809R2-9-2-2SR1-9.sebn
tftp-server Cisco7942/term62.default.loads alias term62.default.loads
tftp-server Cisco7942/term42.default.loads alias term42.default.loads
tftp-server Cisco7942/SCCP42.9-2-1S.loads alias SCCP42.9-2-1S.loads
tftp-server Cisco7942/jar42sccp.9-2-1TH1-13.sbn alias jar42sccp.9-2-1TH1-13.sbn
tftp-server Cisco7942/dsp42.9-2-1TH1-13.sbn alias dsp42.9-2-1TH1-13.sbn
tftp-server Cisco7942/cvm42sccp.9-2-1TH1-13.sbn alias cvm42sccp.9-2-1TH1-13.sbn
tftp-server Cisco7942/apps42.9-2-1TH1-13.sbn alias apps42.9-2-1TH1-13.sbn
tftp-server Cisco7942/cnu42.9-2-1TH1-13.sbn alias cnu42.9-2-1TH1-13.sbn
control-plane
mgcp profile default
dtmf-relay rtp-nte
codec g711ulaw
no vad
gateway
timer receive-rtp 1200
gatekeeper
shutdown
telephony-service
max-ephones 10
max-dn 20
ip source-address 10.5.150.254 port 2000
timeouts ringing 10
system message Altis holding
cnf-file location flash:
time-zone 31
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
transfer-system full-consult
directory entry 1 911 name Support IT
ephone-dn  2
number 1002
label Zatyshnyi Dima 2
description Secondary line
name Zatyshnyi
ephone-dn  3
number 1010
pickup-group 1
ephone-dn  5
number 4
park-slot timeout 20 limit 2 notify 1010 transfer 1010 retry 5 limit 3
name Parking...
ephone-dn  6
number 7
name Parking...
ephone-dn  7
number 6
name Parking...
ephone-dn  8
number 5
name Parking...
ephone-dn  9
number A101002
description Intercom
intercom A100102 barge-in label "Zatyshniy"
ephone-dn  10
number A100102
intercom A101002 barge-in label "PC"
ephone-dn  11
number 3333
name Myphones
paging ip 239.0.0.1 port 2000
ephone-dn  12
number 3355
name HolePhones
paging ip 239.1.1.1 port 2000
paging group 11
ephone  1
device-security-mode none
mac-address 8478.ACE6.3343
username "zat" password zat
paging-dn 11
type 7942
button  2:10
ephone  2
mac-address 1803.7374.56EF
paging-dn 11
type CIPC
button  1:3 2:9
ephone  3
mac-address 8478.ACE6.33AE
type 7942
line con 0
password 7 070C2E425D061500131F11
logging synchronous
login local
line aux 0
line vty 0 4
access-class 100 in
login local
transport input ssh
line vty 5 13
access-class 100 in
login
transport input all
line vty 14 15
login local
transport input all
scheduler allocate 20000 1000
ntp master 5
ntp server 78.152.160.1
end
Volodymyr Khrystenko Thu, 10/10/2013 - 07:45
On 2901:
Current configuration : 59418 bytes
! Last configuration change at 16:15:58 UTC+2 Thu Oct 10 2013 by admin2
! NVRAM config last updated at 15:39:53 UTC+2 Thu Oct 10 2013 by admin1
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service sequence-numbers
hostname cisco2901
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.152-4.M1.bin
boot system flash:c2900-universalk9-mz.SPA.151-2.T1.bin
boot-end-marker
logging buffered 51200
logging console critical
aaa new-model
aaa accounting connection default start-stop group radius
aaa accounting connection h323 start-stop group radius
aaa accounting system default start-stop group radius
aaa accounting resource default start-stop group radius
aaa session-id common
clock timezone UTC+2 2 0
no ip source-route
no ip bootp server
no ip domain lookup
ip domain name altis.local
ip name-server 10.2.4.23
ip dhcp-server 10.2.1.59
ip dhcp-server 10.2.1.57
ip dhcp-server 10.2.1.56
ip dhcp-server 10.2.1.58
ip cef
l2tp-class l2tpclass1
no ipv6 cef
stcapp ccm-group 1
stcapp feature access-code
stcapp feature speed-dial
stcapp supplementary-services
port 0/0/0
  fallback-dn 2201
port 0/0/1
  fallback-dn 2101
port 0/0/2
  fallback-dn 2399
port 0/0/3
  fallback-dn 2102
crypto pki trustpoint TP-self-signed-703877443
subject-name cn=IOS-Self-Signed-Certificate-703877443
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 x.x.x.x 255.255.255.255
  ipv4 10.2.1.212 255.255.255.255
  ipv4 10.2.4.200 255.255.255.255
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server
voice class codec 10
codec preference 1 g711alaw
codec preference 2 g711ulaw
mode cme
max-dn 200
max-pool 42
create profile sync 0380025834254157
voice translation-rule 3
rule 1 /\.*/ /0\1/
voice translation-rule 4
rule 1 /^38\.*/ /\1/
voice translation-profile 1
translate calling 3
translate called 1
voice translation-profile 2
translate calling 2
voice translation-profile 3
translate calling 2
translate called 4
vxml version 2.0
license udi pid CISCO2901/K9 sn FCZ1446904G
license boot module c2900 technology-package securityk9
hw-module pvdm 0/0
redundancy
ip tcp synwait-time 10
ip ssh version 2
track 1 ip sla 1 reachability
class-map match-all exhmap
match access-group name exchsync
class-map match-all Telepresence
class-map match-all exchmap2
match qos-group 1023
class-map match-all exchsyncmap
class-map match-all video
match protocol rtp video
class-map match-all databases
class-map match-all voice
match protocol rtp audio
policy-map wanpolicy
class exchmap2
  police cir 10000000 conform-action transmit  exceed-action drop
policy-map OUTPUT
class voice
  priority 10000
class class-default
  fair-queue
policy-map exchpol
class exhmap
  set qos-group 1023
policy-map QoSforTP
class Telepresence
  priority 1000
class databases
class class-default
gw-accounting aaa
acct-template callhistory-detail
bridge irb
protocol ieee
bridge 41 route ip
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
ccm-manager mgcp
ccm-manager config server 10.2.4.200
ccm-manager config
ccm-manager sccp local GigabitEthernet0/1.40
ccm-manager sccp
mgcp
mgcp call-agent 10.2.4.200 service-type mgcp version 0.1
mgcp package-capability rtp-package
mgcp bind control source-interface GigabitEthernet0/1.40
mgcp bind media source-interface GigabitEthernet0/1.40
sccp ccm 10.2.4.200 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1.40
associate ccm 1 priority 1
associate profile 1 register XCODE123456
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 6
associate application SCCP
dtmf-relay rtp-nte
codec g711ulaw
no vad
gateway
gatekeeper
shutdown
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 16
sdspfarm tag 1 XCODE123456
video
  maximum bit-rate 2000
max-ephones 10
max-dn 10
ip source-address 10.2.3.1 port 2000
service phone videoCapability 1
moh "flash0:moh.au"
transfer-pattern 2555
transfer-pattern 2...
transfer-pattern 2777
transfer-pattern 2304
transfer-pattern 0952810902
transfer-pattern 3134
ephone-dn  1
number 1001 no-reg primary
ephone-dn  2
number 1020 no-reg primary
ephone  1
type 7942
button  1:2
end
Andrey Chertolyas Thu, 10/10/2013 - 08:57
As I understand, your second configuration is from 3945, not from 2901 as you indicated, is it correct? Please check it and correct accordingly.
At least you should implement this commands on your 2901:
sip
It is needed to specify the particular IP address to bind the SIP server to make sure that every SIP conversation originated on 2901 would use the IP address of gi0/0 which is 10.2.4.120
Another thing you can change is to add the address of originating interface on 2901 (which is 10.2.4.120) to 'ip addresses trusted list' on 3945, since it is not clear if you have it specified. Then make a call and gather next debugs in case it still doesn't work:
debug voice ccapi inout
BTW, 10.2.4.254 is the address of gi0/0 on 3945, right?
Kind regards,
Andrew C.
Andrey Chertolyas Mon, 10/14/2013 - 03:52
Hey Volodimir,
Did you have a chance to check my recommendations?
Kind regards,
Andrew C.
Volodymyr Khrystenko Mon, 10/14/2013 - 06:45
Hello. I just set codec to 711ulaw between routers and on 3945 to SIp phone and everything starts working. Stange((
