Maximum throughput on a 2811
Oct 11th, 2013
Hello All,
I'm looking to learn what will happen when the maximum throughput on a Cisco 2811 router has been reached? I can't seem to find any good documentation. Any suggestions?
Thank you in advance!
Joseph W. Doherty Fri, 10/11/2013 - 10:11
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
What happens?  Generally packets start to be lost.  For example, you send 100 Mbps to one FE interface and perhaps 40 Mbps then exits another FE interface.  As most network applications don't well tolerate a 60% packet loss rate, effectively the applications may behave as if there was 100% packet loss.
