Warning message
Creating new fields for UCCX 9.0 CUIC
Oct 11th, 2013
I am tryin to create a Contact Service Activity report for a customer and I have 2 problems.
1st I have created a new field which I want to show the number of calls handled outsite of the Service Level.
The formula I have created is SUM(${calls_handled})-SUM(${handle_sl_met}) this works fine for the totals, however I am getting the overall totals on every Service line . Within Edit Properties i have just put in (${calls_handled})-(${handle_sl_met}) thinking that would sort the individual service lines, however it is still showing the overall total number!
The 2nd problem I have is that I want to run the same report so that it show multiple day summaries for each service.
Date        Serv         Off     Hand    Abnd
3rd Oct  Cust Serv    25         23       2
3rd Oct  Acounts      15         12       3
4th Oct  Cust Serv    32         29       3
4th Oct  Acounts      27         26       1
When I run the report for start time 3/10/2013 to 4/10/2013  for entire range - grouping by start time - summarising daily.
it show as follow
3rd Oct  Cust Serv    57         52       5
3rd Oct  Acounts      42         38       4
Has anyone done this if so can you advise as it is now extremely urgent.
Thanks Sarah
Related Content
