Warning message
ISE Application won't start after upgrading to 1.2
Answered Question
Oct 11th, 2013
we have a customer which is using a ISE-3315 Hardware appliance running 1.1.4.218 Patch 1. He needed to upgrade to 1.2 Patch 2 to support iOS7. There is no secondary appliance so this is a standalone deployment.
We did the upgrade according to Cisco documents (backup, patching the current to the latest patch, performing the upgrade). This all seems to have successfully gone through. I can access the CLI via SSH but the application services are not going to start. I tried to stop and start the services (application stop ise/ application start ise) but I get the following message:
ise/admin# application start ise
Waiting up to 20 seconds for lock: APP_START to complete
Database is still locked by lock: APP_START. Aborting. Please try it later
% Error: Another ISE DB process (APP_START) is in progress, cannot perform Application Start at this time
I waited for half a day but it stayed the same. Also commands like application configure or application config-reset do not work. restarting the ISE did not work aswell.
Has anyone encountered this problem and solved it? My next Idea would be a clean re install of ISE 1.2 and then restoring the backup.
regards,
Patrick
Correct Answer by jjohnston1127 about 3 years 10 months ago
I had an issue with the MnT DB upgrade during a 1.1 ISE to 1.2 ISE upgrade.  It got stuck for hours.  Upon calling TAC, that is exactly what they advised.  Install a fresh node and restore the backup.  It will convert it to 1.2 upon restoration.
The TAC engineer  I worked with also admitted that they had very mixed results in the 1.1 -> 1.2 upgrade so they had been recommending installing new and restoring configuration.
Overall Rating: 5 (2 ratings)
Correct Answer
jjohnston1127 Wed, 10/16/2013 - 05:02
  • Silver, 250 points or more
Patrick Meyer Mon, 10/21/2013 - 01:28
Dear Jjjohnston1127,
This is exactly what we did and it worked.
My advice for all who try the same: Make sure you have a copy of your config before attempting to upgrade. Also, a secondary admin node would be nice to upgrade without business impact. If no secondary node is available, I would suggest to do a clean install rather than upgrading.
regards,
Patrick
Naresh Ginjupalli Wed, 10/16/2013 - 09:42
  • Cisco Employee,
Hi Patrick,
What I see here is the upgrade would have completed and trying to start application automatically. The process being used for this activity is APP_START. During this process the database is locked untill this process is complete. Due to some reason the APP_START process is not releasing the lock that is acquired and thus causing the issue. That is the reason when you start the application server it is saying that APP_START process is in progress. To know better on this issue we would like to see ADE.log file information.
Please follow below steps to get that information.
-Login to CLI with admin access.
-Type the below command.
sh logging system ade/ADE.log
This log will show at what exact process the upgrade is struck.
jsteffensen Thu, 01/09/2014 - 23:47
Hi Everyone
The we have the same problem - it doesn't seems if Cisco cares to solve this obius prblem with new upgrade images on CCO...
After 4 Hours of update of a stand-alone-VM the processes failed to start even waiting for 12 hours.
The Update seems to have successfully gone through, we can access the CLI via SSH,
We also tried to stop and start the services (application stop ise/ application start ise) but I get the following message:
I'ts really anoying with the poor software quality from Cisco!
Naresh Ginjupalli Fri, 01/10/2014 - 00:41
  • Cisco Employee,
Hi Jsteffensen,
Hope you have taken ISE application backup before you start the upgrade process.
If so can you please reload the ISE node instead of stopping and starting the services. Once reloaded can you please check if the services are up and running.
